PineTab/Early-Adopter
The PineTab Early Adopter edition was the first hardware revision of the PineTab which shipped to customers. Shipping began on September 6, 2020.
Contents
Software
The device shipped with a beta build of Ubuntu Touch by UBports. This build is available to download at https://ci.ubports.com/job/rootfs/job/rootfs-pinetab-systemimage/18/. It has the following problems which are software, not hardware, issues:
- The mouse fails to move around the entire screen. It is stuck in an 800px horizontal box.
- It is not possible to enable Bluetooth
- Cameras do not function
- Portrait mode does not function
The first-time setup wizard advises the user to unplug the keyboard dock (avoiding the mouse issues) and update the system. Unfortunately, as of this update to this page (September 8, 2020) this will not fix any of the issues above.
16GB/64GB storage software error
The image installed on the device was sized for a 16GB (~14GiB) eMMC, but the PineTab shipped with a 64GB (~58GiB) eMMC chip installed. This means that the "Storage" page in the "About" section of Ubuntu Touch System Settings will show total storage as 14.0GiB until the partition table on the device is edited.
UBports developers are currently working on a solution that will automatically edit the partition table and resize the data partition without disturbing any user data.
Wifi
Wifi disappears
If wifi stopped working, first try usual means:
- switching wifi off and on again
- reboot PineTab
If it still doesn't work, open terminal and type this:
nmcli r
If output is two lines with red word disabled under word WIFI - rejoice, since this issue is known (although it's not yet investigated well enough to figure out when it happens, so clues to developers are likely welcome). To fix it, just type this in the terminal:
nmcli r wifi on
Wifi missing if started with keyboard attached
OS version: RC#6 (2020-W37)
symptom: if you started with keyboard attached wifi will not come up
reason: the service urfkill is not running
fix:
sudo service urfkill restart
Wifi radio reception is very weak (tweak needed)
This needs a tweak! How to open the PineTab?
Tested with UT, Mobian and Archlinux: sitting right beside the router gives a connection (ca. 60% level). No reception in a distance of 7 meters, no wall, just an opened door, some edges, router not directly visible. Pinephone right beside the Pinetab has an absolutly stable wifi connection.
