PinePower
Contents
PinePower 65W GaN Charger
A small and compact palm size 65W wall socket power adapter. It features 2 USB-C ports and 1 USB-A port charger. Gallium Nitride technology ensures a small and light charger with high charging efficiency. It has a retractable US plug.
General specifications
Body
- Dimensions: 74.8mm x 36.6mm x 32mm
- Weight: 130 grams
- Build: Plastic
- Color: Black
Power
- Input: AC 100-240V 50/60Hz 1.5A Max
- Output: 65W
- Power switch
Connections
- 240Vac input US plug, adapters for AU, EU, and UK,
- 1x USB-A
- 2x USB-C
Power specifications
Output | Max output power | Power ranges PD | Power ranges QC | Power ranges PPS |
Single USB-C1 or C2 | 65W | 5V3A, 9V3A, 12V3A, 15V3A, 20V3.5A | - | 3.3-11V5A |
Single USB-A | 65W | - | QC3.0 4.5V5A, 5V4.5A, 9V3A, 12V3A, 20V3A | - |
USB-C1 &
USB-C2 combined |
USB-C1 &
USB-A combined |
USB-C1 &
USB-C2 + USB-A combined |
Internals
TBA
PinePower 120W Desktop Power Supply
A 120W desktop power adapter. It features 1 USB-C port and 4 USB-A port. The 120W output is not per port, but total output power. This is calculated by combining the 65W USB-C, 3x15W USB-A and the 18W USB-A QC, making a total of 128W. The only difference between the US and EU edition is the supplied power cable. Every port, with exception of the wireless Q-charger, has a display, portraying the output voltage and amps. The display back light can be turned on and off by capacitive touch button, located on the top left side of the unit.
Body
- Dimensions: 123mm x 115mm x 48mm
- Weight: 543 grams
- Build: Plastic
- Color: Black
Display
- Individual port voltage status display
- Individual port current status display
- Display turn off switch
Power
- Input: AC 100-240V 50/60Hz ?A Max
- Output: 120W
- Power switch
Connections
- 240Vac input either US or EU plug is supplied
- 4x USB-A
- 1x USB-C
Output | Protocol | Version | Max output power | Power ranges |
USB-C | PD | ? | 65W | 5V3A, 9V3A, 12V3A, 15V3A, 20V3.25A |
USB-A | QC | 3.1 | 18W | 5V3A, 9V2A, 12V1.5A |
USB-A | USB | ? | 15W | 5V3A |
Wireless charger | Qi | 1.2 | 10W | - |
Internals
The power unit is not made to be disassembled, do so at your own risk. The front plate is secured with 4 tabs, that can be disengaged with a screwdriver. The complete assembly can be slid out, but do mind the same tab in the casing. The power button at the back of the case has a plug that can be disconnected from the main PCB. The wireless charging PCB has to be de-soldered, or forcefully removed from the inner casing, as it is glued to the top of the case.
Some remarks:
- This main PCB is marked as XR SEMI v1.1
- Two unmarked packages, control the display.
- An antenna is connected on the display PCB, lining up with the 'lamp' symbol. This is the capacitive touch button to control the display back light.
- The 65W PD USB-C port is controlled by a HUSB339 controller, paired with a GOFORD G16 MOSFET.
- The other ports have a NDP1360KC as final power converter.
