PinePhone (Pro) replacement earpieces
Revision as of 00:47, 13 July 2023 by Sethi (talk | contribs) (Clarify what is low quality about the LG earpiece.)
The "earpiece" refers to the small speaker at the top of the phone.
The earpiece is not available to purchase from the PINE64 Store. However, it is possible to buy a replacement earpiece for another device, and install it in a PinePhone or PinePhone Pro. This documents earpieces that have been tested by the community, and verified to work.
Note that the earpiece dimensions for both the PinePhone and PinePhone Pro are 12x6x2 mm. When looking into other earpieces not found in this list, aim for these dimensions.
Earpiece PinePhone PinePhone Pro Where to Buy
LG K8 2017 M200N Kind of ¹ Broken Replace Base
Nokia 5 Works Works Replace Base
Nokia 7 Works ² Works ² Replace Base
Nokia X5 Works Works Replace Base
OnePlus One Works Works Replace Base
OnePlus X Works Works Replace Base
PinePhone Works Works
Xiaomi Mi A1 Works Works Replace Base
Xiaomi Redmi Note 4 Works Works Replace Base
Notes
¹ The earpiece is too thin, it can work with padding to keep the contacts together.
² Audio playback is very low quality.
List of earpieces that are too large for the PinePhone (Pro)
The following devices are known to have replacement earpieces with dimensions too large to fit inside the PinePhone or PinePhone Pro.
  • Blackberry Classic Q20
  • HTC Desire 500
  • HTC M10
  • Huawei Honor 7A
  • Huawei Mate 10 Pro
  • Huawei Y7 Prime 2018
  • OnePlus 2
  • Oppo Reno 5 4G
  • Sony Xperia X Compact
  • Sony Xperia XA1 Ultra
  • Sony Xperia XP X Performance
  • Sony Xperia XZ
