PinePhone Updating Instructions
Revision as of 08:10, 11 March 2021 by A-wai (talk | contribs) (→‎Mobian: Remove deprecated instructions to update bootloader)
Mobian
There is no need to regularly flash the newest images to your phone. You can use the pre-installed program "Software" or because Mobian is based on Debian you can open a terminal and use apt to keep the system updated. The following command will check for updates and install them:
 $ sudo apt-get update && sudo apt-get upgrade
If some packages were held back, you can update them with:
 $ sudo apt-get dist-upgrade
Other OSs
Manjaro, or other Arch Linux based OSs
To first download all new package's
 $ sudo pacman -Suuyyw
and do the same without the 'w' to apply new package's
 $ sudo pacman -Suy
(--cache-dir can be used for a separate download location, otherwise consider reading https://wiki.archlinux.org/index.php/Pacman#Configuration for further optimization)
If you encounter any errors during the update, you may have to update the Pacman mirrors as follows:
 $ sudo pacman-mirrors -f
Please add the information
