PinePhone Pro/IMX258 Camera Debugging
Revision as of 17:07, 13 June 2022 by Kgmt0 (talk | contribs) (→‎Megi saves the day: Remove excess empty line)
Background
The Pinephone Pro's rear camera is a Sony IMX258. The camera driver is present upstream, and at least Manjaro's kernel (downstream of Megi's) enables the driver. The camera does not seem to work; this page catalogs work on figuring out why.
Initial status
What do we see in dmesg?
imx258 1-001a: supply vana not found, using dummy regulator
imx258 1-001a: supply vdig not found, using dummy regulator
This tells us the kernel loads the driver, which is something.
Are these errors bad/fatal? Inspecting the source shows us that these supplies are defined in the imx258_supply_names array, and imx258_probe calls devm_regulator_bulk_get to set them up. imx258_probe checks the return code from devm_regulator_bulk_get, emitting a fatal "Failed to get supplies" message if the return code is negative (indicating failure). Since we don't see this message (or any others from the driver), it looks like it loads successfully!
How can we test the camera?
Megapixels
Megapixels requires a per-device file to configure cameras. This one isn't complete (most of its numbers are complete nonsense), but it should let us see what happens when Megapixels tries to access the camera: pine64,pinephone-pro.ini:
[device]
make=PINE64
model=PinePhone Pro
[rear]
driver=imx258
media-driver=rkisp1
capture-width=4208
capture-height=3118
capture-rate=60
capture-fmt=GRBG10P
preview-width=1280
preview-height=960
preview-rate=60
#preview-fmt=BGGR8
capture-fmt=GRBG10P
rotate=90
mirrored=true
focallength=2.6
cropfactor=12.7
fnumber=2.8
flash-display=true
This segfaulted Megapixels for me. After patching some trivial segfaults, I get fatal GTK4 issues and other tangential problems. Let's try something else.
Manually setting up a camera pipeline
We can roughly follow this guide. Doing so gives us the following commands:
"media-ctl" "-d" "platform:rkisp1" "-r"
"media-ctl" "-d" "platform:rkisp1" "-l" "'imx258 1-001a':0 -> 'rkisp1_isp':0 [1]"
"media-ctl" "-d" "platform:rkisp1" "-l" "'rkisp1_isp':2 -> 'rkisp1_resizer_selfpath':0 [1]"
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" '"rkisp1_isp":0 [fmt:SGRBG10_1X10/1048x780]'
"v4l2-ctl" "-z" "platform:rkisp1" "-d" "rkisp1_selfpath" "-v" "width=1048,height=780,"
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" '"rkisp1_resizer_selfpath":0 [fmt:SGRBG10_1X10/1048x780 crop:(0,0)/1048x780]'
"v4l2-ctl" "-z" "platform:rkisp1" "-d" "rkisp1_selfpath" "-v" "width=800,height=600,pixelformat=422P"
"v4l2-ctl" "-z" "platform:rkisp1" "-d" "rkisp1_selfpath" "--stream-mmap" "--stream-count" "1" "--verbose"
Careful readers will note that this is setting the camera up with a low resolution compared to what the sensor can do. For some reason I can't get the rkisp1 node to configure its sink pad with the maximum resolution of the sensor (4208x3118). Instead, it sets itself to 4032x3024. This mismatch is forbidden and causes v4l2 to give us EPIPE when we try to enable the stream. Using the lower resolution gets us further--the last command (which attempts to save a single frame of video) gives output like this:
VIDIOC_QUERYCAP: ok
		VIDIOC_REQBUFS returned 0 (Success)
		VIDIOC_QUERYBUF returned 0 (Success)
		VIDIOC_QBUF returned 0 (Success)
		VIDIOC_STREAMON returned 0 (Success)
But then it just hangs there indefinitely.
Running under strace, we see the program stuck in an ioctl:
ioctl(3, VIDIOC_DQBUF, {type=V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE
VIDIOC_DQBUF corresponds to dequeuing a buffer once it has been filled with an image by the v4l2 device. Apparently, the device never gives us back a captured frame.
Now what?
Does i2c work at all?
The camera driver uses i2c; we can see the camera in the .dts to determine that it's on i2c bus 1, address 0x1a.
The imx258 is controlled over i2c, and sends image data over MIPI. The first step is to see if the i2c control is working.
Looking back at the driver, it seems we should see errors in dmesg if i2c communication fails. The driver checks the chip id in its probe function, which uses i2c, so we can conclude that i2c gets set up properly initially. Does it keep working?
Does i2c keep working? (FTrace)
We can see if other functions that use i2c produce errors--for example, when we run our "v4l2-ctl" ... "--stream-mmap" command, we expect that imx258_start_streaming will get called, and this function also writes a load of registers over i2c.
Build and install a kernel with CONFIG_FTRACE (not hard, but outside the scope of this write-up) and enable function graph tracing:
$ sudo su
# cd /sys/kernel/debug/tracing
# echo function_graph > current_tracer
# cat available_filter_functions | grep -E 'rkisp|imx258|v4l2' | awk '{print $1}' > set_graph_function
# echo 'vm_map_pages,__iommu_map,iommu_map_sg_atomic,rk_iommu_map,__alloc_pages,dma_alloc_attrs,dma_mmap_attrs,__vm_map_pages,vb2_mmap,clk_e,able,schedule_timeout,clk_disable,regmap_write,schedule,__i2c_tra,sfer,i2c_tra,sfer_buffer_flags,dma_free_attrs' | tr , '\n' > set_graph_notrace
# tee trace_pipe > ~/function-trace.log
Now, in another terminal session, run the "v4l2-ctl" ... "--stream-mmap" command again. We end up with a bunch (but hopefully not *too* much) of output in our first terminal and the ~/function-trace.log file.
A quick grep shows that imx258_start_streaming is indeed called, so i2c is working properly.
If i2c works, what doesn't?
Our program that asks for a video frame is still hung! We ask the camera to start streaming frames, it presumably does, but the v4l2 stack never tells us a frame has finished. Doing some digging in the v4l2 stack (and the rkisp1 driver), we find out that rkisp1 is notified about frame status via interrupts.
Perhaps the hardware is never actually emitting the interrupt that signals a frame being finished. Indeed, grepping our FTrace log shows that rkisp1_isr is never called. A quick look at /proc/interrupts shows that the only interrupt associated with the isp has never triggered (0 count on every CPU):
# head -n1 /proc/interrupts; grep isp /proc/interrupts
           CPU0       CPU1       CPU2       CPU3       CPU4       CPU5
 57:          0          0          0          0          0          0     GICv3  75 Level     ff914000.iommu, rkisp1
rkisp1 debugfs info
The rkisp1 driver keeps some error/debug counters in debugfs, which can be viewed at /sys/kernel/debug/ff910000.isp0.
Sadly, the only one of these that comes up nonzero is sp_stop_timeout ("upon stream stop, the capture waits 1 second for the isr to stop the stream. This param is incremented in case of timeout"). I observe it to increment once per time I terminate the "v4l2-ctl" ... "--stream-mmap" command. This tells us what we already know: interrupts are not firing, but it also tells us that we aren't hitting any other errors that rkisp1 knows about.
Next steps
Where do we go from here? I don't know--something may be wrong with the way the .dts specifies interrupts, some kind of firmware/GIC (the rk3399's interrupt controller) configuration issue, or something else. It would be good to try to determine:
  • Whether the MIPI lines actually show traffic, if someone has a logic analyzer and a dissected PPP.
  • Whether the DMA of frames to memory actually happens, regardless of (lack of) emission of the interrupt that tells us when said DMA finishes a frame.
  • Whether the regulator messages we see during boot are actually significant. I don't know enough about the Linux regulator framework to say whether these being not-found means power is not correctly supplied, or if Linux just isn't being properly informed of the power supply requirements for precise tracking/power-saving when the camera is off.
Megi saves the day
[I] <megi> you might be interested in this https://megous.com/dl/tmp/0ae6ba03a17a3d53.png
[I] <megi> https://megous.com/git/linux/tag/?h=orange-pi-5.18-20220521-1759
Turns out, the .dts had the wrong ISP connected to the sensor!
Apply this commit (patch) to your kernel tree, rebuild, and reinstall. Now, the following should produce an image (frame.jpg):
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" '"imx258 1-001a":0 [fmt:SGRBG10_1X10/1048x780]'
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" '"rkisp1_isp":0 [fmt:SGRBG10_1X10/1048x780 crop:(0,0)/1048x780]'
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" '"rkisp1_isp":2 [fmt:YUYV8_2X8/1048x780 crop:(0,0)/1048x780]'
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" '"rkisp1_resizer_selfpath":0 [fmt:YUYV8_2X8/1048x780 crop:(0,0)/1048x780]'
"v4l2-ctl" "-z" "platform:rkisp1" "-d" "rkisp1_selfpath" "-v" "width=1048,height=780,pixelformat=422P"
"v4l2-ctl" "-z" "platform:rkisp1" "-d" "rkisp1_selfpath" "--stream-mmap" "--stream-count" "1" "--stream-to=frame.raw"
ffmpeg -y -s:v 1048x780 -pix_fmt yuv422p -i frame.raw frame.jpg
Similarly, you can take a photo from the front camera with the following:
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" "'m00_f_ov8858 1-0036':0 [fmt:SBGGR10_1X10/1632x1224]"
"media-ctl" "-d" "platform:rkisp1" "-l" "'m00_f_ov8858 1-0036':0 -> 'rkisp1_isp':0 [1]"
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" "'rkisp1_isp':0 [fmt:SBGGR10_1X10/1632x1224 crop:(0,0)/1632x1224]"
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" "'rkisp1_isp':2 [fmt:YUYV8_2X8/1632x1224 crop:(0,0)/1632x1224]"
"v4l2-ctl" "-z" "platform:rkisp1" "-d" "rkisp1_selfpath" "-v" "width=1632,height=1224,"
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" "'rkisp1_resizer_selfpath':0 [fmt:YUYV8_2X8/1632x1224 crop:(0,0)/1632x1224]"
"media-ctl" "-d" "platform:rkisp1" "--set-v4l2" "'rkisp1_resizer_selfpath':1 [fmt:YUYV8_2X8/1632x1224]"
"v4l2-ctl" "-z" "platform:rkisp1" "-d" "rkisp1_selfpath" "-v" "width=1632,height=1224,pixelformat=422P"
In some cases, the isp exposes 2 devices nodes, and the nodes have separate topologies with a different sensor attached to each. In this situation, you may need to reference the isp using the correct device node for the commands to work.
What's left?
  • libcamera and megapixels still don't work. Megapixels appears to need support for debayering YUYV, and both appear to be configuring the rkisp1 pipeline wrong.
  • The images captured are pretty green and seem to have two pixels of garbage at their bottom edge. rkisp1 supports auto white-balance (AWB) using the params/stats pads, and libcamera has some smarts that may hook these up properly. In the meantime, raw images can be postprocessed to improve white balance and exposure.
Useful links
