PineTab
Revision as of 23:03, 4 January 2020 by TuxThePenguin (Talk | contribs) (General fixes for inconsistent information)
Jump to: navigation, search
PAGE UNDER CONSTRUCTION, INFO SUBJECT TO CHANGE
The PineTab is a 10" tablet created by Pine64.
Specifications
  • Dimensions: 11mm x 17.5mm x 26mm (Thickness, Width, Height)
  • Weight: ~600-700g
  • Build: Plastic
  • Storage:
    • 64GB of internal eMMC storage
    • MicroSD slot, bootable
    • M.2 SSD slot, (optional)
  • Cameras: 2Mpx Front, 5Mpx Rear
  • CPU: Allwinner A64 Quad Core
  • GPU: Mali 400 MP2
  • RAM: 2GB LPDDR3
  • I/O: HD Video Out (Mini HDMI), Micro USB 2.0 OTG, USB 2.0 A host, 3.5mm Headphone/Mic combo,
  • Network
    • WiFi
    • M.2 LTE / Cell MODEM card, (optional, and takes place of optional M.2 SSD)
  • Screen: 10.1" IPS 800x1280 Capacitive LCD
  • Attachments/Accessories: Magnetically attached keyboard (optional)
  • Battery: 6000MAh (6Ah)
  • Misc. features:
    • Volume rocker and home button
    • Speakers and Microphone
    • 2.5mm OD Power (5V 3A) Port
Keyboard
Overview: The PineTab detachable keyboard features a full function row, FN key functionality, meta key (where the Windows key would be) and all of the keys you need for daily use.
FN keys:: Pause/play (F2), Stop (F3), Previous(F4), Next(F5), Music (F6), Mail (F7), Home (F8), Mute (F9), Vol- (F10), Vol+ (F11), Disable touchpad (F12), NumLock (Insert), Scroll Lock (Delete), PgUp (Up Arrow), PgDn (Down Arrow), Home (Left Arrow), End (Right Arrow), Digital Numpad (7,8,9,0,U,I,O,P,J,K,L,;,M,.,/)
Operating Systems
The PineTab will automatically boot from microSD if a bootable card is inserted. Although it is technically possible to use any ARM distro (because the PineTab uses the mainline kernel), there are a few that are designed specifically for phones and tablets:
postmarketOS
postmarketOS is a preconfigured version of Alpine Linux for mobile devices. The latest builds can be downloaded from the images page to be flashed to the PineTab.
More information is available at postmarketos.org and on their dedicated PineTab wiki page.
Arch Linux ARM
Arch Linux ARM with LXQt built by Danct12 can be downloaded here
