PinePhone MMS with Matrix
Revision as of 06:39, 29 September 2021 by Silver (talk | contribs)
Screenshot of fractal displaying an MMS conversation
The one known way to get MMS fully (meaning pictures and group messages) working is by relaying all SMS and MMS to a matrix server and using a matrix client to interact with them. https://gitlab.com/untidylamp/mmmpuppet is the bridge used here
Outgoing messages over the max size are sent as a link. The link will not resolve if matrix is hosted on the PinePhone itself, so resize your images. An easy way might be to take a screenshot of your image viewer and send that image instead.
This works method with a local-to-the-pinephone matrix server but you could instead use a public one on the internet. Free accounts on matrix.org should work fine for example. Sleep may need to be disabled for non-local servers or the bridge can get stuck.
Install packages
Arch
Start with a nice and up-to-date Danctnix' Arch ARM PinePhone installation, mine is from April 20 2021. SSH into the PinePhone and then run this to install all the needed packages
sudo pacman -Sy matrix-synapse fractal python-matrix_client python-gobject git meson ninja base-devel python-matrix-nio python-dbus
Start the service
sudo systemctl enable synapse
sudo systemctl start synapse
Mobian
Flash a fresh mobian nightly (Tested September 28 2021) and install the following:
sudo apt install matrix-synapse fractal mmsd-tng python3-matrix-nio python3-vobject python3-aiofiles git
Set up Matrix Synapse on localhost
Skip this if you will be using a remote homeserver. Make a new config with the server name set to local host.
Arch
cd /etc/synapse/
sudo python -m synapse.app.homeserver --server-name localhost --config-path homeserver.yaml --generate-config --report-stats=no
sudo vi /usr/lib/systemd/user/matrix-synapse.service
[Unit]
Description=Multimedia Messaging Service Daemon
After=ModemManager.service
[Service]
ExecStart= python3 -m synapse.app.homeserver --config-path=/etc/matrix/homeserver.yaml
Restart=on-failure
RestartSec=10s
[Install]
WantedBy=default.target
Start the service
systemctl enable matrix-synapse --user
systemctl start matrix-synapse --user
mobian
cd /etc/matrix-synapse/
sudo rm homeserver.*
sudo python3 -m synapse.app.homeserver --server-name localhost --config-path homeserver.yaml --generate-config --report-stats=no
sudo service matrix-synapse start
register_new_matrix_user -c homeserver.yaml http://localhost:8008
and add a new user.
in /etc/synapse/ (arch) or /etc/matrix-synapse/ (mobian)
register_new_matrix_user -c homeserver.yaml http://localhost:8008 # New user name and pw will both be pp
register_new_matrix_user -c homeserver.yaml http://localhost:8008 # New user name and pw will both be mm
Open fractal and log into the homeserver at http://localhost:8008 with username pp and password pp
Set up MMSD
from git (historical, no longer needed, mmsdtng commonly packaged)
Grab the git repository and install it:
cd ~
git clone https://source.puri.sm/kop316/mmsd.git
cd mmsd
meson _build
meson compile -C _build
meson test -C _build
sudo meson install -C _build
sudo vi /usr/lib/systemd/user/mmsd-mm.service
[Unit]
[Service]
ExecStart=/usr/local/bin/mmsd -n -d
Restart=on-failure
RestartSec=10s
[Install]
sudo chmod 644 /usr/lib/systemd/user/mmsd-mm.service
systemctl enable mmsd-mm.service --user
systemctl start mmsd-mm --user
Settings for T-Mobile
This config works for me
After starting mmsdtng the first time it should generate a config. Edit the following 3 options:
vi ~/.mms/modemmanager/ModemManagerSettings
CarrierMMSC=http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS_APN=fast.t-mobile.com
AutoProcessSMSWAP=true
Restart MMSD ModemManager service
systemctl restart mmsdtng
Install MMS bridge
Grab it from git and put things in places
cd ~
git clone https://gitlab.com/untidylamp/mmmpuppet.git
cd mmmpuppet
chmod +x mmmpuppet.py
sudo cp mmm*.py /usr/local/bin/
mkdir -p $HOME/.config/mmm/
cp conf.json.sample $HOME/.config/mmm/conf.json
Configure MMS bridge
This will mostly take care of editing the config for you if you are running a local matrix server.
sed -i 's^"https://matrix-client.matrix.org"^"http://localhost:8008"^' $HOME/.config/mmm/conf.json
sed -i 's^"@bot_account:matrix.org"^"@mm:localhost"^' $HOME/.config/mmm/conf.json
sed -i 's^"Change_me"^"mm"^' $HOME/.config/mmm/conf.json
sed -i 's^"@your_accounts:matrix.org"^"@pp:localhost"^' $HOME/.config/mmm/conf.json
You actually have to fill these two out yourself. I put "US" and my +1 and rest of 10 digit number.
vi  $HOME/.config/mmm/conf.json
"cell_number":      "+15554441234",
"cell_country":     "CA",
Now we need to run it once to process the config file and remove secrets (It will say it has done this and exit on first run)
/usr/local/bin/mmmpuppet.py
check it out now
cat $HOME/.config/mmm/conf.json
If it doesn't change the file to remove all the linebreaks then it didn't like it. Figure out why by looking at the log file.
cat ~/.config/mmm/mmmpuppet.log
Go fix whatever went wrong. Which should be nothing. You should have seen a message like this as output before it returns you to a prompt:
Login successful. Config updated with token. Run again to start bridge.
Set up MMS bridge service
Make systemd unit
sudo vi /usr/lib/systemd/user/mmmpuppet.service
[Unit]
Description=Starts mmmpuppet interface
After=mmsd-mm.service
[Service]
ExecStart=/usr/bin/python3 /usr/local/bin/mmmpuppet.py
Restart=on-failure
RestartSec=10s
[Install]
and start it
sudo chmod 644 /usr/lib/systemd/user/mmmpuppet.service
systemctl enable mmmpuppet.service --user
systemctl start mmmpuppet.service --user
done? see if services are running:
ps aux | grep mm
should show something like this even after reboot
alarm       6374  0.0  0.3 235364  7752 ?        Ssl  22:44   0:00 /usr/local/bin/mmsd -n -d
alarm       6825  9.8  2.7 224976 54188 ?        Ssl  22:52   0:05 /usr/bin/python3 /usr/local/bin/mmmpuppet.py
Remove chatty
for arch do pacman stuff to remove chatty
mobian
apt remove chatty
Don't forget to enable data
You can get sms but not mms with mobile data off
Launch fractal
Log in with this homeserver
username
pp
and password
pp
Logins are not saved. I think there was another package for a keyring or something that enables it?
Done
At this point if you get a message a new room should be created by the bridge bot which you will be invited to. Outgoing works for replies but I can't seem to find the 'set topic' button so new rooms can't be created that the MMS bridge can use. The ones the bridge creates work fine though. Using another matrix client, perhaps a command line one, would work.
