PinePhone Pro Software Releases
Revision as of 19:56, 2 April 2023 by Fxc (talk | contribs) (→‎Download: changed label)
This page contains a list of all available releases and tools for the PinePhone Pro.
Arch Linux ARM
(Unofficial) Arch Linux ARM with choice of Phosh UI, Plasma Mobile, sxmo or barebones. Currently being maintained by the DanctNIX community (GitHub: danctnix, dreemurrs-embedded).
Download
Get both stable and test builds at GitHub releases.
Default credentials
Default user alarm/123456
root (barebone only) root/root
Notes
The GitHub page can be found here: dreemurrs-embedded/Pine64-Arch
A re-image of the above Arch image providing a Btrfs root partitioning has been made by user kaida.
Gentoo
There are unofficial Gentoo overlays with ebuilds for the PinePhone Pro. There are no images - the image must be built manually, including picking the kernel, bootloader and the desired desktop environment. The ARM64 version of Gentoo has to be selected. The PinePhone Pro will not boot with P-Boot but will boot with U-Boot, there is an ebuild for it.
Download
The overlay can be found under https://github.com/stealthgun/gjdwebserver-overlay
Notes
See https://stealthgun.tweakblogs.net/blog/19830/gentoo-on-a-pinephone-pro for the documentation.
Note: Please consider cross-compiling the software on the computer. Long compilation times and heat production can lead to a reduced lifespan of the phone.
GloDroid
A fully open source port of Android to the PinePhone and PinePhone Pro.
GitHub: GloDroid
Download
Notes
Initial support for the Pro since GloDroid v0.7.4.
LuneOS
LuneOS is one of the original multi-tasking OS-es that runs on Linux. Based on HP/Palm's webOS, merged with latest technology stack from LG called webOS OSE (a derivative of what LG uses on their Smart TV's), software such as Qt5 and makes use of the Yocto build system.
Download
Default credentials
Default user root
Notes
In order to connect to the device using SSH/SCP via WiFi: You can simply connect via SSH/SCP via WiFi using the PinePhonePro's IP address on port 22.
Manjaro ARM
Manjaro is a user-friendly Linux distribution based on the independently developed Arch operating system with the Plasma Mobile and Phosh desktop environment.
Download
Default credentials
Default user manjaro/123456
root root/root
Mobian
An unofficial Debian build for ARM64 running with Phosh (developed by Purism, uses Wayland instead of Xorg). The base system is pure Debian, with only the GUI applications and a few others (ModemManager, WiFi chip firmware) being built from modified sources (as well as the kernel and u-boot). Current version is Debian Bookworm.
Download
Images
Note: Tow-Boot required to be able to boot the images, see here!
Default credentials
Default user mobian/1234
Notes
The development is work in progress. See pinephonepro-support for further information. The Mobian wiki can be found here.
In order to connect to the device using SSH/SCP via WiFi, you need to install SSH on the device. You can do this by executing the following in a shell: "sudo apt-get install ssh", afterwards you can connect via SSH/SCP via WiFi using the PinePhonePro's IP address on port 22.
Kali Linux
The official Kali Nethunter images for PinePhone and PinePhone Pro have been released now. Get Nethunter App for your PinePhone's Kali Linux.
Download
Default credentials
Default user for Unofficial Releases kali/8888
Default user for Nethunter Releases kali/1234
Notes
Installation:
$ unxz -c nethunterpro-*-pinephonepro-phosh.img.xz | dd of=/dev/{storage_block} bs=1M status=progress
$ growpart /dev/mmcblkX Y
$ e2fsck -y -f /dev/mmcblkXpY
$ resize2fs /dev/mmcblkXpY
# X: Storage Device Y: Partition Number
Nemo Mobile
Nemo Mobile is the open source build of Sailfish OS with a open source UI called Glacier, based on Manjaro.
Download
Default credentials
root root/root
Notes
The website of the Nemo Mobile UX Team can be found here. Please report bugs regarding the Nemo Mobile UI as GitHub issue.
NixOS
NixOS is a Linux distribution built on top of the Nix package manager using declarative configuration to allow reliable system upgrades.
Download
Not available yet.
Notes
WIP. See https://github.com/NixOS/mobile-nixos/issues/440
postmarketOS
Download
Download page
Note that images for the PinePhone Pro are in the "community" category of devices indicating some features may not work. You can also build your own image using pmbootstrap
Notes
See the pine64-pinephonepro page of the postmarketOS wiki for details.
Various DPA Images
Multiple versions of unofficial images of various Debian-based distributions by the user DPA. They also contain some of DPA's own software.
Download
The latest successful image builds can be found here: https://repo.dpa.li/apt/dpa-image-builder/images/?board=pinephone-pro
Notes
Most of these images are still in development / incomplete and DPA doesn't have time to test them all, but they can still be useful as a starting point to get distributions running for which no other images have been created yet. DPA made these images because they wanted to run their favorite distribution, Devuan, on their phone.
The build scripts can be found in various places: GitLab, my server, GitHub
In theory, these build scripts can create images for any Debian-based distribution which supports ARM64 and can be bootstrapped using debootstrap.
