PinePhone Software Releases
Revision as of 21:34, 20 November 2019 by Dukla2000 (talk | contribs) (→‎Where/how to report defects: add contributions)
PinePhone Operating Systems
Software installation
Initial (new) OS installation should be to an SDcard.
Preparation of SDcard
  • Download your chosen image from the options below
  • Extract and write the image to an SDcard
  • Plug SD card into phone
  • Boot phone
If you need step-by-step instructions for writing an image to an SDcard, check NOOB#Step-by-Step_Instructions_to_Flashing_MicroSD_Cards then return to this page.
Installation to eMMC
  • Prepare a new SDcard as above
  • Boot the phone
  • Run a magic script (to be defined/written/...)
Postmarket OS
postmarketOS also has a script pmbootstrap that can build your SDcard for you, see for example this forum thread.
Download location
Direct download from postmarketOS image site
userid/password
demo/demo
What works
What does not work
postmarketOS PinePhone wiki site
Contributions
See postmarketOS wiki for options to contribute.
Ubuntu Touch by UBPorts
Download location
Jenkins Project rootfs-pinephone
userid/password
What works
What does not work
You should use the built-in Ubuntu Touch feature to "Report a bug". See UBports own tutorial on how to submit defects.
Contributions
See UBports website for how to donate.
KDE Plasma
Download location
  • Not Yet Ready
userid/password
What works
What does not work
Where/howto report defects
Sailfish OS
Download location
The Sailfish OS image is built on Gitlab CI. The latest image can be installed using the flashing script.
The script downloads the image and bootloader from our CI, extracts everything and burns it onto the SD card.
Instructions:
4. Execute it: ./flash-it.sh
5. Follow the instructions. Some commands in the script require root permissions (for example: mounting and flashing the SD card).
Note: The script will format and flash the SD card, make sure that you don't have any important data on the SD card!
userid/password
What works
What does not work
Contributions
See the SailfishOS wiki for options to contribute.
Maemo Leste
Download location
Maemo Leste test builds download
userid/password
root/toor
What works
What does not work
NixOS
Download location
  • Not Yet Ready
userid/password
What works
What does not work
LuneOS
Download location
userid/password
What works
What does not work
Nemo Mobile
Download location
  • Not Yet Ready
userid/password
What works
What does not work
Contributions
Details about contributions and donations are on the NixOS website.
Other Resources
