PinePhone Hardware Accessory Compatibility
Revision as of 15:30, 5 June 2020 by Fxc (talk | contribs) (fix)
List of devices that have been tried on the PinePhone, and the results.
Peripheral equipment
Type Make/Model Connected
via
Hardware IDs Result Tested OS Notes
5-1 USB-C hub from aliexpress USBC 05e3:0626 hub PD not working,
rest not working yet
UBPorts/pmOS HDMI, GBit eth, 2xUSB-3, USB-C PD
Generic Bluetooth keyboard generic BT -- No pairing via ui, but functional via terminal pmOS instructions
Protection
Screen protector
Most screen protectors for the iPhone 11 Pro Max and the iPhone XS Max fit the PinePhone (if the top notch is not obscured by a black foil or similar).
Case
The Pine store got official cases:
Tight-fit cases of other phones can't be alienated for the PinePhone due as most times the proportions and/or camera notch won't fit. The phone can however also be used with "phone sleeves", such as those from fitBAG.
