PinePhone
Revision as of 18:02, 26 April 2021 by Fxc (talk | contribs) (Reverted edits by Fxc (talk) to last revision by Dsimic)
Introduction
State of the software
First things first, the PinePhone is aimed solely at early adopters - more specifically, the only intend for these units is to find their way into the hands of users with extensive Linux experience.
Bear in mind that the software for Linux on phones is very early, with most of the software being in alpha or beta state. That's especially also the case for scalability of applications, their availability and practicability, any hardware function implementations and the firmware. The software is provided as is. There is no warranty for the software, not even for merchantability or fitness for a particular purpose.
Help and support
For any questions regarding the phone please regard the contents of this wiki page, including linked articles further below. Still have any questions regarding software, shipping or ordering? Please don't hesitate to contact the community in the bridged community channels for detailed answers and to chat with friendly people, see Main Page#Community and Support.
Mind that PINE64 is not like a regular company (see PINE64 philosophy) and that support resources are spare - the preferred way to get support quickly (issues are best solved in they're solved without delay!) is to ask in the community chat and to only contact PINE64 directly if questions couldn't be solved via the chat. The community is happy to help with any issue.
First time installation
Protective plastic tab, as visible under the back cover, with the battery in place
Slots for microSD and SIM cards, under the back cover of the phone
Warning: The Beta Edition comes with SSH enabled by default and a weak SSH password. It is highly recommend to disable SSH or to switch to key-based SSH authentication.
When shipped, the battery is isolated from the device using a protective plastic tab, as visible on the picture, which is required to be removed before using the phone. The battery will not charge until this is removed and the modem, WiFi and Bluetooth will not work until the battery is connected.
  1. Carefully remove the back panel using the notch in the corner of the back cover without overbending it
  2. Remove the battery (if the battery is stuck in the device please check this paragraph for a fix).
  4. Reinsert the battery
For further information, see the section below.
The PinePhone's SIM slot only accepts a micro SIM, as visible on the picture. Please, do not insert a nano SIM without an adapter. An adapter from a nano SIM to a micro SIM may be included under tape in one of the notches of the phone's packaging. The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot, as pictured here:
Specifications
  • SIM Card: Micro-SIM
  • Display:
  • Sound: Loudspeaker, 3.5mm jack & mic (jack doubles as hardware UART if killswitch 6 is deactivated)
  • Communication:
    • Modem: Quectel EG25-G
    • LTE-TDD: B38, B39, B40, B41
    • Bluetooth: 4.0, A2DP
  • Killswitches: Modem, WiFi & Bluetooth, Microphone, Cameras
Components
The list of major hardware components of the PinePhone is available in the table below; see also the PinePhone component list and the PinePhone schematics.
Component Model
Touchscreen Goodix GT917S
Rear camera OmniVision OV5640
Camera flash SGMICRO SGM3140
LCD Xingbangda XBD599
WiFi Realtek RTL8723CS
Bluetooth Realtek RTL8723CS
Modem Quectel EG25-G
GNSS/GPS Quectel EG25-G
Magnetometer ST LIS3MDL
Vibration motor Unknown model
Notification LED LED0603RGB
Power button X-Powers AXP803
Hardware revisions
Thermal safety
The PinePhone is based on Allwinner A64, which is an older-generation SoC built on a 40 nm process; as a result, the phone produces quite some heat under medium or high loads, and especially during charging or when using USB accessories such as a docking station. Measurements to prevent damage to the phone and to its surroundings need to be taken by the user. This especially includes proper handling of the phone: do not charge the phone in a way where heat builds up around the phone without being able to escape. Especially do not charge your phone under a pillow or a blanket, or in pockets or bags. Charging the phone produces heat, so charging the phone in a way where the excessive heat cannot dispose around the phone poses an immediate fire risk.
Users might notice that the phone gets warm under usage, compared to other smartphones with more up-to-date hardware. Under normal circumstances these temperatures do not pose a risk while being in the levels within the safe operating temperatures, which are beyond the point where components can be too hot to touch. Higher temperatures might especially be experienced on the top side of the screen and on the inside of the phone, at the RF shield of the modem. The higher temperature of the RF shield of the modem is also caused by the SoC on the opposite side of the main board, and the RF shield of the modem is used to disperse some of the heat produced by the SoC. In newer phone revisions, starting with the revision 1.2a, there are also thermal pads and foils on the back cover and between the SoC's RF shield and the screen, dispersing heat on the screen and on the back cover. In the past there have been safety concerns regarding the thermals, possibly causing heat damage in some cases; see the documentation of those issues by the developer Megous here and here. While the developers are working hard to prevent such issues, they cannot be excluded under all circumstances; see also this section. The users are expected to monitor their phones' thermals at every point at this state of the software.
It is highly recommend to update the phone on a regular basis to always get the latest improvements. The default settings for the performance throttling and emergency shutdowns upon reaching the critical temperatures might be set to a too high point depending on the specific use-case and length of the usage. Under Linux, the phone's thermal management behavior can be modified to achieve lower temperatures and prevent the screen and other components from potentially taking damage; see PinePhone Thermal Tweaks for further details.
Hardware accessories
USB-C connector
The USB-C can be used to power the device, and offers USB2 host and OTG possibilities, and also can make use of the USB-C capability to integrate HDMI signals. Some USB-C hubs are available that offer power throughput, USB connection, HDMI port and Ethernet connection.
Pogo pins
Interrupt SDA SCL
DCIN USB-5V GND
DCIN and USB-5V are the names used in the schematics. The actual behavior of these pogo pins is not obvious based on their names. DCIN is connected both to the VBUS line of the USB Type-C connector, and to the ACIN/VBUS inputs on the PMIC. This means that, depending on a number of factors, DCIN may be at 0 V or 5 V. USB-5V is connected at the output of an LP6226 DC/DC boost converter (5 V), which in turn is fed by the PS output of the PMIC. The boost converter is enabled or disabled by a GPIO output from the A64 SoC, controlled by software (e.g. the Linux kernel). Depending on inputs and decision made by the PMIC, PS may be at the battery voltage (fed "directly" by the battery through a transistor controlled by the PMIC), or at the "USB" voltage (fed by the PMIC's ACIN/VBUS inputs). This means that depending on a number of factors, USB-5V may be at battery voltage (between 3.0 V and 4.3 V), or at 5 V.
Because the PinePhone may act as a USB host (providing 5 V at the USB Type-C connector's VBUS to a connected device) or as a USB device (drawing from a 5 V source on the USB Type-C connector's VBUS), DCIN is actually not strictly an input nor an output. Some community analysis of the PinePhone schematic (and some testing) indicates that you can connect a 5 V power supply to DCIN in order to power the phone at the PMIC's ACIN/VBUS inputs (and, as a side effect, charge the battery). This may not be safe to do in all conditions, e.g., when the phone is acting as a USB host to a connected USB device. It should also be safe to use DCIN as a power output from the PinePhone, e.g., when a USB Type-C charger is connected, you can draw current directly from the USB Type-C port's VBUS, which is provided by the charger. Please note that, when using DCIN as an output from the PinePhone, DCIN isn't "always on"; it may be 0 V. It is currently not documented on how much current can be safely drawn.
USB-5V should be safe to use as an "always on" power output from the PinePhone. Depending on a number of factors, voltage may be from 3 V to 5 V; thus, if you are using USB-5V to power your pogo-pins expansion board, you will probably need to use DC/DC converters/regulators as appropriate. USB-5V is on even while the A64 SoC is powered down.
The I2C and interrupt lines have pull-ups on the phone side. The I2C lines are pulled up to 3v3 by the phone.
Back cover
Community-built accessories
Serial console
Serial connector pinout
The PinePhone has a serial port accessible through the headphone connector, which is activated by the sixth position of the DIP switch under the back cover. If the switch is set to the "on" position, the headphone connector is in audio mode; if it is set to "off", the connector is in the UART mode. The UART serial connection can also be used for communication with other devices from the PinePhone.
The parameters for serial communication are 115200n8.
The pinout of the serial connector is as follows:
  • Tip: RX
  • Ring: TX
  • Sleeve: GND
Killswitch configuration
Detail of DIP switch
Camera
Battery
Protective plastic sticker inside a PinePhone
The EG25-G modem and the RTL8723CS WiFi and Bluetooth combo do not work without battery power, even when enough power is supplied to the PinePhone via the USB Type-C port.
The phone ships with a protective plastic sticker between the battery and the phone to protect the device from turning on during shipping.. You need to gently open the back cover, then remove the battery and finally remove the sticker and check that the pins aren't bent. Note: If the battery is stuck inside the phone, the mid screw in the lower part of the midframe needs to be slightly loosened, see here.
Modem
The PinePhone uses Quectel EG25-G as modem. AT commands are used to communicate with the modem. The software minicom can be used to send the commands.
To connect with the modem:
minicom -D /dev/ttyUSB2
AT commands
A list of documented AT commands can be found in the EC25&EC21 AT Commands Manual from Quectel. Further undocumented AT commands found by the developer megi, who reverse-engineered parts of the modem and its firmware, can be found on megi's website here.
VoLTE
AT+QMBNCFG="list"
AT+QCFG="ims",1
AT+CFUN=1,1
AT+CLCC
+CLCC: 1,1,0,1,0,"",128
+CLCC: 2,1,0,1,0,"",128
APN settings
Carrier support
Documents
Firmware update
The modem firmware can be updated to the latest version if it is outdated and dmesg returns the following message:
modem-power serial1-0: Your modem has an outdated firmware. Latest know version is EG25GGBR07A08M2G_01.002.07. Consider updating.
Pre-update checklist:
cd quectel_eg25_recovery
sudo ./qfirehose -f ./
Firmware modifications
GPS / GNSS
GPS data from /dev/ttyUSB1 being decoded by gpsmon
The GPS engine in the modem supports mutli-GNSS reception from GPS, GLONASS, BeiDou, Galileo and QZSS independent of a cellular connection. The operation of the GNSS subsystem is controlled via a separate set of AT commands. The AGPS data upload uses the file management AT commands, which also have their own manual. These are linked in the documentation section below.
As with most smartphones, the PinePhone has a small antenna and has difficulty getting a first fix without assistance data, a cold start can take 15 minutes under good conditions. While the hardware supports AGPS data upload, it isn't yet implemented in current distributions. There is a proof of concept script which can be made to work, but support needs to be added to ModemManager, oFono etc. before it will be easy to use.
Basic testing of GNSS reception can be done by using the AT command interface (/dev/ttyUSB2) from a terminal progam like minicom and the data output interface (/dev/ttyUSB1) to feed NMEA data into gpsmon or some other progam that can parse standard NMEA sentences.
cat /dev/ttyUSB1
$GPVTG,,T,,M,,N,,K,N*2C
$GPGSA,A,1,,,,,,,,,,,,,,,,*32
$GPGGA,,,,,,0,,,,,,,,*66
Voice mail
In Canada, Rogers voicemail can be called by dialing *98
Operating systems
Software releases
Installation instructions
Relevant subsections of the article for installing OSes to the PinePhone are:
Frequently asked questions
Modifications and repairs
Replacing the mainboard
Alternatively, user bridadan uploaded a video tutorial of the swap procedure including camera swap and proximity sensor housing here: https://www.youtube.com/watch?v=J3AJEF7akkw.
Flashing the ANX firmware
Method 1
Download the latest ANX7688 firmware image on the phone:
Method 2
Booting a factory test image will automatically flash the ANX7688 chip. See PinePhone Software Releases#Factory-loaded postmarketOS build for such an image.
Replacing the screen
Spare parts not available in the Pine64 store
  • Earpiece dimensions: 12x6x2 mm. Compatible with Xiaomi Mi2 / Mi3 / Mi4, Lenovo A536 and others, see here
  • Loudspeaker dimensions: 15x11x3 mm. Compatible with Nokia N91, Lenovo A536 and others, see here
Press
Developer works
The following resources have been made available by Megous, one of the developers:
External links
