PinePhone Sensors and Navigation
DRAFT
Overview
The Pinephone contains various components that enable or aid orientation and navigation tasks.
  • Multi-GNSS Receiver as part of the cellular modem (GPS/Galileo/Glonass/BeiDou)
  • IMU (Inertial Measurment Unit), combined Accelerometer and Gyroscope sensor (MPU6050)
  • Magnetometer (LIS3MDL or AF8133J)
Pinephone navigation sensors
Hardware
Quectel EG25G Modem / GNSS Receiver
[TODO: add interfaces, constraints, antenna location]
Invensense/TDK MPU6050 IMU
Key features:
  • Digital-output X-, Y-, and Z-Axis angular rate sensors (gyroscopes) with selectable range of ±250, ±500, ±1000, and ±2000°/sec
  • Digital-output triple-axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g and ±16g
  • 400kHz Fast Mode I2C for communicating with all registers
ST LIS3MDL Magnetometer/Compass
Key features:
  • ±4/±8/±12/±16 gauss selectable magnetic full scale range
  • 16-bit data output
VTC AF8133J Magnetometer/Compass
Key features:
  • ±12/±22 gauss selectable magnetic full scale range
  • 400Hz max. update rate
Sensor reference frames
The sensors are mounted on the Pinephone's main board in different positions and orientations, for the purpose of orientation and navigation it is important to know the relationship between the sensor coordinate frames and the body frame of the phone...
Pinephone sensor coordinates systems (red) and body coordinate system (cyan)
As a basis for software development, a common body coordinate system has to be established along with it's relation to a world coordinate system. "iio-sensor-proxy expects the (sensor) readings to match those defined in the Linux IIO documentation, the Windows Integrating Motion and Orientation Sensors whitepaper, and the Android sensor documentation"[ref]. To transform the sensor coordinate systems into body coordinates, 'mount matrices' have to be defined.
[TODO: explain body reference choices, north-east-down world coordinates]
Software
Drivers
[TODO: i2cdev, linux-iio, support matrix]
  • EG25G: provides either UART or USB based interfaces for NMEA data
    • /dev/ttyUSB2 : AT command interface
    • /dev/ttyUSB1 : default NMEA data output
  • MPU6050:inv_mpu6050, inv_mpu6050_i2c, industrialio
	iio:device2: mpu6050 (buffer capable)
		9 channels found:
			accel_x:  (input, index: 0, format: be:S16/16>>0)
			6 channel-specific attributes found:
				attr  0: calibbias value: -2102
				attr  1: matrix value: 0, 0, 0; 0, 0, 0; 0, 0, 0
				attr  2: mount_matrix value: 0, 1, 0; -1, 0, 0; 0, 0, -1
				attr  3: raw value: 912
				attr  4: scale value: 0.000598
				attr  5: scale_available value: 0.000598 0.001196 0.002392 0.004785
			accel_y:  (input, index: 1, format: be:S16/16>>0)
				attr  0: calibbias value: 941
				attr  3: raw value: 516
			accel_z:  (input, index: 2, format: be:S16/16>>0)
				attr  0: calibbias value: 1242
				attr  3: raw value: 15860
			temp:  (input)
			3 channel-specific attributes found:
				attr  0: offset value: 12420
				attr  1: raw value: -1073
				attr  2: scale value: 2.941176
			anglvel_x:  (input, index: 4, format: be:S16/16>>0)
			5 channel-specific attributes found:
				attr  0: calibbias value: 0
				attr  1: mount_matrix value: 0, 1, 0; -1, 0, 0; 0, 0, -1
				attr  2: raw value: -32
				attr  3: scale value: 0.001064724
				attr  4: scale_available value: 0.000133090 0.000266181 0.000532362 0.001064724
			anglvel_y:  (input, index: 5, format: be:S16/16>>0)
				attr  2: raw value: 4
			anglvel_z:  (input, index: 6, format: be:S16/16>>0)
				attr  2: raw value: 0
			timestamp:  (input, index: 7, format: le:S64/64>>0)
			gyro:  (input, WARN:iio_channel_get_type()=UNKNOWN)
			1 channel-specific attributes found:
				attr  0: matrix value: 0, 0, 0; 0, 0, 0; 0, 0, 0
		3 device-specific attributes found:
				attr  0: current_timestamp_clock value: realtime
				attr  1: sampling_frequency value: 50
				attr  2: sampling_frequency_available value: 10 20 50 100 200 500
		2 buffer-specific attributes found:
				attr  0: data_available value: 0
				attr  1: watermark value: 1
		Current trigger: trigger1(mpu6050-dev2)
  • LIS3MDL: st_sensors, st_sensors_i2c, st_magn, st_magn_i2c, industrialio
	iio:device1: lis3mdl (buffer capable)
		4 channels found:
			magn_x:  (input, index: 0, format: le:S16/16>>0)
				attr  0: raw value: 6766
				attr  1: scale value: 0.000146
				attr  2: scale_available value: 0.000146 0.000292 0.000438 0.000584
			magn_y:  (input, index: 1, format: le:S16/16>>0)
				attr  0: raw value: -2046
			magn_z:  (input, index: 2, format: le:S16/16>>0)
				attr  0: raw value: 12726
			timestamp:  (input, index: 3, format: le:S64/64>>0)
				attr  1: sampling_frequency value: 1
				attr  2: sampling_frequency_available value: 1 2 3 5 10 20 40 80
		Current trigger: trigger0(lis3mdl-trigger)
Userspace services
[TODO: ...]
  • Modem Manager
  • ofono
  • gpsd
  • iio-sensor-proxy
  • geoclue
Tools/Utilities
[TODO: minicom, gpsmon, monitor-sensor, iio-utils...]
Applications
[TODO: pure-maps, navit, ...]
Development
[TODO: Open issues, tasks, projects]
  • AGPS integration
  • Raw magnetometer data + calibration in iio-sensor-proxy
  • Compass App
