PinePhone Installation Instructions
Revision as of 14:47, 12 August 2023 by Fxc (talk | contribs) (→‎Installation to the microSD: Moved to the top)
This section has generic installation instructions.
For specific installation instructions for each distribution please see the software releases pages:
Boot priority
PinePhone Pro
For details regarding the boot priority on the PinePhone Pro see PinePhone Pro#Boot order.
PinePhone
The PinePhone always boots from the microSD card first. It is therefore recommended to have a microSD card handy. It is not possible to lock themself out of the phone when the installation on the internal storage (the eMMC) fails, as a correctly flashed microSD card will always boot. Note: Booting from USB is not supported by the hardware, a live USB stick will not boot.
The phone will also try to boot from microSD cards, which were previously flashed with an OS and formatted later, causing the phone to fail to boot. See reuse SD card on how to format the microSD card properly, including wiping the residues of u-boot.
The microSD belongs in the upper slot, the micro-SIM in the lower slot.
For this installation method you need a microSD card, a microSD card reader and a compatible device, such as a computer or a laptop with Linux, iOS, Windows or similar (Note: ChromeOS is not supported).
To install an image to the microSD card:
  1. Download your chosen image from PinePhone Software Releases for the regular PinePhone and PinePhone Pro Software Releases for the PinePhone Pro
  2. Extract the compressed file
  3. Write ("flash") the image to your microSD card, see the section Flashing the microSD below
  4. Plug microSD card into phone (make sure to use the top slot, not the bottom slot)
  5. On the PinePhone Pro: The eMMC might have to be overruled to boot from the microSD card, see PinePhone Pro#Boot order
  6. Boot up the phone
Using Balena Etcher
Using the graphical application Balena Etcher to flash the microSD card is recommended for new or inexperienced users.
Download: https://etcher.balena.io/#download-etcher
Install the application and start it.
Click the button Flash from file:
Select the downloaded image and make sure that you downloaded the correct one. Images for the PinePhone and the PinePhone Pro are not compatible with each other. Images for the PinePhone typically have the word "PinePhone" in the filename, while images for the PinePhone Pro typically have "PinePhone Pro" in their filename.
Note: At this the image file does not have to be extracted from the archive format. Balena Etcher handles the extracting automatically.
Then click on Select target:
Note: Make sure to select the correct target by comparing the name and the disk capacity with the label on the microSD card.
Then click on Flash!:
That's it! Now follow the further instructions above.
Using dd
Make sure to select the correct device using lsblk. Then run dd with the selected device:
sudo dd if=IMAGE.img of=/dev/[DEVICE] bs=1M status=progress conv=fsync
Note: The image needs to be written to the whole device, not to partition 1. Make sure you're NOT selecting /dev/sda1 or /dev/mmcblk0p1 as target.
Using bmaptool
Make sure to select the correct device using lsblk. Then run bmaptool with the correct device:
Download the IMAGE.xz and the IMAGE.bmap files, then run bmaptool copy --bmap IMAGE.bmap IMAGE.xz /dev/[DEVICE]. This takes around 2.5 minutes to flash a 4 Gb file.
Using Gnome Disks
Gnome Disks can be used to flash the microSD card. To do so, select the correct device in the left device selection, then click on the three dot menu and select Restore Disk Image... and follow the on-screen instructions.
Installation to the eMMC
From the booted microSD OS
  1. Flash an OS to the microSD card (and optionally resize the partition, see below)
  2. Insert microSD card and boot the phone
  3. Download the desired OS' image on the booted OS or transfer it to the microSD card
  4. Extract the image file if it is archived
  5. Flash the image file to eMMC using dd if=IMAGE.img of=/dev/mmcblkX bs=1M status=progress conv=fsync where X is the number label of the eMMC (of the disk, not the partition!). Use the command lsblk to check your devices: typically with the current kernel the microSD card is /dev/mmcblk0 and the eMMC is /dev/mmcblk2 but as always with dd be extremely cautious to get the devices correct.
  6. Turn off phone, remove microSD card and then turn on the phone.
Using JumpDrive
Note: This only applies to the regular PinePhone, not the PinePhone Pro.
The internal eMMC flash storage can be flashed using the Jumpdrive utility by Danct12 and Martijn from postmarketOS. This utility boots from micro SD and exposes the internal eMMC flash storage when the PinePhone is connected to a computer. The process of flashing an OS to the exposed and mounted eMMC is identical to that of any other storage medium - e.g. a microSD card. You can use the dd command or a utility such as Etcher or Gnome Disks, etc.
  1. Download and extract the Jumpdrive image
  2. Flash the Jumpdrive image to a microSD card
  3. Boot the PinePhone from the Jumpdrive microSD card
  6. Once the flashing process is complete, disconnect the PinePhone from your PC, power it down and remove the Jumpdrive microSD card
The Jumpdrive image is smaller than 50MB. You can keep an microSD card specifically for using Jumpdrive, and there are 64MB microSD cards sold cheaply that will suffice. Jumpdrive also acts as a rescue image in case if you messed up your installation. To do so, you can telnet to 172.16.42.1, mount rootfs and fix it!
SD to eMMC via installer
An special installer image booted from the microSD card can be used to flash the eMMC as well. Mobian and postmarketOS installer images booted from microSD card will simply ask the user if they want to install to eMMC. The feature lives in the distribution-agnostic calamares-extensions repository (see calamares-extensions#7), so other distributions might adopt this in the future.
Using Tow-Boot
Tow-Boot is an opinionated distribution of the U-Boot bootloader. It includes an USB Mass Storage Mode, which exposes the flash drive(s) to a computer connected to the phone via USB-C. The Tow-Boot bootloader has to be installed if it is not pre-installed already. For instructions see the following links:
If Tow-Boot is installed the phone can be started into USB Mass Storage Mode by holding the volume up key on startup.
The steps of flashing an operating system to the phone after booting Tow-Boot's USB Mass Storage Mode and connecting the phone to a computer is identical to that of any other storage medium - e.g. a microSD card. You can use the dd command or a utility such as Etcher or Gnome Disks from the computer the phone is connected to.
Resize partition to fit disk space
Note: Many operating systems already include a script, which is resizing the partition on first boot, where this step is not required.
Once you've flashed the OS to your microSD card or eMMC storage, you may also need to expand the partition to fill all the available space.
Resize SD card's partition using computer
For microSD cards, insert the microSD card and resize the partitions through the computer. For eMMC, insert the phone cable and use Jumpdrive to access the eMMC directly, and resize the partition after flashing the image. To do the flashing you have two options:
Using Growpart
Install growpart and run:
growpart /dev/mmcblkX Y
resize2fs /dev/mmcblkXpY
where X is the storage device and Y is the partition number (viewable from lsblk).
If you get any errors about missing or unknown commands, use apt-cache search to find and install the needed software. Also don't forget to use sudo.
Using Parted
Parted's interactive mode and resize work well together. Do this before you put your microSD card into the PinePhone for the first time for best results.
sudo parted /dev/<your_sd_card_device>
(parted) resizepart 2 100%
(parted) quit
sudo resize2fs /dev/<the_second_sd_card_PARTITION>
Resize from within the PinePhone
eMMC: you would need to resize the partition on eMMC (flashed with the operating system) by booting another image from the microSD card: that way, the eMMC will be unmounted. It is not recommended to resize eMMC while booted from eMMC! Resizing a currently mounted partition can have weird results. If you booted from the microSD card, you can follow the above guidelines on how to resize from a computer.
MicroSD card: It is generally not possible to boot from eMMC to partition the unmounted microSD card, because of the boot order - you would have to write the image to the empty microSD card first, then resize partition, all without rebooting. It is also not recommended to resize the microSD card while booted from microSD card! Resizing a currently mounted partition can have weird results.
Reuse SD card for data storage on system booting from eMMC
Once you have installed your release of choice to eMMC, you may wish to use an microSD card for data storage. If you choose to re-use a card you have previously used to boot from, you will find your phone will not boot if you just reformat the card and insert it. This is because the Allwinner firmware in the PinePhone uses some (normally) unused space at the front of the microSD card to store boot software, which you need to clear.
This can be done as follows on any Linux system:
lsblk
to check the device of your microSD card – as an example lets assume it is /dev/mmcblk0 then
sudo dd if=/dev/zero of=/dev/[DEVICE] bs=8k seek=1 count=4
will clear the relevant sectors of your card.
Since Danctnix (arch) switched to a gpt partition table from mbr in May of 2022 it installs u-boot at an offset of 128k instead of 8k, which means this command must be used instead
sudo dd if=/dev/zero of=/dev/[DEVICE] bs=32k seek=4 count=1
Web resources
