PinePhone Power Management
The data on this page is based on the the PinePhone v1.1 - Braveheart.
Regulators
Current Assignments
Name/GPIO Output Voltage Can disable at runtime? Can disable in suspend? Consumers (internal/external separated by semicolon)
DCDC1 3.3V No No (VCC-IO) VCC-EFUSE, VCC-IO, VCC-PC (VQMMC2), VCC-PD, VCC-USB; Modem [I2C, PCM, UART], Motor, Pogo I2C, UART0, VMMC0, VMMC2, WiFi CHIP_EN
DCDC2 DVFS No Yes VDD-CPUX
DCDC3 DVFS N/A N/A VDD-CPUX (polyphase with DCDC2)
DCDC4 N/A Yes Yes Not used
DCDC5 1.2V No Yes (future) VCC-DRAM; DRAM
DCDC6 1.1V No Yes (future) VDD-SYS
DC1SW N/A Yes Yes Not used
ALDO1 2.8V Yes Yes VCC-PE; Camera AFVCC, Camera DOVDD, CSI I2C, Pogo I2C
ALDO2 1.8V No No (VCC-PL) VCC-PL; Pogo INT
ALDO3 3.0V No No (KEYADC) AVCC, KEYADC, VCC-PLL
DLDO1 3.3V No No (ANX7688 AVDD33) HVCC, VCC-DSI; ANX7688 [AVDD33, HDMI_VT, I2C, ANX-V1.0 Enable, VCONN_EN Disable Pull-up], HDMI [DDC, HPD], Proximity LED, Sensor I2C, Sensor VDD
DLDO2 1.8V? 3.3V? Yes Yes MIPI-DSI VIO
DLDO3 2.8V Yes Yes Camera AVDD
DLDO4 1.8V-3.3V Yes Yes VCC-PG; VQMMC1
ELDO1 1.8V No No (DRAM) CPVDD; DRAM
ELDO2 N/A Yes Yes Not used
ELDO3 1.8V Yes Yes Camera DVDD
FLDO1 1.2V Yes Yes HSIC-VCC (not used)
FLDO2 1.1V No No (VDD-CPUS) VDD-CPUS
GPIO0-LDO 3.3V Yes Yes Backlight PWM, LCD, Proximity sensor VDD, Touchscreen [I2C, VCC]
GPIO1-LDO 1.8V No No (ANX7688 DVDD1V8) ANX7688 [AVDD1V8, DVDD1V8, CC, HDMI DDC, I2C, Power/Reset pull-up]
PD6 5.0V Yes Yes USB OTG
PD8 5.0V Yes Yes Pogo supply, USB OTG via PD6
PD9 5.0V Yes Yes VCONN (USB Type C)
PH10 PWM Yes Yes Backlight
PL7 VBAT Yes Yes Modem
ANX-V1.0 1.0V Yes Yes ANX7688 [AVDD1V0, DVDD1V0]
Suggested Hardware Changes
ANX7688
  1. Move ANX7688 AVDD33 (the chip input only, not the other things connected to 3v3) and ANX7688 I2C Level Shift (3.3V side) from DLD01 to DCDC1
  2. Move ANX7688 DVDD1V8 (the chip input only, not the other things labeled DVDD1V8) from GPIO1-LDO to ALDO2
  3. Move ANX7688 ANX-V1.0 Regulator Enable and ANX7688 VCONN_EN Disable Pull-up from DLDO1 to GPIO1-LDO
The result of these changes would be that:
  1. The always-on part of the ANX7688 chip (AVDD33, DVDD1V8) will always be powered
  2. GPIO1-LDO only needs to be powered when a USB cable is detected, and is enough to power the rest of the chip (except HDMI)
  3. DLDO1 only needs to be enabled if the display pipeline or sensors are active, even if a USB cable is plugged in
Sensors
  1. Swap the VDD and LEDA inputs of the STK3311-A sensor, moving VDD to DLDO1 and LEDA to GPIO0-LDO. The sensor VDD needs to match the I2C voltage, and the LED driver should be on a separate power supply from the sensors. There is some concern, because GPIO0-LDO has a 100mA limit, but the proximity sensor should work properly at the lowest LED drive current (12.5mA).
Assignments after Suggested Changes
Note: Only regulators that were modified are included here.
DCDC1 3.3V No No (VCC-IO) VCC-EFUSE, VCC-IO, VCC-PC (VQMMC2), VCC-PD, VCC-USB; ANX7688 [AVDD33, I2C], Modem [I2C, PCM, UART], Motor, Pogo I2C, UART0, VMMC0, VMMC2, WiFi CHIP_EN
ALDO2 1.8V No No (VCC-PL) VCC-PL; ANX7688 [DVDD1V8], Pogo INT
DLDO1 3.3V Yes Yes HVCC, VCC-DSI; ANX7688 [HDMI_VT], HDMI [DDC, HPD], Proximity sensor VDD, Sensor I2C, Sensor VDD
GPIO0-LDO 3.3V Yes Yes Backlight PWM, LCD, Proximity LED, Touchscreen [I2C, VCC]
GPIO1-LDO 1.8V Yes Yes ANX7688 [ANX-V1.0 Enable, AVDD1V8, CC, HDMI DDC, I2C, Power/Reset pull-up, VCONN_EN Disable Pull-up]
Open Questions
  • How is ANX1.8V actually powered? from GPIO1-LDO or PS or both?
  • Is DLDO2 supposed to be 1.8V or 3.3V? The schematic says both in different places.
  • If DLDO2 is 3.3V, can we spread the HDMI/DSI/Sensors better across DLDO1 and DLDO2 so they can be more independent?
Software Updates Needed
Drivers that Need Regulator Consumers
  • LCD Panel for VCC-LCD
  • MIPI-DSI/DPHY/Panel for MIPI-DSI VIO
  • STK3311-A
Drivers that Need to Suspend Regulators
  • STK3311-A
  • LIS3MDL
  • MPU6050
  • Goodix touchscreen
  • sunxi pinctrl (maybe)
  • USB PHY
GPIO
Current Modem Pin Assignments
Note: only pins relevant to power management are included in this table.
Pin Signal Name Description Direction (as modem) Needed in suspend? Connected to
1 WAKEUP_IN Drive low to wake up the modem I No PH7 (active high)
2 AP_READY Drive high/low to signal the A64 is ready to receive URCs I No (if held) NC
4 W_DISABLE# Drive low to enter Airplane Mode I No (if held/tristate) PH8 (active high)
20 RESET_N Drive low to reset the modem I No (if held/tristate) PC4 (active high)
21 PWRKEY Drive low to turn the modem on/off I No (if held/tristate) PB3 (active high)
61 STATUS Open drain output, pulled low when the modem is on O No PB3
62 RI Pulled low to request host wakeup O Yes PB2
66 DTR Drive low to wake up the modem I No PL6 (active low)
Current Port L Pin Assignments
Pin Signal Name Description Direction Needed in suspend?
PL0 PMU-SCK AXP803 I2C/RSB Clock O Yes
PL1 PMU-SDA AXP803 I2C/RSB Data I/O Yes
PL2 WL-REG-ON Not Connected N/A N/A
PL3 WL-WAKE-AP Wake-on-WLAN Interrupt I Yes
PL4 BT-RST-N Bluetooth Reset Control O No (if held)
PL5 BT-WAKE-AP Wake-on-BT Interrupt I Yes
PL6 DTR Modem DTR (Wakeup Request) O No
PL7 4G-PWR-BAT Modem Power Supply Control O No (if held)
PL8 ANX7688-CABLE_DET ANX7688 Cable Detection Interrupt I Yes
PL9 ANX_RESET ANX7688 Reset Control O No (if held)
PL10 LCD-PWM LCD Backlight PWM Brightness Control O No
PL11 ANX7688-INT ANX7688 Alert Interrupt I Yes
PL12 POGO-INT Pogo Pin Interrupt I Yes
Pins Held During Suspend
Pins Active During Suspend
  1. Connect WL-REG-ON (PL2) and WL-PMU-EN (WiFi).
  2. Connect the LIS3MDL DRDY pin, not INT pin, to PB1
  3. Reconnect LINEOUTN to make the line output differential.
  4. Replace WAKEUP_IN with AP_READY at PH8.
  5. Swap DTR (PL6, no level shift) and RI (PB2, level shift).
  6. Connect the modem PWRKEY to PB3 only, not STATUS or DCDC1 (depopulate R1526).
  7. Connect the modem STATUS to a GPIO input.
  8. Disconnect the modem I2C. The level shifter can be repurposed for the next change.
  9. Connect the modem debug UART TX/RX to PD0-1.
  10. Move the modem main UART TX/RX to PD2-3. Motor and CSI reset that are currently at PD2-3 would need to be moved elsewhere.
  11. Connect both AXP803 USB-DRVVBUS (populate R1300) and ANX7688 VBUS_CTRL to DRVVBUS (in addition to PD6). The signal would be driven by either PD6 or the ANX7688. If this is not possible, then prefer to at least connect AXP803 USB-DRVVBUS.
  12. Reorient the transistors for ANX_POWER (PD10) and ANX_RESET (PL9) so they do not invert their input, and produce a low-level output by default.
  13. Remove the transistors inverting VCONN1_EN and VCONN2_EN, and use a pull-up to DVDD1V8 instead of the pull-up to 3V3.
Open Questions
  • What exactly is the modem PWRKEY currently connected to? PB3? STATUS? DCDC1?
