PinePhone Hardware Accessory Compatibility
Revision as of 01:28, 3 November 2020 by E1337 (talk | contribs) (Adding a note encouraging people to fill in missing data)
List of devices that have been tried on the PinePhone, and the results.
Protection
Screen protector
The official screen protector can be found in the Pine64 store under PinePhone Tempered Glass Screen Protector.
Most screen protectors for the iPhone 11 Pro Max and the iPhone XS Max fit the PinePhone (if the top notch is not obscured by a black foil or similar).
Case
The Pine store got official cases:
Tight-fit cases of other phones can't be alienated for the PinePhone due as most times the proportions and/or camera notch won't fit. The phone can however also be used with "phone sleeves", such as those from fitBAG. The sleeve from fitBAG for the Xiaomi Redmi Note 8 Pro is fitting the PinePhone very tightly.
Peripheral equipment
Note: if you tested any of the listed entries with an "Unknown" in any column, please feel encouraged to fill it in. (Even if you aren't the original tester who originally added the row!)
Type Make/Model Connected
via
Hardware IDs Result Tested OS Tested PinePhone HW (1.2, 1.2a, ...) Notes
USB-C Hub AliExpress 5-1 USB-C Hub USB-C 05e3:0626 hub PD not working,
rest not working yet
UBPorts/pmOS Unknown HDMI, GBit eth, 2xUSB-3, USB-C PD
Bluetooth Keyboard Unknown(? maybe this entry should be removed) Bluetooth -- No pairing via ui, but functional via terminal pmOS Unknown Instructions
USB-C Hub UMAX U-Connect Type-C Multiport H7 USB-C - USB-A ports, PD, HDMI works, SD card reader not enumerating on PP with removed VCONN switches (may need VCONN) Arch Linux Unknown HDMI, 3xUSB-3, USB-C PD, SD reader
USB-C Soundcard Google Pixel USB-C to 3.5mm adapter USB-C 18d1:5029 Works, recognized as usb soundcard, but only if a cable is plugged in pmOS Unknown
USB-C Hub Anker PowerExpand+ 7-in-1 USB-C PD Ethernet Hub USB-C -- USB Ports and HDMI Port work, can charge while using this device (needs VCONN HW mod) Mobian Unknown HDMI, USB3, Ethernet, PD-USBC, SD Card, Micro SD Card
USB-C Hub Dell WD-15 Docking station USB-C 0424:2807 USB Ports and charging works. Audio sinks and DP status changes are detected (needs VCONN HW mod and ANX firmware) pmOS Unknown HDMI, VGA and DP might work after a kernel update. ANX firmware is needed for charging after VCONN mod.
USB-C Hub Microsoft HD-500 Dock USB-C -- USB Hub, Display Out, and Power Delivery all works. (needs VCONN HW mod and ANX firmware) Mobian Unknown
USB-C Hub HP Elite x3 LapDock USB-C -- Dock display, keyboard/trackpad, and Power Delivery all works. (needs VCONN HW mod and ANX firmware) Mobian Unknown Haven't tested micro-HDMI port or the internal USB-C hub.
USB-C Hub Plexgear 7-port multi adapter with PD and SD-card reader USB-C USB-hub: 0bda:5411 (RTS5411); Ethernet: 0bda:8153 (RTL8153); SD-card reader: 05e3:0749; Audio: 0c76:161f; 2109:0102; 0c76:161f Everything seems to work. PD, 3x USB 2.0 ports, ethernet, HDMI, SD-card, audio. Arch Linux 1.2 with VCONN mod (CC switches removed)
