PinePhone Software Releases
Revision as of 15:16, 13 April 2023 by Rsglobal (talk | contribs) (Update GloDroid)
This page contains a list of all available releases and tools for the PinePhone in alphabetical order.
Note: Some releases may not have a good setup for the backlight at low brightness. If configured too low, the backlight shuts down completely, but the screen is still displayed and usable in bright front-light.
See PinePhone Installation Instructions on how to install the operating systems. Please see PinePhone Updating Instructions for how to update the phone.
Software Releases
Arch Linux ARM
(Unofficial) Arch Linux ARM with choice of Phosh UI, Plasma Mobile, sxmo or barebones. Currently being maintained by the DanctNIX community (GitHub: danctnix, dreemurrs-embedded).
Download
Get both stable and test builds at GitHub releases.
Default credentials
Default user alarm/123456
root (barebone only) root/root
Notes
ExpidusOS
A fork of Void Linux with a custom fork of XFCE called Gensis as the default desktop environment, developed by Midstall Software.
Download
Check the download page for that latest version, or the image file list for all versions, look for the filename that starts with "pinephone".
Default credentials
Default user expidus/expidus
Notes
What works, what does not work:
How to contribute and report defects:
Fedora
Download
There is also an FTP server with images build every night @ ftp://pine.warpspeed.dk/nightly/pinephone/ (Mount this with something like Nautilus)
Default credentials
GitHub images pine/123456
Nightly images (via FTP) pine/1111
Notes
WiFi, Bluetooth, SMS, Data, Calls all work! There are still a few bugs though, and some features don't have driver support yet on any PinePhone distribution.
Please send your bug reports to the project's issue tracker. Be sure to include logs if applicable! Send us pull requests on Github.
Gentoo
There are unofficial Gentoo overlays with ebuilds for the PinePhone. There are no images - the image must be built manually, including picking the kernel, bootloader and the desired desktop environment. The ARM64 version of Gentoo has to be selected.
Download
Overlay locations:
Notes
The documentation can be found here:
Note: Please consider cross-compiling the software on the computer. Long compilation times and heat production can lead to a reduced lifespan of the phone.
GloDroid
A fully open-source port of Android and LineageOS to the PinePhone.
GitHub: GloDroid
Download
Notes
Feature overview:
  • Works: WiFi, screen dimming, sound, touchscreen, charging and telephony(partially) works.
  • Doesn't work: Bluetooth and GPS
  • See more at project status page
Kali Linux
The official Kali Nethunter images for PinePhone and PinePhone Pro have been released now. For older/unofficial releases, you can still download from the GitHub releases page. Get Nethunter App for your PinePhone's Kali Linux. Packet Injection is working now, use iwconfig instead of airmon-ng.
Download
Default credentials
Default user for Unofficial Releases kali/8888
Default user for Nethunter Releases kali/1234
Notes
Installation:
$ unxz -c Kali-PinePhone-{Release}.img.xz | dd of=/dev/{storage_block} bs=1M status=progress
$ growpart /dev/mmcblkX Y
$ e2fsck -y -f /dev/mmcblkXpY
$ resize2fs /dev/mmcblkXpY
# X: Storage Device Y: Partition Number
LuneOS
LuneOS is one of the original multi-tasking OS-es that runs on Linux. Based on HP/Palm's webOS, merged with latest technology stack from LG called webOS OSE (a derivative of what LG uses on their Smart TV's), software such as Qt5 and makes use of the Yocto build system.
Download
Default credentials
Default user root
Notes
In order to connect to the device using SSH/SCP via WiFi: You can simply connect via SSH/SCP via WiFi using the PinePhone's IP address on port 22.
Maemo Leste
Maemo is a trimmed-down version of Debian for mobile devices, originally a collaboration between Nokia and many open source projects (the Maemo community) before Nokia abandoned it. The more well-known devices Maemo supports are the OpenMoko and N900. The community now takes full responsibility in developing fully open source Maemo for a variety of mobile devices. You may be interested to learn more about the features in their Maemo Leste FAQ.
Maemo 8 "Leste" is an ARM64 port of Devuan (Debian without systemd) and runs the mainline Linux kernel. The default user interface stack is Hildon, Xorg, Matchbox WM, and GTK.
Download
There is also an image builder, see the wiki for instructions on how to build a custom image. For current status and instructions, please read their PinePhone wiki page.
Default credentials
root toor
user 12345 (lockscreen)
Notes
Most discussion occurs at #maemo-leste on irc.libera.chat and this thread.
All other contact information is listed on the main page of the Maemo wiki.
Submit bug reports on github. To track known issues, you may use these search terms: pinephone, pine64.
Manjaro ARM
Manjaro is a user-friendly Linux distribution based on the independently developed Arch operating system with the Plasma Mobile and Phosh desktop environment.
Download
Default credentials (Only Phosh)
Default user manjaro/123456
root root/root
Notes
The installation of the stable images is strongly suggested. The dev images might break frequently.
Mobian
An unofficial Debian build for ARM64 running with Phosh (developed by Purism, uses Wayland instead of Xorg). The base system is pure Debian, with only the GUI applications and a few others (ModemManager, WiFi chip firmware) being built from modified sources (as well as the kernel and u-boot). Current version is Debian Bookworm.
Download
Note: Tow-Boot is required to be able to boot the images, see here!
Default credentials
Default user mobian/1234
Notes
The development is work in progress. See pinephone-support for further information. The Mobian wiki can be found here.
In order to connect to the device using SSH/SCP via WiFi, you need to install SSH on the device. You can do this by executing the following in a shell: "sudo apt-get install ssh", afterwards you can connect via SSH/SCP via WiFi using the PinePhone's IP address on port 22.
Multi-distro demo image
Warning: This is a demo image for testing different operating systems before installing a regular image. Attempting to use this image productively is highly discouraged. The kernel is shared across the different operating systems and is not updated.
This image allow users to try many Linux distributions easily, without having to figure out how to flash them individually and juggle with many microSD cards. Also called megi's 15-in-1 multi boot image.
Download
Update 2022-01-26, using megi's kernel 5.16.2
DD image to SD card and boot. This image is for 16GiB or larger SD cards, also works if flashed to eMMC.
This is also a good build for charging depleted battery. Just boot up this build with power supply connected, keep the PinePhone charging for 3 hours at power down stage.
For more info on this build, please visit its entry the "News" section of its web page.
Due to its size, download though torrent is suggested by the author on its main page.
Default credentials
General 1111
sxmo user/1111
Manjaro seems to insist on 123456
Notes
Note: Note about zstd) archive file (.zst):
On Linux, you may install or compile zstd, then write the image to SD card by piping zstdcat and dd. See the "Installation" section of its web page for command examples.
On Windows, instead of the offical zstd command line program, you may use 7-zip-zstd. Different installation method is provided in their README. Install 7-Zip-zstd / zstd, extract the disk image file (.img) from the zstd archive, and flash with tools like Win32 Disk Imager.
Also see PinePhone Installation Instructions.
Nemo Mobile
Nemo Mobile is the open source build of Sailfish OS with a open source UI called Glacier, based on Manjaro.
Download
Default credentials
root root/root
Notes
The website of the Nemo Mobile UX Team can be found here. Please report bugs regarding the Nemo Mobile UI as GitHub issue.
NixOS
NixOS is a Linux distribution built on top of the Nix package manager using declarative configuration to allow reliable system upgrades.
Download
There is a guided installer by the Mobile NixOS project available. An installer image that can be flashed to a sdcard can be downloaded from the Hydra build instance.
Users that want to build a local image, are expected to follow the instructions in the Getting Started page, and Project's device page.
Notes
Project home page: Mobile NixOS
OpenMandriva Lx
OpenMandriva Lx with Plasma Mobile as UI.
Download
The official image can be found at sourceforge.net. See here for the offical announcement.
Notes
Note: This image is solely for testing purposes.
openSUSE
Our images use the same openSUSE Tumbleweed base as our desktop images, except what needs to be changed for the PinePhone. The images include zypper (RPM) as the default package manager, and have access to virtually the same (open source) software as our desktop repositories, thanks to the Factory ports. Using dnf is possible, if preferred.
Download
To verify the images you need to import our GPG key. Keep on mind that the first boot may stay on black screen for about a minute - consequent boots should be faster.
You can find install instructions at this section in the openSUSE Wiki.
Default credentials
Default user pine/1234
root root/linux
Notes
You can find all information about the releases of the project here. Detailed information, tips and troubleshooting suggestions are also provided at the openSUSE Wiki. You will also find information in our wiki on how to report issues (Contributing section).
postmarketOS
Download
Download page
Default credentials
Test images user user/147147
Notes
As of writing, official images are provided with Phosh, Plasma Mobile and Sxmo. The official images come in two flavors, either as a test image to try out postmarketOS, or with the installer.
When using the installer images (recommended), it is possible to:
  • encrypt the installation
  • install from the SD card to eMMC
Power users may also create their own image with the distribution's install and development tool pmbootstrap.
See the pine64-pinephone page of the postmarketOS wiki for details.
Sailfish OS
Sailfish OS is a Linux-based operating system based on open source projects such as Mer, and a closed source UI based on Lipstick.
Download
Flashing script
The Sailfish OS image is built on Gitlab CI. The latest image can be installed using the flashing script.
The script downloads the image and bootloader from the CI, extracts everything and burns it onto the SD card. Note: The script will format and erase the SD card!
Instructions:
  5. Execute it: ./flash-it.sh
  • When asked where to flash, type 'raw' and it will build the image on your computer. Otherwise define the path /dev/.... to flash to card or internal emmc.
username/password
Set PIN on initialization.
Notes
  • Sometimes the first run stalls before the tutorial. Reboot and it will start from setting the security pin.
  • The homescreen may be locked unless you boot with a sim card inserted. An old expired sim will do. If you do not have a SIM card on hands, do NOT set a security code on first boot.
  • When a screen with a loading circle is displayed, just left/right swipe it away.
  • If you're not familiar with Sailfish OS, pay attention to the tutorial - the interface works great, but is not immediately obvious. If you are familiar with it, you can skip the tutorial by touching all 4 corners starting top left.
See the Hardware Support section on the Mer Wiki's PinePhone Page.
There is a limited selection of apps available from the Jolla store, the vast majority are hosted on openrepos.net. If the Storeman app for openrepos is not preinstalled, download the RPM and click to install.
See the documentation wiki at the github project for help and links.
See the Installation section on the Mer Wiki's PinePhone Page for compile, build and development.
Git repo links are at the top of this OS section. other repos that may be helpful:
See the Sailfish OS wiki for links to their forum, as well as info required when reporting an issue. See the Sailfish OS wiki main page for options to contribute to Sailfish OS.
Notes
OTA is supported: zypper refresh && zypper update as root (devel-su to get root access). Things that need reflash are bootloader specific at the moment. If improvements like Crust or changes of partition layout are added, then you need to reflash.
SkiffOS
Minimal in-memory cross-compiled OS optimized for hosting multiple in parallel Docker containers. Provides the reliability of firmware with the ease-of-use of package managers.
Download
The repository and instructions can be found here.
Notes
Upgrade over-the-air via a simple rsync script, or copying 3 files.
Uses the Buildroot cross-compilation tool for support for all Pine64 boards.
Use configuration packages to configure distro:
Package Distro
core/pinephone_neon KDE Neon via Ubuntu repositories
core/pinephone_nixos Nixos Mobile
core/pinephone_gentoo Gentoo with Link-time Optimization & KDE Mobile or Phosh
core/pinephone_ubports Ubuntu Ports for PinePhone
core/pinephone_manjaro_kde Manjaro for PinePhone: KDE variant
core/pinephone_manjaro_phosh Manjaro for PinePhone: Phosh variant
core/pinephone_manjaro_lomiri Manjaro for PinePhone: Lomiri variant
The boot-up OS is upgraded independently from the containers.
Slackware
Slackware is the world's oldest actively developed Linux distribution, providing a modern user land (applications) and Linux Kernel, within a more classic Unix Operating System environment.
Download
Notes
Discussion: Thread
Ubuntu Touch
A Mobile Version of the Ubuntu Operating System made and maintained by the UBports Community.
Ubuntu touch is a mobile version of Ubuntu developed by the UBports community. Installation instructions can be found on the UBports PinePhone project. There is also a script to download the latest image and flash to your PinePhone. In the future, Ubuntu Touch will be able to be installed onto the PinePhone with the UBports installer GUI tool.
Download
Default credentials
Default user Set during boot
Notes
Scroll down to the bottom of this page, or directly here [1] to see which features work.
Contributions and bug reports can be made via. UBports gitlab page. See UBports website for how to donate.
Tools
There are software tools, that can be booted on the PinePhone.
JumpDrive
JumpDrive can be used to flash the eMMC (and the microSD card), see PinePhone Installation Instructions#Using JumpDrive.
See https://github.com/dreemurrs-embedded/Jumpdrive/releases for the latest image. Make sure to download the "PinePhone" image and to unpack the archive before flashing.
Tow-Boot
Tow-Boot is a more user-friendly distribution of U-Boot. Can also mount internal storage as USB Mass Storage by holding the volume up button at startup before and during the second vibration and the LED will turn blue if done successfully.
See https://github.com/Tow-Boot/Tow-Boot/releases for the latest image. Make sure to download the image with pinephoneA64 in the name.
Hardware test build
Warning: The factorytest image for hardware testing appears to be no longer maintained.
On the Braveheart model, there was a postmarketOS based basic Factory Test OS pre-installed on the eMMC. The developer Martijn Braam from postmarketOS has improved the functionality of the image considerably later. Since the 20200501 version, it is able to test all the hardware. It also includes functionality to install a new OS to the eMMC when using with an test image that includes that OS image. The downloadable image just does the hardware tests. Do not flash eMMC to test your device, just flash it to microSD and test from there. New versions are distributed as part of the postmarketOS distribution.
Note: The magnetometer test will fail on the new Beta Edition, as the factory image wasn't updated for it yet.
Links:
Historic factory builds
These are different operating system builds that was preloaded in the factory with testing utility.
Download the build, extract the image and dd it to a 8 GB or larger microSD card, then insert it into the PinePhone. After power up or reboot, you may perform and complete the test routine, or apply the build from microSD card to eMMC.
All the download links below are direct download from pine64.org.
Warning: These images are for testing purposes only. If you are looking for an up-to-date image please select one from the software releases section instead.
Distribution Download Link File Size MD5
Beta Edition pine64-pinephone-plamo-beta-factorytest.img.xz 1.78GB f16bce93504a52217540ac886863a418
Mobian pine64-pinephone-20201207-factorytest-mobian.img.xz 1.41GB 015be381ff4e650a7fca6d4eaa90d63d
KDE pine64-pinephone-20201208-factorytest-kde.img.xz 2.28GB 32979ff17b5ec4d358ce99f1aff0c77c
Manjaro pine64-pinephone-20201013-manjaro-stable-20201018-factory56.img.xz 1.04GB 4edfd4dceaefdd32a3417c1727161c29
postmarketOS pine64-pinephone-20200726-phosh-v20.05-factory.img.xz 517MB 244093be2f6d728fcbd1d29114607727
Ubuntu Touch PinePhone-flasher-ubuntu-7b.img.gz 1.05GB 2d7f5271e7a281db8f1b1219bedbe131
Installing other ARM64 distributions
Other ARM64 distributions might be installed as well, however this requires some tinkering and may not work well.
Note: Distributions not on this page may not even boot after you follow this section. In the best case, they will be barely usable. This is more for fun, or if you would like to port a new distribution to the PinePhone.
General steps:
  1. Create a boot partition (from 4 MB to about 252 MB) and a root partition (from the end of boot to the end of the card) filesystem on the SD card.
  2. Format the boot partition with vfat, and the root partition with a supported filesystem like ext4 or f2fs.
  3. Extract the root filesystem from your distribution's ARM image into the root filesystem on the SD card. Do not copy the partition, copy the files instead (in archive mode, like rsync -ar).
  4. Edit /etc/fstab to match your partitions.
  5. Grab megi's kernel from https://xff.cz/kernels/, Follow the instructions in the README, which involves copying the kernel modules into the SD card rootfs, and writing u-boot and the bootloader.
If you would like to see examples or specific commands for how to complete these steps, see:
Other Resources
Community
Hardware information
Apache NuttX RTOS is a Real-Time Operating System that supports PinePhone
Other software information
Other
