PinePhone Hardware Issues
This page is under construction
Please help to review and edit this page or paragraph. Information are subject to change.
Issues
Main Board
Sim Reader
The sim reader may fail to read a sim card (reporting 'sim-missing' in mmcli), possibly due to deformed pins (if you put your sim adapter in without a sim).
USB-C Side Board
All USB-C Side Board issues can be fixed by replacing the USB-C Side Board
Internal Microphone
The microphone may stop working or occasionally stop working or give off static when power is plugged in.
One possible fix is to shim U101 (as seen on the back side of the USB-C Side Board) with a piece of paper or cardboard.
Bottom Speaker
The bottom speaker may stop working, especially if you have recently mishandled the USB-C Side Board, stressing the point of connection between the circuit board and the circuit flex. This can be fixed by touching up the solder between the two.
Uncategorized Issues
Place new issues here.
See Also
