PineNote Development
This article seeks to provide general development information for the PineNote
Flashing Software
Currently, the only way to flash software is using rkdeveloptool.
Using rkdeveloptool
rkdeveloptool is a command line utility built on libusb.
Downloading and Building rkdeveloptool
PINE64 develops its own updated fork of rkdeveloptool on GitLab.
You will need to have libusb 1.0 and its development headers installed.
git clone https://gitlab.com/pine64-org/quartz-bsp/rkdeveloptool.git cd rkdeveloptool mkdir build cd build cmake ..
This sets up all the build files. You can then compile with make
inside the build directory.
After you're done, you'll likely also need to install the udev rules, or else your user won't have permission to access the USB devices:
sudo cp 99-rk-rockusb.rules /etc/udev/rules.d/ sudo udevadm --control reload
Building Downstream U-Boot
While in maskrom mode, we need to have a u-boot to download onto the device for any of the other commands to work.
git clone -b quartz64 https://gitlab.com/pgwipeout/u-boot-rockchip.git git clone -b rkbin https://github.com/JeffyCN/rockchip_mirrors.git rkbin cd u-boot-rockchip export CROSS_COMPILE=aarch64-none-linux-gnu- make rk3566-quartz64_defconfig ./make.sh
Running rkdeveloptool
First, you'll want to make sure the device you've connected is in maskrom mode:
./rkdeveloptool ld
It should output something like DevNo=1 Vid=0x2207,Pid=0x350a,LocationID=202 Maskrom
. If it doesn't, see PineNote Development#Entering Maskrom Mode.
TODO: finish this section
- Flip the device around so that the display faces down
- Lay the pen on the right side, with its tip pointing towards the speaker grill, and its magnet pointing towards the upper right corner of the label on the back.
- Turn the device on and check
rkdeveloptool ld
output to verify that you are in maskrom mode
This can be a bit fiddly to get right, and may need a few tries.
