PinePhone Pro
Revision as of 15:47, 15 October 2021 by Abcde (talk | contribs) (initial specs and some base info)
The PinePhone Pro is an upgraded PinePhone. On 15 October 2021 Pine64 announced a successor to the PinePhone. It has 4 GB RAM and 128 GB eMMC, and has a hexa-core RK3399S processor. The RK3399S is a special version of the RK3399 made specifically for the PinePhone Pro.
Introduction
Links to information
Specifications
  • Dimensions: 160.8 x 76.6 x 11.1mm
  • Weight: Approx. 215g
  • SIM Card: ?Micro-SIM?
  • Display:
    • Size: 6 inches (151mm) diagonal
    • Type: 1440 x 720 in-cell IPS with Gorilla Glass 4™
  • System on Chip: Rockchip RK3399S 64bit SoC – 2x A72 and 4x A53 CPU cores @ 1.5GHz
  • RAM: 4GB LPDDR4 @ 800MHz
  • Internal Storage: 128GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
  • Back Camera: 13MP Sony IMX258 with Gorilla Glass 4™ protective layer, LED Flash
  • Front Camera: 5MP OmniVision OV5640 front-facing camera
  • Sound: Loudspeaker, 3.5mm jack & mic (jack doubles as hardware UART if hardware switch 6 is deactivated)
  • Communication:
    • Modem: Quectel EG25-G
    • LTE-TDD: B38, B39, B40, B41
    • WLAN & Bluetooth: AMPAK AP6255 WiFi 11ac + Bluetooth V4.1
  • Privacy switches: Modem, WiFi & Bluetooth, Microphone, Cameras
Components
Press
Developer works
