PinePhone
Revision as of 01:39, 20 November 2019 by FlyingToast (talk | contribs)
The PinePhone is a smartphone created by Pine64, capable of running mainline Linux and supported by many partner projects. A "braveheart" edition is currently available for purchase from the PINE64 store, though it should be noted that this version comes without a preinstalled OS, and is geared specifically towards tinkerers and hackers. People looking for a stable consumer-grade phone should wait for the final release, which is expected to occur in March 2020 and will be available for at least five years.
Specifications
  • BODY:
    • Dimensions: 160.5mm x 76.6mm x 9.2mm
    • Weight: Between 180-200 gram
    • Build: Plastic
    • SIM: Micro-SIM
  • DISPLAY:
    • Size: 5.95 inches
    • Resolution: 1440x720 pixels, 18:9 ratio
  • PLATFORM:
    • OS: Various open source mainline Linux or BSD mobile OSes
    • Chipset: Allwinner A64
    • CPU: Quad-core 1.2 GHz ARM Cortex A-53
    • GPU: MALI-400
  • MEMORY:
    • Internal: 16GB eMMC, 2GB LPDDR3 SDRAM
    • Expansion: micro SD Card support SDHC and SDXC
  • CAMERA:
    • Main Camera: Single 5MP, 1/4", LED Flash
    • Selfie Camera: Single 2MP, f/2.8, 1/5"
  • SOUND:
    • Loudspeaker: Yes
    • 3.5mm jack with mic: Yes
  • COMMUNICATION:
    • LTE-FDD: B1/ B2/ B3/ B4/ B5/ B7/ B8/ B12/ B13/ B18/ B19/ B20/ B25/ B26/ B28
    • LTE-TDD: B38/ B39/ B40/ B41
    • WCDMA: B1/ B2/ B4/ B5/ B6/ B8/ B19
    • GSM: 850/900/1800/1900MHz
    • Bluetooth: 4.0, A2DP
    • GPS: Yes, with A-GPS, GLONASS
    • NFC: No
    • FM Radio: No
    • USB: type C (SlimPort), USB Host, DisplayPort Alternate Mode output
    • 3.5mm jack doubles as hardware UART if killswitch 6 is deactivated
  • FEATURES:
    • Sensors: Accelerometer, gyro, proximity, ambient light, magnetometer(compass)
    • Actuator: Vibrator
    • Privacy Switches: Modem (disables cellular modem and GNSS/GPS), Wifi & Bluetooth, Microphone, and Cameras
  • BATTERY:
    • Removable Li-Po 2750-3000 mAh battery
    • Charging: USB Type-C, 15W 5V 3A Quick Charge, follows USB PD specification
  • PRICE:
    • USD $150 (16GB eMMC/2GB LPDDR3 SDRAM configuration)
No other configurations of the PinePhone are available at this time.
History
The PinePhone was announced at FOSDEM 2019, February 2-4, 2019. The first Project Don't be evil devkit was on display at the Pine64 booth during the weekend.
Hardware revisions
The PinePhone platform went through two "developer kit" phases that partner projects used to prove their software on the upcoming platform.
  1. Project Anakin
  2. Project Don't be evil
Additionally, two "early adopter" revisions of the platform were created:
  1. PinePhone 1.0 "Developer"
  2. PinePhone 1.1 "Brave Heart"
The first generally available PinePhone batch was PinePhone 1.1 "Brave Heart". Pre-orders for this batch started on November 15, 2019. It is expected to ship sometime in December 2019 to January 2020.
A "full release" Pinephone, which will likely have board revision 1.2, will be released in 2020.
Killswitch configuration
The PinePhone features six switches that can be used to configure its hardware. They are numbered 1-6, with switch 1 located nearest to the modem. Their on position is toward the top of the phone.
  1. Modem: On enables 2G/3G/4G communication and GNSS hardware, off disables.
  2. WiFi/BT: On enables Wi-Fi and Bluetooth communication hardware, off disables.
  3. Microphone: On enables audio input from on-board microphones (not 3.5mm jack), off disables.
  4. Rear camera: On enables the rear camera, off disables.
  5. Front camera: On enables the front camera, off disables.
  6. Headphone: On enables audio input and output via the 3.5mm audio jack, off switches the jack to hardware UART mode.
