PinePhone
Revision as of 01:18, 20 November 2019 by UniversalSuperBox (talk | contribs) (Rewrite page with the start of a beautiful new timeline)
The PinePhone is a smartphone platform created by the Pine64 community and supported by many partner projects. It should be available for five years from its consumer launch date, which is expected to occur in March 2020.
Specifications
  • BODY:
    • Dimensions: 160.5mm x 76.6mm x 9.2mm
    • Weight: Between 180-200 gram
    • Build: Plastic
    • SIM: Micro-SIM
  • DISPLAY:
    • Size: 5.95 inches
    • Resolution: 1440x720 pixels, 18:9 ratio
  • PLATFORM:
    • OS: Various open source mainline Linux or BSD mobile OSes
    • Chipset: Allwinner A64
    • CPU: Quad-core 1.2 GHz ARM Cortex A-53
    • GPU: MALI-400
  • MEMORY:
    • Internal: 16GB eMMC, 2GB LPDDR3 SDRAM
    • Expansion: micro SD Card support SDHC and SDXC
  • CAMERA:
    • Main Camera: Single 5MP, 1/4", LED Flash
    • Selfie Camera: Single 2MP, f/2.8, 1/5"
  • SOUND:
    • Loudspeaker: Yes
    • 3.5mm jack with mic: Yes
  • COMMUNICATION:
    • LTE-FDD: B1/ B2/ B3/ B4/ B5/ B7/ B8/ B12/ B13/ B18/ B19/ B20/ B25/ B26/ B28
    • LTE-TDD: B38/ B39/ B40/ B41
    • WCDMA: B1/ B2/ B4/ B5/ B6/ B8/ B19
    • GSM: 850/900/1800/1900MHz
    • Bluetooth: 4.0, A2DP
    • GPS: Yes, with A-GPS, GLONASS
    • NFC: No
    • FM Radio: No
    • USB: type C (SlimPort), USB Host, DisplayPort Alternate Mode output
    • 3.5mm jack doubles as hardware UART if killswitch 6 is deactivated
  • FEATURES:
    • Sensors: Accelerometer, gyro, proximity, ambient light, magnetometer(compass)
    • Actuator: Vibrator
    • Privacy Switches: Modem (disables cellular modem and GNSS/GPS), Wifi & Bluetooth, Microphone, and Cameras
  • BATTERY:
    • Removable Li-Po 2750-3000 mAh battery
    • Charging: USB Type-C, 15W 5V 3A Quick Charge, follows USB PD specification
  • PRICE:
    • USD $150 (16GB eMMC/2GB LPDDR3 SDRAM configuration)
No other configurations of the PinePhone are available at this time.
History
The PinePhone was announced at FOSDEM 2019, February 2-4, 2019. The first Project Don't be evil devkit was on display at the Pine64 booth during the weekend.
Hardware revisions
The PinePhone platform went through two "developer kit" phases that partner projects used to prove their software on the upcoming platform.
  1. . Project Anakin
  2. . Project Don't be evil
Additionally, two "early adopter" revisions of the platform were created:
  1. . PinePhone 1.0 "Developer"
  2. . PinePhone 1.1 "Brave Heart"
The first generally available PinePhone batch was PinePhone 1.1 "Brave Heart". Pre-orders for this batch started on November 15, 2019. It is expected to ship sometime in December 2019 to January 2020.
A "full release" Pinephone, which will likely have board revision 1.2, will be released in 2020.
Killswitch configuration
The PinePhone features six switches that can be used to configure its hardware. They are numbered 1-6, with switch 1 located nearest to the modem. Their on position is toward the top of the phone.
  1. . Modem: On enables 2G/3G/4G communication and GNSS hardware, off disables.
  2. . WiFi/BT: On enables Wi-Fi and Bluetooth communication hardware, off disables.
  3. . Microphone: On enables audio input from on-board microphones (not 3.5mm jack), off disables.
  4. . Rear camera: On enables the rear camera, off disables.
  5. . Front camera: On enables the front camera, off disables.
  6. . Headphone: On enables audio input and output via the 3.5mm audio jack, off switches the jack to hardware UART mode.
PinePhone Concepture Photo
PinePhone Case Photos
