PineNote Development/TODOs
Back to PineNote main page
Status
Functionality Component Status (factory) Status (updated) Notes
Bootloader Bootloader Android only WIP for Linux Booting into linux requires a patched uboot. Instructions here.
Operating System Stability WIP Users have successfully booted Arch, Manjaro, and Debian. Debian has most support right now.
Suspend Works This kernel patch adds suspend support.
Updates WIP GPU libs (mesa) and mutter rely on patched packages. These should not be updated via the package manager at the moment, make sure to exclude them.
Networking Works
Components E-Paper Display WIP Mostly functional. There is some ghosting and work remains, but the device and screen are usable.
Touch Works
Bluetooth Works, audio stutters Switching the driver provides stable connections for keyboards, but audio still stutters. Trying to fix this here.
Sensors Unsure Light sensors? Rotational sensors?
Buttons Works Power button works.
Accessory compatibility, spare parts Spare parts Not available yet Spare parts currently not available yet in the store.
Software notes Firefox GPU Rendering Possible Requires patched mesa and
MOZ_ENABLE_WAYLAND=1
. See here.
Kernel/driver TODOs
These exist, but they haven't been written down yet.
Userspace TODOs
The TODOs in this space are organized around what functionality they enable. A table of the important functions that a user may want in the Pinenote and a status are listed below:
Functionality Approaches (apps) Level of support (subjective) Supports Does not yet support Notes
Reading Documents Koreader Great Fully featured ebook reader; Supports many filetypes; Handwritten notes Large user base on many devices; codebase has a somewhat of a reputation for being messy
Xournalpp Good Reading/writing PDFs and other files; No definition support (long-press for definition) Billed more as a note-taking app than a document reading app
Themes
A lot of getting the PineNote to work nicely will be theming things appropriately. Please list themes for various components here:
GNOME
Untested as far as I know: https://github.com/fujimo-t/gnome-shell-theme-e-ink
GTK
Todo
GNOME Configurations
See here.
Sway Configurations
See here.
Open questions that would be helpful during development
  1. How do we pin packages so Mesa isn't updated when we update using our package manger?
Documentation TODOs
Note: These are things we know how to do, but they just haven't been documented in the wiki yet. If you know how to do one of these things, please make a page for it. If you aren't sure where to put it or just don't feel like doing it, please just message @aarondabomb on matrix and I'll be happy to document it.
Pin Mesa Packages so they don't update when we upgrade other packages
Should be super simple, I just don't know how. If you know, it would be helpful for you to add that information near step 5 here.
Control the backlight?
Building alacritty correctly
Force a screen refresh?
Maximilian mentioned how to do this, but I don't know enough to know what it means XD see conversation here: https://matrix.to/#/!QtTzSRYMuozjbOQkzJ:matrix.org/$tfumBpnP2UPouNpaeFrggR40ZkrD_pHAtJdQmQvzL-o?via=matrix.org&via=kde.org&via=tchncs.de
Trying to fix bluetooth
I tried to add latency as described here, but to no avail. I noticed the best performance with SBC codec, but still not usable.
Preliminary fix for stuttering bluetooth audio:
Following a fix used for the Quartz Model A (which uses the same SoC as the Pinenote), we can modify the device tree prior to building the kernel to try to mitigate poor bluetooth audio streaming. (reference: see https://lore.kernel.org/linux-arm-kernel/20220926055435.31284-1-leo@nabam.net/T/)
Steps:
  • Open arch/arm64/boot/dts/rockchip/rk3566-pinenote.dtsi
  • Go to line 939, "bluetooth", under the "uart1" section
  • Edit the two lines that read "device-wake-gpios" and "host-wake-gpios"; you want them to read "device-wakeup-gpios" and "host-wakeup-gpios" respectively
  • Add the following line to the end of the bluetooth section (under the vddio-supply line in my .dtsi): "max-speed = <3000000>;"
  • Count your zeros, don't forget your punctuation..
Caveats:
This will improve BT audio quality at least when using the AAC codec. In my experience, the quality is more than acceptable, but there are still issues apparent: occasional isolated stutters even on AAC; prohibitively frequent stutters on SBC-XQ remain. Fully resolving BT audio issues might require further changes similar to the one described above, or may alternatively be a matter of audio software settings (e.g., process priority, audio server buffer settings). Investigation ongoing..
