PinePhone
Revision as of 13:48, 28 June 2020 by Jedi2light (talk | contribs) (Added PinePhoneSides.svg to wiki, but wiki engine can not display this file due to backend error, seems like imagemagick package is not installed)
The PinePhone is a smartphone created by Pine64, capable of running mainline Linux and supported by many partner projects. The BraveHeart Edition was the first publicly-available version of the phone, though it came without a fully functional OS (factory test image) and was geared specifically towards tinkerers and hackers. Its successor is the Community Edition, which is expected to be shipped in June 2020 and will be available for at least five years.
First time installation
PinePhone is capable of running a multitude of different Linux mobile OSes
PinePhone`s backward and front sides
After unboxing remove the back panel using the notch in the corner of the back panel. Then remove the battery and peel off the clear plastic sticker below it that isolates the charging contact. Then replace the battery. See Battery for more information.
Specifications
Weight: Between 180-200 grams
SIM Card: Micro-SIM
Display:
System on Chip: Allwinner A64
RAM: 2GB LPDDR3 SDRAM
Internal Storage: 16GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
Communication: EG25-G
Bluetooth: 4.0, A2DP
Killswitches: Modem, Wifi & Bluetooth, Microphone, Cameras
Battery: Lithium ion Rated Capacity 2800mAh (10.64Wh), Typical Capacity 3000mAh (11.40Wh) (nominally replaceable with any Samsung J7 form-factor battery)
Hardware Revisions
  1. Project Anakin
  5. PinePhone v1.2‎ - Community Edition
Hardware Addons
PinePhone Hardware Accessory Compatibility
See PinePhone Hardware Accessory Compatibility for a list of devices working with the PinePhone (depending on their OS support)
USB-C Connector
Pogo Pins
The PinePhone has 6 pogo pins on the back allowing for custom hardware extensions such as wireless charging or an IR blaster. The pogo pins provide access to an interrupt line, power input to charge the battery, 3.3 V power source (disputed: see PinePhone_v1.1_-_Braveheart#Pogo_Pins_supply_5v0.2C_not_3v3), and an I2C interface.
A step/stl/stp (3D model) file for the back cover is freely available for creating custom cases that interface with the pogo pins.
Serial console
UART serial connector for PineBook and PinePhone
The PinePhone has a serial port in the headphone connector, it's activated by the 6th contact on the dipswitch. If the switch is on then the headphone connector is in audio mode, if it's off then it's in UART mode. This uart serial connection can also be used for communication with other devices from the PinePhone.
The UART is 115200n8
The pinout for the serial connector on the tablet side is:
  • Tip: RX
  • Ring: TX
  • Sleeve: GND
Because it is a "host"/DTE that means that you need a "cross modem cable" (Wikipedia Null Modem) with TX on Tip to be connected to RX on tablet side.
The serial connection is 3.3V. A cable like e.g. FTDI TTL-232R-3V3-AJ which has TX on Tip and RX on Ring fits perfectly.
You can also buy the debug cable from PINE64 Store The store cable uses a 4 ring plug, as seen in the PDF, but a 3 ring plug works just as well. That cable uses a CH340 chipset based serial to USB converter, but any 3.3v serial connection can be used.
Killswitch configuration
Photo of BraveHeart switches from OSAKANA TARO on Twitter
The PinePhone features six switches that can be used to configure its hardware. They are numbered 1-6, with switch 1 located nearest to the modem. Their on position is toward the top of the phone.
  1. Modem: On enables 2G/3G/4G communication and GNSS hardware, off disables.
  2. WiFi/BT: On enables Wi-Fi and Bluetooth communication hardware, off disables.
  3. Microphone: On enables audio input from on-board microphones (not 3.5mm jack), off disables.
  4. Rear camera: On enables the rear camera, off disables.
  5. Front camera: On enables the front camera, off disables.
  6. Headphone: On enables audio input and output via the 3.5mm audio jack, off switches the jack to hardware UART mode.
Battery
The supplied battery is meant to be compatible with Samsung part number EB-BJ700BBC / BBE / CBE from the 2015 J7 phone. There is a report that the EB-BJ700CBE isn't quite the same size, causing the back not to fit properly.
  1. +ve
  2. thermistor
  3. -ve
  4. not connected
If your battery is hard to remove from the phone, try loosening the screws around it. Possibly cutting up a piece of plastic and sliding it under the battery as a pull tab can work too.
The BraveHeart Edition ships with a plastic sticker between the battery and the phone. You need to open the back cover (gently), then remove the battery and finally remove the sticker. This is to protect the device from turning on during shipping.
Photo of Brave Heart case from OSAKANA TARO on Twitter
Photo of Brave Heart battery sticker from OSAKANA TARO on Twitter
The EG25 modem and RTL8723CS Wifi/bluetooth do not work without battery power, even if you are supplying enough power to the PinePhone with USB-C.
There has been a report on the forum that this sticker can bend the pins that make connection between the battery and the phone: please check your setup carefully after removing the sticker.
Modem and Carrier Support
There is a document about using the modem from January 18th 2020 by user megi here. The script at the end to disable the modem before power off is pretty essential to avoid corrupting your modem's flash memory.
To check if the PinePhone is supported on your carrier:
Search for your carrier on frequencycheck.com and compare the carrier's LTE/GSM/WCDMA frequencies to the PinePhone's supported frequencies (listed under the specifications section).
It is likely that there will be a few frequencies that your carrier uses which are not supported by the PinePhone. Not all of the carrier's frequencies need to be supported by the PinePhone for it to work - as long as most of them are supported, you will still get good coverage.
Voice Mail
APN settings
For tested APN settings and how to apply them see PinePhone APN Settings.
Operating Systems
The PinePhone will automatically boot from microSD if a bootable card is inserted. Although it is technically possible to use any ARM distribution (because the PinePhone uses the mainline kernel), there are a few that are designed specifically for mobile use on devices like the PinePhone
The PinePhone Software Releases page has a complete list of currently supported phone-optimized Operating System images that work with the PinePhone as well as other related software information. As soon as more patches got mainlined and distributions ship with the updated kernel, they will also be able to run unmodified on the device.
Installation instructions
For instructions how to install the operating systems on the eMMC or SD card see PinePhone Installation Instructions.
Flashing eMMC using Jumpdrive
The internal eMMC flash storage can be flashed using the Jumpdrive utility by Danct12 and Martijn from postmarketOS. This utility boots from micro SD and exposes the internal eMMC flash storage when the PinePhone is connected to a computer. The process of flashing and OS to the exposed and mounted eMMC is identical to that of any other storage medium - e.g. a SD card. You can use the 'DD' command or a utility such as Etcher or Gnome Disks, etc.
Detailed Usage Instructions
Resize file system
If you flash a 4GB image distribution (such as phosh+debian) to your eMMC, your eMMC will only have a 3.7G partition on it. To use the entire 14.7G on the eMMC, run the following commands:
  1. sudo cfdisk /dev/sdX
  2. Change to [Resize] in the ncurses program, resize the 3.7G partition to 14.7G, and [Write]
  3. sudo resize2fs /dev/sdXY
Feedback
Frequently Asked Questions
For a list of frequently asked questions (including information regarding the shipping), see PinePhone FAQ.
PinePhone Board Information, Schematics and Certifications
Developer works
Megous
External links
