PinePhone
First time installation
PinePhone is capable of running a multitude of different Linux mobile OSes
Backward and front of PinePhone UBPorts Edition
After unboxing remove the back panel using the notch in the corner of the back panel. Then remove the battery and peel off the clear plastic sticker below it that isolates the charging contact. Then replace the battery. See Battery for more information.
Specifications
Weight: Between 180-200 grams
SIM Card: Micro-SIM
Display:
System on Chip: Allwinner A64
RAM: 2GB LPDDR3 SDRAM
Internal Storage: 16GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
Communication: G25-G
Bluetooth: 4.0, A2DP
Components
Component Model
Touchscreen Goodix GT917S
Rear camera OmniVision OV5640
Camera flash SGMICRO SGM3140
LCD Xingbangda XBD599
WiFi Realtek RTL8723CS
Bluetooth Realtek RTL8723CS
Modem Quectel EC25-E
GNSS/GPS Quectel EC25-G
Magnetometer ST LIS3MDL
Sixaxis InvenSense MPU-6050
Vibration motor Yes, unknown model
Notification LED LED0603RGB
Power button X-Powers AXP803
Hardware Revisions
  1. Project Anakin
  5. PinePhone v1.2‎ - Community Edition
Hardware Addons
PinePhone Hardware Accessory Compatibility
See PinePhone Hardware Accessory Compatibility for a list of devices working with the PinePhone (depending on their OS support)
USB-C Connector
Pogo Pins
Interrupt SDA SCL
3V3 USB-5V GND
The USB-5V line is for charging the phone and the 3V3 power source for powering peripherals to the phone. The I2C and interrupt lines have pull-ups on the phone side.
Back cover
Serial console
The UART is 115200n8.
  • Tip: RX
  • Ring: TX
  • Sleeve: GND
Killswitch configuration
Photo of BraveHeart switches from OSAKANA TARO on Twitter
Battery
The EG25 modem and RTL8723CS WiFi/bluetooth do not work without battery power, even if you are supplying enough power to the PinePhone with USB-C.
The supplied battery is meant to be compatible with Samsung part number EB-BJ700BBC / BBE / CBE from the 2015 J7 phone. There is a report that the EB-BJ700CBE isn't quite the same size, causing the back not to fit properly.
  1. +ve
  2. thermistor
  3. -ve
  4. not connected
If your battery is hard to remove from the phone, try loosening the screws around it. Possibly cutting up a piece of plastic and sliding it under the battery as a pull tab can work too.
Modem and Carrier Support
To check if the PinePhone is supported on your carrier:
Search for your carrier on frequencycheck.com and compare the carrier's LTE/GSM/WCDMA frequencies to the PinePhone's supported frequencies (listed under the specifications section).
It is likely that there will be a few frequencies that your carrier uses which are not supported by the PinePhone. Not all of the carrier's frequencies need to be supported by the PinePhone for it to work - as long as most of them are supported, you will still get good coverage.
Voice mail
APN settings
For tested APN settings and how to apply them see PinePhone APN Settings.
Documents
There is a document about using the modem from January 18th 2020 by user megi here. The script at the end to disable the modem before power off is pretty essential to avoid corrupting your modem's flash memory.
Operating Systems
Installation instructions
Flashing eMMC using Jumpdrive
Detailed Usage Instructions
Resize file system
If you flash a 4GB image distribution (such as phosh+debian) to your eMMC, your eMMC will only have a 3.7G partition on it. To use the entire 14.7G on the eMMC, run the following commands:
  1. sudo cfdisk /dev/sdX
  2. Change to [Resize] in the ncurses program, resize the 3.7G partition to 14.7G, and [Write]
  3. sudo resize2fs /dev/sdXY
Feedback
Frequently Asked Questions
For a list of frequently asked questions (including information regarding the shipping), see PinePhone FAQ.
PinePhone Board Information, Schematics and Certifications
Developer works
Megous
External links
