User:StructurallySound/PinePhone Software Releases/Feature Matrix
Revision as of 03:34, 27 December 2020 by StructurallySound (talk | contribs)
Version Tested mobian-pinephone-phosh-20201215
UI Shell Phosh
Features
General System
  • ✅ Copy / paste works
  • ✅ WIFI works
  • ✅ WAN works
  • ✅ App switching works,
  • ✅❌ Headphone jack works, but require additional settings change to output audio to headphones.
  • ❌ Phone crashed and needed restart several times over ~10 days with relatively light usage.
  • ❌ UX to place/move typing cursor hard to use
Phone Calls
  • dialing in
  • dialing out
  • speaker mode
  • mute
  • call quality
  • Contacts integration
App: Calls (Stock App)
  • ✅ Can make / receive calls with decent call quality.
  • ✅ Speaker mode works.
  • ✅ Displays contact names properly in call history panel for phone numbers that stored in contacts.
  • ❌⬆ Cellular connection sometimes terminate and does not reconnect after about a day of usage. Re-locking and unlocking the phone sometimes fixes it.
  • ❌ Calls sometimes does not have incoming audio. Toggle to speaker mode fixes that problem.
  • ❌ When playing audio in another app, incoming phone call has no incoming audio.
  • ❌ ⬇No integration to contacts or SMS app from call history panel. (No way to add new phone number to address book; no way to reply by text to a number in call history panel.)
SMS/MMS
  • Sending text
  • Receiving text
  • Group MMS
  • Sending image (MMS)
  • Receiving image (MMS)
App: Chats (stock app)
  • ✅ Can send / receive text messages.
  • ❌ No MMS support (cannot send/receive images or group text)
  • ❌ No sound/vibrate notification when receiving text when the SMS app is in focus, even when phone is locked.
  • ❌ "Add contact" (to address book) does not work
Email
  • Sending / Receiving emails
  • downloading / uploading attachments
App: Geary (Stock App)
  • ❌⬆ No way to specify authentication method / port for IMAP (as a result, probably does not support a lot of different IMAP configs)
Map
  • GPS location
  • building / landmark search
  • directions
App: Maps (Stock App)
  • ✅ Can get GPS location
  • ✅ Can search for landmarks
  • ✅ Can search for directions to places
  • ❌ search UI not phone optimized (difficult if not impossible to see some text / buttons).
Browser App: GNOME Web (Stock App)
  • ✅ Basic browsing works
  • ✅ Audio playback continues in background
  • ✅❌ Multiple tabs work, although attempting to close one tab prompts UI/UX inconsistent with Phosh.
  • ❌⬇ YouTube plays, but with low frame rate (<10FPS)
  • ❌⬇ When phone is locked, audio playback stops after a while (5mins), but resumes on awaking phone (no unlocking needed)
App: Firefox (Stock App)
  • ✅ YouTube plays with good frame rate
