PinePhone
Introduction
State of the software
First things first, the PinePhone is aimed solely at early adopters - more specifically, the only intend for these units is to find their way into the hands of users with extensive Linux experience.
Bear in mind that the software for Linux on phones is very early, with most of the software being in alpha or beta state. That's especially also the case for scalability of applications, their availability and practicability, any hardware function implementations and the firmware. The software is provided as is. There is no warranty for the software, not even for merchantability or fitness for a particular purpose.
Help and support
For any questions regarding the phone please regard the contents of this wiki page, including linked articles further below. Still have any questions regarding software, shipping or ordering? Please don't hesitate to contact the community in the bridged community channels for detailed answers and to chat with friendly people, see Main Page#Community and Support.
Mind that PINE64 is not like a regular company (see PINE64 philosophy) and that support resources are spare - the preferred way to get support quickly (issues are best solved in they're solved without delay!) is to ask in the community chat and to only contact PINE64 directly if questions couldn't be solved via the chat. The community is happy to help with any issue.
First time installation
When shipped, the battery is isolated from the device using a protective plastic tab, as visible on the picture, which is required to be removed before using the phone. The battery will not charge until this is removed and the modem, WiFi and Bluetooth will not work until the battery is connected.
- Carefully remove the back panel using the notch in the corner of the back cover without overbending it
- Remove the battery (if the battery is stuck in the device please check this paragraph for a fix).
- Peel off the clear plastic sticker below it, which isolates the charging contacts
- Reinsert the battery
For further information, see the section below.
The PinePhone's SIM slot only accepts a micro SIM, as visible on the picture. Please, do not insert a nano SIM without an adapter. An adapter from a nano SIM to a micro SIM may be included under tape in one of the notches of the phone's packaging. The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot, as pictured here:
Specifications
- Dimensions: 160.5 x 76.6 x 9.2mm
- Weight: Between 180 ~ 200 grams
- SIM Card: Micro-SIM
- Display:
- Size: 5.95 inches (151mm) diagonal
- Type: HD IPS capacitive touchscreen, 16M colors
- Resolution: 1440x720, 18:9 ratio
- System on Chip: Allwinner A64
- RAM: 2GB or 3GB LPDDR3 SDRAM
- Internal Storage: 16GB or 32GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
- Back Camera: Single 5MP, 1/4", LED Flash
- Front Camera: Single 2MP, f/2.8, 1/5"
- Sound: Loudspeaker, 3.5mm jack & mic (jack doubles as hardware UART if killswitch 6 is deactivated)
- Communication:
- Modem: Quectel EG25-G
- LTE-FDD: B1, B2, B3, B4, B5, B7, B8, B12, B13, B18, B19, B20, B25, B26, B28
- LTE-TDD: B38, B39, B40, B41
- WCDMA: B1, B2, B4, B5, B6, B8, B19
- GSM: B2, B3, B5, B8 (850, 900, 1800, 1900 MHz)
- WLAN: Wi-Fi 802.11 b/g/n, single-band, hotspot
- Bluetooth: 4.0, A2DP
- GNSS: GPS/GLONASS/BeiDou/Galileo/QZSS, with A-GPS
- Sensors: Accelerometer, gyroscope, proximity, ambient light, compass
- Killswitches: Modem, WiFi & Bluetooth, Microphone, Cameras
- Battery: Lithium-ion, rated capacity 2800mAh (10.64Wh), typical capacity 3000mAh (11.40Wh) (nominally replaceable with any Samsung J7 form-factor battery)
- I/O: USB Type-C, USB Host, DisplayPort Alternate Mode output, 15W 5V 3A Quick Charge, follows USB PD specification
Components
The list of major hardware components of the PinePhone is available in the table below; see also the PinePhone component list and the PinePhone schematics.
Component | Model |
Touchscreen | Goodix GT917S |
Rear camera | OmniVision OV5640 |
Camera flash | SGMICRO SGM3140 |
Front camera | GalaxyCore GC2145 |
LCD | Xingbangda XBD599 |
WiFi | Realtek RTL8723CS |
Bluetooth | Realtek RTL8723CS |
Modem | Quectel EG25-G |
GNSS/GPS | Quectel EG25-G |
Magnetometer | ST LIS3MDL |
Ambient light / Proximity | SensorTek STK3335 |
Accelerometer / Gyroscope | InvenSense MPU-6050 |
Vibration motor | Unknown model |
Notification LED | LED0603RGB |
Volume buttons | Buttons connected to the KEYADC |
Power button | X-Powers AXP803 |
Battery fuel gauge | X-Powers AXP803 |
Hardware revisions
- Project Anakin
- "Project Don't Be Evil" – development kit (devkit)
- PinePhone v1.0 – developer batch
- PinePhone v1.1 – Braveheart
- PinePhone v1.2 – Ubports Community Edition
- PinePhone v1.2a – postmarketOS Community Edition
- PinePhone v1.2b – Manjaro Community Edition, KDE Community Edition, Mobian Community Edition, and Beta Edition
Thermal safety
The PinePhone is based on Allwinner A64, which is an older-generation SoC built on a 40 nm process; as a result, the phone produces quite some heat under medium or high loads, and especially during charging or when using USB accessories such as a docking station. Measurements to prevent damage to the phone and to its surroundings need to be taken by the user. This especially includes proper handling of the phone: do not charge the phone in a way where heat builds up around the phone without being able to escape. Especially do not charge your phone under a pillow or a blanket, or in pockets or bags. Charging the phone produces heat, so charging the phone in a way where the excessive heat cannot dispose around the phone poses an immediate fire risk.
Users might notice that the phone gets warm under usage, compared to other smartphones with more up-to-date hardware. Under normal circumstances these temperatures do not pose a risk while being in the levels within the safe operating temperatures, which are beyond the point where components can be too hot to touch. Higher temperatures might especially be experienced on the top side of the screen and on the inside of the phone, at the RF shield of the modem. The higher temperature of the RF shield of the modem is also caused by the SoC on the opposite side of the main board, and the RF shield of the modem is used to disperse some of the heat produced by the SoC. In newer phone revisions, starting with the revision 1.2a, there are also thermal pads and foils on the back cover and between the SoC's RF shield and the screen, dispersing heat on the screen and on the back cover. In the past there have been safety concerns regarding the thermals, possibly causing heat damage in some cases; see the documentation of those issues by the developer Megous here and here. While the developers are working hard to prevent such issues, they cannot be excluded under all circumstances; see also this section. The users are expected to monitor their phones' thermals at every point at this state of the software.
It is highly recommend to update the phone on a regular basis to always get the latest improvements. The default settings for the performance throttling and emergency shutdowns upon reaching the critical temperatures might be set to a too high point depending on the specific use-case and length of the usage. Under Linux, the phone's thermal management behavior can be modified to achieve lower temperatures and prevent the screen and other components from potentially taking damage; see PinePhone Thermal Tweaks for further details.
Hardware accessories
USB-C connector
The USB-C can be used to power the device, and offers USB2 host and OTG possibilities, and also can make use of the USB-C capability to integrate HDMI signals. Some USB-C hubs are available that offer power throughput, USB connection, HDMI port and Ethernet connection.
Pogo pins
Interrupt | SDA | SCL |
DCIN | USB-5V | GND |
DCIN and USB-5V are the names used in the schematics. The actual behavior of these pogo pins is not obvious based on their names. DCIN is connected both to the VBUS line of the USB Type-C connector, and to the ACIN/VBUS inputs on the PMIC. This means that, depending on a number of factors, DCIN may be at 0 V or 5 V. USB-5V is connected at the output of an LP6226 DC/DC boost converter (5 V), which in turn is fed by the PS output of the PMIC. The boost converter is enabled or disabled by a GPIO output from the A64 SoC, controlled by software (e.g. the Linux kernel). Depending on inputs and decision made by the PMIC, PS may be at the battery voltage (fed "directly" by the battery through a transistor controlled by the PMIC), or at the "USB" voltage (fed by the PMIC's ACIN/VBUS inputs). This means that depending on a number of factors, USB-5V may be at battery voltage (between 3.0 V and 4.3 V), or at 5 V.
Because the PinePhone may act as a USB host (providing 5 V at the USB Type-C connector's VBUS to a connected device) or as a USB device (drawing from a 5 V source on the USB Type-C connector's VBUS), DCIN is actually not strictly an input nor an output. Some community analysis of the PinePhone schematic (and some testing) indicates that you can connect a 5 V power supply to DCIN in order to power the phone at the PMIC's ACIN/VBUS inputs (and, as a side effect, charge the battery). This may not be safe to do in all conditions, e.g., when the phone is acting as a USB host to a connected USB device. It should also be safe to use DCIN as a power output from the PinePhone, e.g., when a USB Type-C charger is connected, you can draw current directly from the USB Type-C port's VBUS, which is provided by the charger. Please note that, when using DCIN as an output from the PinePhone, DCIN isn't "always on"; it may be 0 V. It is currently not documented on how much current can be safely drawn.
USB-5V should be safe to use as an "always on" power output from the PinePhone. Depending on a number of factors, voltage may be from 3 V to 5 V; thus, if you are using USB-5V to power your pogo-pins expansion board, you will probably need to use DC/DC converters/regulators as appropriate. USB-5V is on even while the A64 SoC is powered down.
The I2C and interrupt lines have pull-ups on the phone side. The I2C lines are pulled up to 3v3 by the phone.
Back cover
Community-built accessories
- PinePhone Development Stand at Thingverse
- PinePhone Hard Case by _The3DmaN_ at Thingverse
- PinePhone Hard Case by blitzaxt at Thingverse
Serial console
The PinePhone has a serial port accessible through the headphone connector, which is activated by the sixth position of the DIP switch under the back cover. If the switch is set to the "on" position, the headphone connector is in audio mode; if it is set to "off", the connector is in the UART mode. The UART serial connection can also be used for communication with other devices from the PinePhone.
The parameters for serial communication are 115200n8.
The pinout of the serial connector is as follows:
- Tip: RX
- Ring: TX
- Sleeve: GND
Killswitch configuration
Number | Name | Explanation | Description |
1 | Modem | Pulls Q1501 gate up (FET killing modem power) | "On" enables 2G/3G/4G communication and GNSS hardware, "off" disables it. |
2 | WiFi / Bluetooth | Pulls up CHIP_EN | "On" enables WiFi and Bluetooth communication hardware, "off" disables it. |
3 | Microphone | Breaks microphone bias voltage from the SoC | "On" enables audio input from on-board microphones (not 3.5 mm jack), "off" disables it. |
4 | Rear camera | Pulls up PWDN on OV5640 | "On" enables the rear camera, "off" disables it. |
5 | Front camera | Pulls up PWDN on GC2145 | "On" enables the front camera, "off" disables it. |
6 | Headphone | Pulls up IN2 on analog switch BCT4717ETB | "On" enables audio input and output via the 3.5 mm audio jack, "off" switches the jack to hardware UART mode. |
Camera
Battery
The phone ships with a protective plastic sticker between the battery and the phone to protect the device from turning on during shipping.. You need to gently open the back cover, then remove the battery and finally remove the sticker and check that the pins aren't bent. Note: If the battery is stuck inside the phone, the mid screw in the lower part of the midframe needs to be slightly loosened, see here.
+ve | thermistor | -ve | not connected |
Modem
The PinePhone uses Quectel EG25-G as modem. AT commands are used to communicate with the modem. The software minicom
can be used to send the commands.
To connect with the modem:
minicom -D /dev/ttyUSB2
AT commands
A list of documented AT commands can be found in the EC25&EC21 AT Commands Manual from Quectel. Further undocumented AT commands found by the developer megi, who reverse-engineered parts of the modem and its firmware, can be found on megi's website here.
VoLTE
AT+QMBNCFG="list" +QMBNCFG: "List",0,1,1,"ROW_Generic_3GPP",0x0501081F,201901141 +QMBNCFG: "List",1,0,0,"VoLTE-ATT",0x0501033C,201909271 +QMBNCFG: "List",2,0,0,"hVoLTE-Verizon",0x05010141,201911251 +QMBNCFG: "List",3,0,0,"Sprint-VoLTE",0x05010205,201908141 +QMBNCFG: "List",4,0,0,"Commercial-TMO_VoLTE",0x05010505,201811231 +QMBNCFG: "List",5,0,0,"Telus-Commercial_VoLTE",0x05800C43,201912031 +QMBNCFG: "List",6,0,0,"Commercial-SBM",0x05011C18,201904021 +QMBNCFG: "List",7,0,0,"Commercial-DT",0x05011F1C,201905311 +QMBNCFG: "List",8,0,0,"Reliance_OpnMkt",0x05011B38,201910161 +QMBNCFG: "List",9,0,0,"TF_Germany_VoLTE",0x05010C1B,201909201 +QMBNCFG: "List",10,0,0,"TF_Spain_VoLTE",0x05010CFA,201909261 +QMBNCFG: "List",11,0,0,"Volte_OpenMkt-Commercial-CMCC",0x05012071,201904281 +QMBNCFG: "List",12,0,0,"OpenMkt-Commercial-CT",0x05011322,201911081 +QMBNCFG: "List",13,0,0,"OpenMkt-Commercial-CU",0x05011505,201807052
AT+QCFG="ims",1
AT+CFUN=1,1
To check the status of VoLTE during a call, the AT command CLCC
can be used:
AT+CLCC +CLCC: 1,1,0,1,0,"",128 +CLCC: 2,1,0,1,0,"",128
APN settings
Carrier support
Documents
Firmware update
The modem firmware can be updated to the latest version if it is outdated and dmesg returns the following message:
modem-power serial1-0: Your modem has an outdated firmware. Latest know version is EG25GGBR07A08M2G_01.002.07. Consider updating.
Pre-update checklist:
- The battery needs to be charged sufficiently
- The phone needs to be plugged into a charger
- Deep sleep is recommended to be disabled as it can interrupt the update process
- It is recommended to close all other running applications
- Use common sense while doing the update, don't do the update while being impaired in any way
cd quectel_eg25_recovery
sudo ./qfirehose -f ./
Firmware modifications
GPS / GNSS
The GPS engine in the modem supports mutli-GNSS reception from GPS, GLONASS, BeiDou, Galileo and QZSS independent of a cellular connection. The operation of the GNSS subsystem is controlled via a separate set of AT commands. The AGPS data upload uses the file management AT commands, which also have their own manual. These are linked in the documentation section below.
As with most smartphones, the PinePhone has a small antenna and has difficulty getting a first fix without assistance data, a cold start can take 15 minutes under good conditions. While the hardware supports AGPS data upload, it isn't yet implemented in current distributions. There is a proof of concept script which can be made to work, but support needs to be added to ModemManager, oFono etc. before it will be easy to use.
Basic testing of GNSS reception can be done by using the AT command interface (/dev/ttyUSB2) from a terminal progam like minicom and the data output interface (/dev/ttyUSB1) to feed NMEA data into gpsmon or some other progam that can parse standard NMEA sentences.
cat /dev/ttyUSB1
$GPVTG,,T,,M,,N,,K,N*2C $GPGSA,A,1,,,,,,,,,,,,,,,,*32 $GPGGA,,,,,,0,,,,,,,,*66
Voice mail
In Canada, Rogers voicemail can be called by dialing *98
Operating systems
Software releases
Installation instructions
Relevant subsections of the article for installing OSes to the PinePhone are:
- Boot priority
- Installation to the microSD
- Installation to the eMMC
- Resize partition to fit disk space
- Reuse SD card for data storage on system booting from eMMC
Frequently asked questions
Modifications and repairs
Replacing the mainboard
Alternatively, user bridadan uploaded a video tutorial of the swap procedure including camera swap and proximity sensor housing here: https://www.youtube.com/watch?v=J3AJEF7akkw.
- You’ll need a small Phillip’s screwdriver and a prying tool to swap out the PinePhone’s mainboard.
- Remove the PinePhone’s back cover. See your quick start guide for details.
- Remove the battery as well as any inserted SD and SIM cards.
- Unscrew all 15 Phillip’s head screws around the midframe of the phone.
- Gently pry up the midframe using a guitar pick or credit card corner. It is easiest to separate the midframe at one of the bottom edges. Work your way around all the sides of the phone until the midframe separates from the phone’s body.
- Detach all ribbon cables and “Lego” connectors. List of things to detach: 1) two “Lego” connects at the bottom of the mainboard. 2) u.FL antenna connect and touchscreen digitizer on PCD left side. 3) LCD ribbon cable top of mainboard, next to audio/ UART jack.
- Pry the mainboard up gently from the left-hand side.
- Remove front and main cameras and reset them into the new mainboard.
- Check that the rubber proximity sensor housing is in the chassis, not stuck to the removed mainboard.
- Place the new mainboard in the chassis, hooking in on the plastic tabs on left side and pressing down firmly on opposite side, and follow the steps (7-2) in reverse. When reattaching the midframe take care that no cables are out of place or trapped, as they may be damaged when tightening screws.
Flashing the ANX firmware
Method 1
Download the latest ANX7688 firmware image on the phone:
cp anx7688-fw.bin /lib/firmware/ echo 1 > /sys/class/typec/port0/device/flash_eeprom
Method 2
Booting a factory test image will automatically flash the ANX7688 chip. See PinePhone Software Releases#Factory-loaded postmarketOS build for such an image.
Replacing the screen
- Make sure you have a precision screwdriver set that has the correct size Philips tip. The screws are very small and the heads can easily be stripped if the screwdriver is not correct - if you feel your screwdriver slipping, stop what you are doing and try one that is a better fit. A magnetized screwdriver will help in not losing screws, as will a magnetic parts holder to keep them in while working.
- There are a number of components and cables as well as the insulator sheet under the battery that are glued in place. A hair dryer will loosen the glue and make them much easier to remove. You may want to order extra cables along with the screen just in case.
- The vibration motor, which is part of the USB-C board assembly and glued into place, will come apart easily and be damaged if you pry it up in the wrong place. Make sure you pry from underneath the complete part, not midway on its housing. The ribbon cable attaching this to the USB-C board is small, thin, and fragile so be careful with that as well.
- The new screen comes with new side switches and insulator sheet but there are a number of parts that need to be transferred from the old screen, like the thin coax cable running up the side, the phone ear speaker, proximity sensor gasket, and a gold-colored mesh glued in place that needs to be transferred to a flexible circuit included on the new screen. If you don't swap over the proximity sensor rubber gasket the screen will immediately turn off after logging in. Be careful when routing the coax cable that it goes around the screw holes or you may drive a screw right through the cable.
Spare parts not available in the Pine64 store
- Earpiece dimensions: 12x6x2 mm. Compatible with Xiaomi Mi2 / Mi3 / Mi4, Lenovo A536 and others, see here
- Loudspeaker dimensions: 15x11x3 mm. Compatible with Nokia N91, Lenovo A536 and others, see here
- Proximity sensor rubber isolator
Press
- PinePhone mainboard schematic:
- PinePhone mainboard Released Schematic ver 1.2b
- PinePhone mainboard Released Schematic ver 1.2a
- PinePhone schematic ver 1.2 change list
- "Braveheart" PinePhone mainboard Schematic ver 1.1
- "Braveheart" PinePhone mainboard component top placement drawing ver 1.1
- "Braveheart" PinePhone mainboard component bottom placement drawing ver 1.1
- PinePhone component list
- PinePhone USB-C small board schematic:
- PinePhone certifications:
- PinePhone FCC Certificate
- RF Exposure SAR Information from FCC ID site
- PinePhone CE RED Certificate
- PinePhone ROHS Report
- Note: PinePhone's GSMA TAC (Type Allocation Code) is 86769804
- Allwinner A64 SoC information:
- X-Powers AXP803 PMIC (Power Management IC) information:
- LPDDR3 (178 Balls) SDRAM:
- eMMC information:
- CMOS camera module information:
- LCD touch screen panel information:
- Lithium battery information:
- WiFi/BT module information:
- LTE module information:
- Sensors:
- Digital video to USB-C bridge:
- Case information:
- Other components:
- See links in the Component List
Developer works
The following resources have been made available by Megous, one of the developers:
- Getting started with PinePhone Hardware
- State of development progress
- PinePhone Technical News and Update, also applies to other Allwinner devices including PINE A64 SBC
- Contributions to the kernel development
