PinePhone Pro/Create a multi-distribution image using rk2aw
This article explains how to create a multi-distribution image on the PinePhone Pro using rk2aw.
Multi-distro on microSD Card
This article explains how to install megi's rk2aw loader, U-Boot to SPI and a multi-distribution image to the microSD card and/or eMMC of the PinePhone Pro. Further instructions regarding rk2aw can be found on megi's website under https://xff.cz/kernels/rk2aw/rk2aw-rk3399-pinephone-pro/INSTALL. Please note that loader and userspace utility to flash it are free, but not open-source.
Options to boot Arch Linux ARM, Manjaro, Mobian, PostmarketOS and Ubuntu Touch
Flash rk2Aw loader to SPI
Connect PinePhone Pro to a Linux machine, start a ssh connection and download installer to flash pre-loader to the phone's SPI.
ssh <user>@<phoneip>
cd ~/Downloads
curl -O https://xff.cz/kernels/bootloaders/ppp.tar.gz
tar -xvzf ppp.tar.gz -C ~/Downloads
# scp -r ~/Downloads/ppp <user>@<phoneip>:~/Downloads # copy to phone, non needed
sudo ./spinor-flash-initial-setup.sh
Build multi-distro on the microSD card
If necessary wipe the microSD card
sudo dd if=/dev/zero of=/dev/sdb count=1 bs=32768 status=progress # quick way i.e. # 32GB SDcard (30989615104bytes/32768dim=1volta)
sudo dd if=/dev/zero of=/dev/sdb count=945728 bs=32768 status=progress # slow way i.e. # 32GB SDcard (30989615104bytes/32768dim=945728volte)
sudo dd if=/dev/zero of=/dev/sdb count=15271040 bs=4096 status=progress # 63GB SDcard (62550179840bytes/512dim=122168320volte)
Partition the microSD card
Note: A minimum capacity of 64 GB for the microSD card is recommended for 5 distributions.
sudo sfdisk /dev/sdb --wipe always <<EOF
 label: gpt
 first-lba: 64
 table-length: 8
 start=64, size=32704, type=D7B1F817-AA75-2F4F-830D-84818A145370, name="loader", attrs=RequiredPartition
 size=11G, name="ALARM", attrs="RequiredPartition,LegacyBIOSBootable"
 size=11G, name="MANJARO", attrs="RequiredPartition,LegacyBIOSBootable"
 size=11G, name="MOBIAN", attrs="RequiredPartition,LegacyBIOSBootable"
 size=11G, name="PMOS", attrs="RequiredPartition,LegacyBIOSBootable"
 size=11G, name="UT", attrs="RequiredPartition,LegacyBIOSBootable"
 size=+, name="extra", attrs="RequiredPartition,LegacyBIOSBootable"
EOF
Checking that no-one is using this disk right now ... OK
Disk /dev/sdb: 58.25 GiB, 62550179840 bytes, 122168320 sectors
Disk model: SD Card Reader
Disklabel type: gpt
Disk identifier: C44BE2FC-34D6-4DD8-99FC-7FFB75602A79
Old situation:
>>> Script header accepted.
>>> Created a new GPT disklabel (GUID: F71BFBA6-D2C3-4C20-8079-1401B10C724C).
The maximal number of partitions is 8 (default is 128).
 /dev/sdb1: Created a new partition 1 of type 'unknown' and of size 16 MiB.
 /dev/sdb2: Created a new partition 2 of type 'Linux filesystem' and of size 11 GiB.
 /dev/sdb3: Created a new partition 3 of type 'Linux filesystem' and of size 11 GiB.
 /dev/sdb4: Created a new partition 4 of type 'Linux filesystem' and of size 11 GiB.
 /dev/sdb5: Created a new partition 5 of type 'Linux filesystem' and of size 11 GiB.
 /dev/sdb6: Created a new partition 6 of type 'Linux filesystem' and of size 11 GiB.
 /dev/sdb7: Created a new partition 7 of type 'Linux filesystem' and of size 3.2 GiB.
 /dev/sdb8: Done.
New situation:
Disklabel type: gpt
Disk identifier: F71BFBA6-D2C3-4C20-8079-1401B10C724C
Device         Start       End  Sectors  Size Type
 /dev/sdb1         64     32767    32704   16M unknown
 /dev/sdb2      32768  23101439 23068672   11G Linux filesystem
 /dev/sdb3   23101440  46170111 23068672   11G Linux filesystem
 /dev/sdb4   46170112  69238783 23068672   11G Linux filesystem
 /dev/sdb5   69238784  92307455 23068672   11G Linux filesystem
 /dev/sdb6   92307456 115376127 23068672   11G Linux filesystem
 /dev/sdb7  115376128 122167295  6791168  3.2G Linux filesystem
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Get image files of the distributions
Get the compressed distribution images from PinePhone Pro Software Releases, decompress them and mount both partitions "/boot", "/root" from each distro.
Change the directory to the Downloads folder.
cd ~/Downloads
Get images. Example releases (update the syntax to newer releases).
wget https://github.com/dreemurrs-embedded/Pine64-Arch/releases/download/20230203/archlinux-pinephone-pro-phosh-20230925.img.xz
wget https://github.com/manjaro-pinephone/phosh/releases/download/beta35/Manjaro-ARM-phosh-pinephonepro-beta35.img.xz
wget https://images.mobian.org/pinephonepro/weekly/mobian-pinephonepro-phosh-20231008.img.xz
wget https://images.postmarketos.org/bpo/v23.06/pine64-pinephonepro/phosh/20230904-0846/20230904-0846-postmarketOS-v23.06-phosh-22.2-pine64-pinephonepro.img.xz
wget https://ci.ubports.com/job/focal-hybris-rootfs-arm64/job/master/lastSuccessfulBuild/artifact/ubuntu-touch-pinephone-pro-img-arm64.raw.xz
Extract the compressed files:
xz -v -d -k archlinux-pinephone-pro-phosh-20230925.img.xz
xz -v -d -k Manjaro-ARM-phosh-pinephonepro-beta35.img.xz
xz -v -d -k mobian-pinephonepro-phosh-20231008.img.xz
xz -v -d -k 20230904-0846-postmarketOS-v23.06-phosh-22.2-pine64-pinephonepro.img.xz
xz -v -d -k ubuntu-touch-pinephone-pro-img-arm64.raw.xz
For PostMarketOS you can also use bootstrap to generate distro image. Make sure you install pmbootstrap before building images
git clone --depth=1 https://git.sr.ht/~postmarketos/pmbootstrap
mkdir -p ~/.local/bin
ln -s "$PWD/pmbootstrap/pmbootstrap.py" ~/.local/bin/pmbootstrap
source ~/.profile # remember to update your environment
pmbootstrap --version # If this returns error, put ~/.local/bin in your PATH, adding the following to your ~/.profile (zsh: ~/.zprofile).
# PATH="$HOME/.local/bin:$PATH" # optional
Create 2GB empty image file, format and mount it.
sudo dd if=/dev/zero of=postmarketOS-edge.img bs=1 count=0 seek=2G status=progress && sync
sudo mkfs.ext4 postmarketOS-edge.img
sudo su
losetup -P /dev/loop0 postmarketOS-edge.img
exit
Build PMOS image via pmbootstrap
pmbootstrap init # follow all the setup directions
pmbootstrap status
pmbootstrap pull
pmbootstrap install --sdcard=/dev/loop0
pmbootstrap shutdown # remember to deactivare chroot after the image creation
Build Arch Linux partition
Login as root, mount the image, copy rootfs and bootfs to the partition. You need also to make some changes on some files.
sudo su # login with your psw
losetup -P /dev/loop1 archlinux-pinephone-pro-phosh-20230925.img
mkdir /mnt/archlinux /mnt/archlinux/boot /mnt/archlinux/root /mnt/archlinuxsd
mount /dev/loop1p1 /mnt/archlinux/boot/ && mount /dev/loop1p2 /mnt/archlinux/root/
exit
sudo dd if=/dev/loop1p2 of=/dev/sdb2 bs=1M status=progress conv=fsync
sudo mount /dev/sdb2 /mnt/archlinuxsd/
sudo scp -r /mnt/archlinux/boot/* /mnt/archlinuxsd/boot
sudo mv /mnt/archlinuxsd/boot/boot.scr /mnt/archlinuxsd/boot/boot.scrORIG
sudo mkdir /mnt/archlinuxsd/boot/extlinux
sudo su
cat << EOF > /mnt/archlinuxsd/boot/extlinux/extlinux.conf
#/boot/extlinux/extlinux.conf
MENU TITLE Pinephone Pro Boot Menu
LABEL l0
MENU LABEL ALARM
FDT /boot/dtbs/rockchip/rk3399-pinephone-pro.dtb
KERNEL /boot/Image.gz
INITRD /boot/initramfs-linux.img
APPEND root=PARTLABEL=ALARM console=ttyS2,115200 console=tty0 loglevel=4 rw rootwait
EOF
cat << EOF > /mnt/archlinuxsd/etc/fstab
# <file system> <dir> <type> <options> <dump> <pass>
PARTLABEL=ALARM	/         	ext4      	rw,relatime	0 1
EOF
exit
Build Manjaro partition
losetup -P /dev/loop2 Manjaro-ARM-phosh-pinephonepro-beta35.img
mkdir /mnt/manjaro /mnt/manjaro/boot /mnt/manjaro/root /mnt/manjarosd
mount /dev/loop2p1 /mnt/manjaro/boot/ && mount /dev/loop2p2 /mnt/manjaro/root/
exit
sudo dd if=/dev/loop2p2 of=/dev/sdb3 bs=1M status=progress conv=fsync
sudo mount /dev/sdb3 /mnt/manjarosd/
sudo scp -r /mnt/manjaro/boot/* /mnt/manjarosd/boot
sudo mv /mnt/manjarosd/boot/boot.scr /mnt/manjarosd/boot/boot.scrORIG
sudo mkdir /mnt/manjarosd/boot/extlinux
sudo su
cat << EOF > /mnt/manjarosd/boot/extlinux/extlinux.conf
LABEL l0
MENU LABEL MANJARO
KERNEL /boot/Image
APPEND root=PARTLABEL=MANJARO console=ttyS2,115200 console=tty0 loglevel=4 rw rootwait
EOF
cat << EOF > /mnt/manjarosd/etc/fstab
PARTLABEL=MANJARO   /   ext4     defaults    0   1
EOF
exit
Build Mobian partition
losetup -P /dev/loop3 mobian-pinephonepro-phosh-20231008.img
mkdir /mnt/mobian /mnt/mobian/boot /mnt/mobian/root /mnt/mobiansd
mount /dev/loop3p1 /mnt/mobian/boot/ && mount /dev/loop3p2 /mnt/mobian/root/
exit
sudo dd if=/dev/loop3p2 of=/dev/sdb4 bs=1M status=progress conv=fsync
sudo mount /dev/sdb4 /mnt/mobiansd/
sudo scp -r /mnt/mobian/boot/* /mnt/mobiansd/boot
sudo su
cat << EOF > /mnt/mobiansd/etc/fstab
PARTLABEL=MOBIAN	/	ext4	defaults,x-systemd.growfs	0	1
EOF
exit
sudo nano /mnt/mobiansd/boot/extlinux/extlinux.conf
 >adjust ## /boot/extlinux/extlinux.conf file
 >MENU LABEL MOBIAN
 >linux /boot/vmlinuz-6.1-rockchip
 >initrd /boot/initrd.img-6.1-rockchip
 >fdtdir /boot/dtb-6.1-rockchip/
 >APPEND root=PARTLABEL=MOBIAN console=ttyS2,115200 console=tty0 loglevel=4 rw rootwait
Build PostmarketOS partition
losetup -P /dev/loop4 postmarketOS-edge.img
mkdir /mnt/postmarketos /mnt/postmarketos/boot /mnt/postmarketos/root /mnt/postmarketossd
mount /dev/loop4p1 /mnt/postmarketos/boot/ && mount /dev/loop4p2 /mnt/postmarketos/root/
exit
sudo dd if=/dev/loop4p2 of=/dev/sdb5 bs=1M status=progress conv=fsync
sudo mount /dev/sdb5 /mnt/postmarketossd/
sudo scp -r /mnt/postmarketos/boot/* /mnt/postmarketossd/boot
sudo mkdir /mnt/postmarketossd/boot/extlinux
sudo su
cat << EOF > /mnt/postmarketossd/boot/extlinux/extlinux.conf
default l0
menu title U-Boot menu
prompt 0
timeout 10
label l0
 menu label PMOS
 linux /boot/vmlinuz
 initrd /boot/initramfs-extra
 fdtdir /boot/dtbs-pine64-pinephonepro/
APPEND root=PARTLABEL=PMOS console=ttyS2,115200 console=tty0 loglevel=4 rw rootwait
EOF
cat << EOF > /mnt/postmarketossd/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
PARTLABEL=PMOS / ext4 defaults 0 0
EOF
exit
Build Ubuntu Touch partition
losetup -P /dev/loop5 ubuntu-touch-pinephone-pro-img-arm64.raw
mkdir /mnt/ubuntutouch /mnt/ubuntutouch/boot /mnt/ubuntutouch/root /mnt/ubuntutouchsd
mount /dev/loop5p2 /mnt/ubuntutouch/boot/ && mount /dev/loop5p3 /mnt/ubuntutouch/root/
exit
sudo dd if=/dev/loop5p3 of=/dev/sdb6 bs=1M status=progress conv=fsync
sudo mount /dev/sdb6 /mnt/ubuntutouchsd/
sudo scp -r /mnt/ubuntutouch/boot/* /mnt/ubuntutouchsd/boot
sudo su
cat << EOF > /mnt/ubuntutouchsd/etc/fstab
PARTLABEL=UT	/	ext4	defaults	0	1
EOF
cat << EOF > /mnt/ubuntutouchsd/boot/extlinux/extlinux.conf
default l0
prompt 0
timeout 50
label l0
       menu label UT
       linux /boot/vmlinuz-6.5.0-okpine-ut
       initrd /boot/initrd.img-6.5.0-okpine-ut
       fdtdir /boot/dtb-6.5.0-okpine-ut/
APPEND root=PARTLABEL=UT console=ttyS2,115200 console=tty0 loglevel=4 rw rootwait
EOF
exit
Unmount and detach all images
sudo umount /mnt/*/*
sudo umount /media/*/*
sudo rm -r /mnt/*
sudo rm -r /media/*/*
sudo su
losetup -D
exit
Multi-distro on eMMC
Options to boot Phosh or sxmo
Make sure you boot from the microSD card in your PinePhone Pro as we are going to overwrite the eMMC. Note that below, Arch is booted from the microSD card and the microSD card is listed as the device /dev/mmcblk1.
Same as above. Note this installs rk2aw and a bootloader to SPI NOR flash. Resulting SPI status is as follow:
# ./rk2aw-spi-flasher
Machine: Pine64 PinePhonePro (pine64,pinephone-pro)
SPI NOR Flash:
- Total size: 16384 KiB
- Erase block size: 4 KiB
- Write size: 1
- Manufacturer: gigadevice
- Part name: gd25lq128e
- JEDEC ID: 257018
Bootable images currently present in SPI NOR flash:
Idx Header     Off 1      Size 1     Off 2      Size 2     Notes/content
0   0          2048       6144       0          0          (padded) 0='rk2aw'
5   131072     133120     67584      200704     124928     0='U-Boot TPL' 1='U-Boot SPL'
7   524288     526336     147456     673792     124928     0='ddrbin' 1='U-Boot SPL'
Auto-calculated layout for rk2aw dual bootloader scheme:
Area                 Offset     Size
rk2aw primary        0          65536
rk2aw backup         65536      65536
spl fallback         131072     393216
spl primary          524288     389120
itb fallback         913408     2097152
itb primary          3010560    2097152
Build multi-distro eMMC
In this example we are going to build 2 partitions on the eMMC, the first with Arch/Phosh and the second with Arch/sxmo. We have already downloaded the images from Danct12 and decompressed them.
Mount the images
cd ~/Downloads # enter to directory
losetup -P /dev/loop0 archlinux-pinephone-pro-phosh-20230203.img
losetup -P /dev/loop1 archlinux-pinephone-pro-sxmo-20230203.img
ls -l /mnt/
mkdir /mnt/phosh
mkdir /mnt/sxmo
mkdir /mnt/phosh/boot
mkdir /mnt/phosh/root
mkdir /mnt/sxmo/boot
mkdir /mnt/sxmo/root
mkdir /mnt/ephosh # e for the partition on the eMMC
mkdir /mnt/esxmo  # e for the partition on the eMMC
mount /dev/loop0p1 /mnt/phosh/boot/
mount /dev/loop0p2 /mnt/phosh/root/
mount /dev/loop1p1 /mnt/sxmo/boot/
mount /dev/loop1p2 /mnt/sxmo/root/
lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0          7:0    0     5G  0 loop
├─loop0p1    259:0    0   122M  0 part /mnt/phosh/boot
└─loop0p2    259:1    0   4.9G  0 part /mnt/phosh/root
loop1          7:1    0   3.5G  0 loop
├─loop1p1    259:2    0   122M  0 part /mnt/sxmo/boot
└─loop1p2    259:3    0   3.4G  0 part /mnt/sxmo/root
mmcblk2      179:0    0 115.2G  0 disk
├─mmcblk2p1  179:1    0   122M  0 part
└─mmcblk2p2  179:2    0 115.1G  0 part
mmcblk2boot0 179:32   0     4M  1 disk
mmcblk2boot1 179:64   0     4M  1 disk
mmcblk1      179:96   0  59.6G  0 disk
├─mmcblk1p1  179:97   0   122M  0 part /boot
└─mmcblk1p2  179:98   0  59.5G  0 part /
zram0        254:0    0   1.5G  0 disk [SWAP]
Prepare eMMC
dd if=/dev/zero of=/dev/mmcblk2 count=32768 bs=32768 status=progress # overwrite the front to clear any bootloaders
sfdisk /dev/mmcblk2 << EOF
label: gpt
first-lba: 64
table-length: 8
size=32G, name="PHOSH", attrs="RequiredPartition,LegacyBIOSBootable"
size=+, name="SXMO", attrs="RequiredPartition,LegacyBIOSBootable"
EOF
Disk /dev/mmcblk2: 115.23 GiB, 123731968000 bytes, 241664000 sectors
>>> Created a new GPT disklabel (GUID: 7EB4B1E0-5F49-4F30-9F1E-E9E1F305D461).
/dev/mmcblk2p1: Created a new partition 1 of type 'Linux filesystem' and of size 32 GiB.
/dev/mmcblk2p2: Created a new partition 2 of type 'Linux filesystem' and of size 83.2 GiB.
/dev/mmcblk2p3: Done.
New situation:
Disklabel type: gpt
Disk identifier: 7EB4B1E0-5F49-4F30-9F1E-E9E1F305D461
/dev/mmcblk2p1     2048  67110911  67108864   32G Linux filesystem
/dev/mmcblk2p2 67110912 241661951 174551040 83.2G Linux filesystem
Syncing disks.
lsblk
 ├─mmcblk2p1  179:1    0    32G  0 part
 └─mmcblk2p2  179:2    0  83.2G  0 part
Build Phosh partition
dd if=/dev/loop0p2 of=/dev/mmcblk2p1 bs=1M status=progress conv=fsync
mount /dev/mmcblk2p1 /mnt/ephosh/
scp -r /mnt/phosh/boot/* /mnt/ephosh/boot
mv /mnt/ephosh/boot/boot.scr /mnt/ephosh/boot/boot.scrORIG
cat << EOF > /mnt/ephosh/etc/fstab
 #Static information about the filesystems.
 #See fstab(5) for details.
 #<file system> <dir> <type> <options> <dump> <pass>
 PARTLABEL=PHOSH 	/   ext4   rw,relatime	0 1
 # UUID=52CA-6165  /boot vf rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro	0 2
mkdir /mnt/ephosh/boot/extlinux
cat << EOF > /mnt/ephosh/boot/extlinux/extlinux.conf
 LABEL l0
 MENU LABEL phosh
 KERNEL /boot/Image
 APPEND root=PARTLABEL=PHOSH console=ttyS2,115200 console=tty0 loglevel=4 rw rootwait
 EOF
Build SXMO partition
We have unmounted all the Phosh devices, so
lsblk
dd if=/dev/loop1p2 of=/dev/mmcblk2p2 bs=1M status=progress conv=fsync
mount /dev/mmcblk2p2 /mnt/esxmo/
scp -r /mnt/sxmo/boot/* /mnt/esxmo/boot
mv /mnt/esxmo/boot/boot.scr /mnt/esxmo/boot/boot.scrORIG
cat << EOF > /mnt/esxmo/etc/fstab
# Static information about the filesystems.
# See fstab(5) for details.
PARTLABEL=SXMO /     ext4      	rw,relatime	0 1
# UUID=841C-F9DD      	/boot     	vfat      	rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro	0 2
EOF
mkdir /mnt/esxmo/boot/extlinux
cat << EOF > /mnt/esxmo/boot/extlinux/extlinux.conf
 LABEL l0
 MENU LABEL sxmo
 KERNEL /boot/Image
 APPEND root=PARTLABEL=SXMO console=ttyS2,115200 console=tty0 loglevel=4 rw rootwait
EOF
Follow-up comments
  1. On first boot neither Phosh nor sxmo resized their partition - sudo resize2fs sorted that.
  2. Any time an update rebuilds the initramfs it is necessary to delete /boot/boot.scr again to keep the rk2aw menu clean.
