PinePhone Pro
Revision as of 22:47, 27 January 2022 by Fxc (talk | contribs) (Removed formatting -> consistency)
Rendering of the PinePhone Pro
The PinePhone Pro is PINE64's flagship smartphone announced on October 15, 2021. It features 4GB of RAM, an 128GB eMMC and is using an Rockchip RK3399S SoC, which is a specialized version of the RK3399 made specifically for the PinePhone Pro.
Introduction
The PinePhone Pro is PINE64’s second smartphone and a successor to the original PinePhone. It does not, however, replace the original PinePhone. It should also not be considered a second generation PinePhone; it is a higher-end device, with much better specs, aimed at those who wish to daily-drive a open system stack. Achieving this goal will, however, take time as the software and overall smartphone software ecosystem needs to mature.
More information about the PinePhone Pro can be found on the device main page.
State of the software
Presently, at the time of writing (late 2021), the PinePhone Pro is aimed solely at early adopters and developers. It will take time for all the PinePhone Pro’s functionality to reach software parity with the original PinePhone and for mobile operating systems, in more general, to reach a higher degree of maturity.
Bear in mind that the software for these smartphones is still in a very early stage, with most of the software being in alpha or beta state. That's especially also the case for scalability of applications, their availability and practicability, any hardware function implementations and the firmware. The software is provided as is. There is no warranty for the software, not even for merchantability or fitness for a particular purpose.
Editions and revisions
Similarly to the original PinePhone, various PinePhone Pro editions are planned, the first of which is the Developer Edition (aimed at developers, as the name entails) followed by the Explorer Edition, which is aimed at early adopters.
Help and support
Still have any questions regarding software, shipping, or ordering after reading this Wiki? Please don't hesitate to contact the community in the bridged community channels for detailed answers or simply to chat with friendly people in the community! See Main Page#Community and Support.
Please keep in mind that PINE64 is not like a regular company (see PINE64 philosophy), and currently that support resources are sparse - the best way to get support quickly is to ask in the community chat! Please only contact PINE64 directly if questions couldn't be solved via the community chat or this wiki.
First time setup
Do not insert an empty micro SIM adapter into the phone, as it will get stuck on the contact pins.
When shipped the battery is isolated from the mainboard contacts using a protective plastic tab, which is required to be removed before using the phone. The battery will not charge until it is removed and some of the device’s functionality may not function properly.
The PinePhone Pro's SIM slot only accepts a micro SIM, please do not insert a nano SIM without an adapter. The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot. Notice: Do not insert an empty micro SIM adapter into the phone, as it will get stuck on the contact pins. An adapter from a nano to a micro SIM is included in the box.
  1. Carefully remove the back panel using the notch in the corner of the back cover without overbending it
  2. Remove the battery (if the battery is stuck in the device please check this paragraph for a fix)
  4. Reinsert the battery
Software
At the time of the release, in late 2021, the PinePhone Pro is in an early development stage. That said, the device has benefited greatly from work done on the original PinePhone, which means that even early development images feature all core functionality, such as: functional UI, sensors and even the modem (to a degree).
The development is expected to proceed very quickly compared to progress done on the original PinePhone as much of the fundamental work can carry over to the new device. You can follow development efforts on Megi's blog, the dedicated PinePhone Pro Development section as well as on individual project’s Wiki’s and repositories.
Boot order
On the PinePhone Pro the eMMC (the internal storage of the phone) has a higher boot priority than the microSD card (see RK3399 boot sequence#Boot sequence details for details regarding the boot sequence). That behavior is in contrast to the original PinePhone with the Allwinner A64 SoC, where the microSD card has a higher boot priority.
The Explorer Edition comes with a modified U-Boot pointing to the microSD card pre-installed to the eMMC. The microSD card can be (temporarily) booted instead of the pre-installed operating system, when the power key is shortly held at boot. To always boot from the microSD card it is recommended to wipe U-Boot from the eMMC. When the pre-installed bootloader was overwritten with a bootloader without such a configuration, the reset button underneath the back cover of the phone can also be used to temporarily bypass the eMMC, the button may however only be pressed shortly during boot.
The Developer Edition, which was an earlier revision intended for development, was coming with an Android factory OS preinstalled. For details regarding how to remove the bootloader and the preinstalled OS of the eMMC for Developer Edition, please see the relevant wiki article.
Installation instructions
It is strongly recommended you perform all testing from a microSD card, leaving the eMMC vacant. Please ask in the community chat if you have any questions regarding the installation.
This page is under construction
Please help to review and edit this page or paragraph. Information are subject to change.
Software releases
The PinePhone Pro Software Releases page has a complete list of currently supported phone-optimized operating system images that work with the PinePhone Pro.
Specifications
  • Dimensions: 160.8 x 76.6 x 11.1mm
  • Weight: Approx. 220g
  • SIM Card: Micro-SIM
  • Display:
    • Size: 6 inches (151mm) diagonal
    • Type: 1440 x 720 in-cell IPS with Gorilla Glass 4™
  • System on Chip: Rockchip RK3399S 64bit SoC – 2x A72 and 4x A53 CPU cores @ 1.5GHz
  • RAM: 4GB LPDDR4 @ 800MHz
  • Internal Storage: 128GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
  • Back Camera: 13MP Sony IMX258 with Gorilla Glass 4™ protective layer, LED Flash
  • Front Camera: 8MP, OmniVision OV8858 front-facing camera
  • Sound: Loudspeaker, 3.5mm jack & mic (jack doubles as hardware UART if hardware switch 6 is deactivated)
  • Communication:
    • Modem: Quectel EG25-G
    • LTE-TDD: B38, B39, B40, B41
    • WLAN & Bluetooth: AMPAK AP6255 WiFi 11ac + Bluetooth V4.1
  • Privacy switches: Modem, WiFi & Bluetooth, Microphone, Cameras
Privacy switch configuration
Detail of DIP switch
Number Name Description
1 Modem "On" enables 2G/3G/4G communication and GNSS hardware, "off" disables it.
2 WiFi / Bluetooth "On" enables WiFi and Bluetooth communication hardware, "off" disables it.
3 Microphone "On" enables audio input from on-board microphones (not 3.5 mm jack), "off" disables it.
4 Rear camera "On" enables the rear camera, "off" disables it.
5 Front camera "On" enables the front camera, "off" disables it.
6 Headphone "On" enables audio input and output via the 3.5 mm audio jack, "off" switches the jack to hardware UART¹ mode.
¹ Note: The baud rate may be 1500000 instead of 115200.
Components
Component Model
Touchscreen
Rear camera IMX258
Camera flash AW3641EDNR
Front camera OV8858
LCD
WiFi + Bluetooth AzureWave AW-CM256SM
Modem Quectel EG25-G
GNSS/GPS Quectel EG25-G
3 Axis Magnetometer ST LIS3MDL
Geo Magnetic Sensor Voltafield AF8133J
Ambient light / Proximity STK3311-A
Accelerometer / Gyroscope TDK MPU-6500
Vibration motor
Notification LED
Audio Codec ALC5616 and ALC5640
Power button
Battery fuel gauge RK818
Datasheets, schematics and certifications
  • PinePhone Pro USB-C small board schematic:
    • TBD
Press
For an overview about media of the PinePhone Pro you can use for the news, blogs, or similar see PinePhone Pro Press.
External links
