PineNote Development/Software Tweaks
Revision as of 20:49, 12 January 2023 by Fxc (talk | contribs) (+cat)
Fixing Bluetooth
Some users have noticed instability with their wireless driver. Upgrading the driver to the version provided by LibreELEC may help! To do this, download the BCM4345C0.hcd, brcmfmac43455-sdio.bin, and brcmfmac43455-sdio.txt from the libreELEC repositories and place them in the same location as your previous firmware (`/lib/firmware/brmc/`). Then rename brcmfmac43455-sdio.{txt,bin} as `brcmfmac43455-sdio.pine64,pinenote-v1.2.{txt,bin}`. If this doesn't help, ask about it in the matrix chat!
Autoconnect to your Bluetooth devices
This bluetooth-autoconnect project may help.
Preliminary fix for stuttering bluetooth audio
Following a fix used for the Quartz Model A (which uses the same SoC as the Pinenote), we can modify the device tree prior to building the kernel to try to mitigate poor Bluetooth audio streaming. (reference: see https://lore.kernel.org/linux-arm-kernel/20220926055435.31284-1-leo@nabam.net/T/)
Steps:
  • Open arch/arm64/boot/dts/rockchip/rk3566-pinenote.dtsi
  • Go to line 939, "bluetooth", under the "uart1" section
  • Edit the two lines that read "device-wake-gpios" and "host-wake-gpios"; you want them to read "device-wakeup-gpios" and "host-wakeup-gpios" respectively
  • Add the following line to the end of the bluetooth section (under the vddio-supply line in my .dtsi): "max-speed = <3000000>;"
  • Count your zeros, don't forget your punctuation..
Caveats:
This will improve BT audio quality at least when using the AAC codec. In my experience, the quality is more than acceptable, but there are still issues apparent: occasional isolated stutters even on AAC; prohibitively frequent stutters on SBC-XQ remain. Fully resolving BT audio issues might require further changes similar to the one described above, or may alternatively be a matter of audio software settings (e. g., process priority, audio server buffer settings). Investigation ongoing.
