PinePhone Pro
Revision as of 18:55, 16 October 2021 by CCF100 (talk | contribs) (Change to exact date)
Rendering of the PinePhone Pro
The PinePhone Pro is PINE64's flagship smartphone announced on October 15, 2021. It features 4GB of RAM, an 128GB eMMC and is using an Rockchip RK3399S SoC.
Introduction
Specifications
  • Dimensions: 160.8 x 76.6 x 11.1mm
  • Weight: Approx. 215g
  • SIM Card: ?Micro-SIM?
  • Display:
    • Size: 6 inches (151mm) diagonal
    • Type: 1440 x 720 in-cell IPS with Gorilla Glass 4™
  • System on Chip: Rockchip RK3399S 64bit SoC – 2x A72 and 4x A53 CPU cores @ 1.5GHz
  • RAM: 4GB LPDDR4 @ 800MHz
  • Internal Storage: 128GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
  • Back Camera: 13MP Sony IMX258 with Gorilla Glass 4™ protective layer, LED Flash
  • Front Camera: 5MP OmniVision OV5640 front-facing camera
  • Sound: Loudspeaker, 3.5mm jack & mic (jack doubles as hardware UART if hardware switch 6 is deactivated)
  • Communication:
    • Modem: Quectel EG25-G
    • LTE-TDD: B38, B39, B40, B41
    • WLAN & Bluetooth: AMPAK AP6255 WiFi 11ac + Bluetooth V4.1
  • Privacy switches: Modem, WiFi & Bluetooth, Microphone, Cameras
Components
Press
For an overview about media of the PinePhone Pro you can use for the news, blogs, or similar see PinePhone Pro Press.
Developer works
  • Megi's blog post about the device
External links
