PineNote
Revision as of 21:20, 6 January 2022 by Sqrtroot (talk | contribs) (Added section about USB-C Uart dongle)
The PineNote
The PineNote is the first hybrid notepad computer device combination of notebook, tablet and e-reader using an e-ink panel. It is derived from the Quartz64 model A SBC and powered by a Rockchip RK3566 quad-core ARM Cortex A55 64-bit processor with a MALI G-52 GPU.
Specification
General Information
  • Dimensions: 191.1x232.5x7.4mm
  • Weight: 438g
Core
  • CPU: RK3566 1.8GHz 64-bit quad-core A55
  • GPU: MALI G52 2EE
  • System memory: 4GB LPDDR4
  • Flash: 128GB eMMC
E-ink Display
  • Size: 10.3"
  • Resolution: 1404x1872
  • DPI: 227
  • Grayscale: 16
  • Front Light: 36 level cold and warm
  • Capacitive multi-touch panel
  • EMR pen digitizer
Network
  • WiFi: 2.4/5GHz 802.11a/b/g/n/ac
  • Bluetooth: 5.0
Audio
  • Built in stereo speakers
  • 4 x DMIC microphone
Sensor
  • G-Sensor for portrait and landscape sensing
Power
  • 4000mAH LiPo battery
  • DC 5V @ 3A USB-C connector
Accessories
  • Optional EMR pen with magnetic attachment (included in the first production batch)
  • Optional Cover (included in the first production batch)
Software releases
  • Not yet available
SoC and Memory Specifications
  • 22nm process, believed to be FD-SOI
  • Supports Vulkan 1.0 and 1.1
NPU (Neural Processing Unit) Capabilities
  • RAM Memory : 4GB LPDDR4.
  • Flash Memory: 128GB eMMC
PineNote Information, Schematics, and Certifications
  • Certifications:
    • Not yet available
Development Efforts
  • PineNote Development for general information regarding how to flash the device and other development information.
Software
Hardware
This section includes discussions and their results regarding hardware changes to the PineNote.
The following topics have resolved:
  • PineNote/Hardware_Changes/Closed_Case_UART
  • Could the USB-C port support USB 3.1 5Gbps? Yes and no. The RK3566 only has a host-mode 5Gbps controller, meaning it can only negotiate such a high data rate with a device such as a flash drive. When the RK3566 is acting as a device, it only supports 480Mbps transfer rates. The hardware required to switch between these modes would raise the PineNote's price unreasonably. Therefore, the USB-C port will remain at USB 2.0 speeds for Host and Device mode.
  • Could the USB-C port output DisplayPort? Yes and no. The hardware required to support such a feature would raise the PineNote's price unreasonably. Therefore, DisplayPort output will not be possible through the USB-C port.
  • Where is the microSD card slot? The case design of the PineNote is fixed, making physical changes like adding a microSD card slot would raise the cost unreasonably. However, revisions of the PineNote motherboard after 1.1 will feature an internal ribbon cable connector where a microSD card slot may be attached. Attaching such a device will require taking the PineNote apart.
  • How will I install software to the PineNote? This is a hardware and software question. If the software on your PineNote is completely broken and cannot boot to a recoverable state, a Hall (magnet) sensor was fitted to the PineTab motherboard as U9009. This sensor is attached to SARADC_VIN0_KEY/RECOVERY on the RK3566. With the device powered off, and screen face down, holding a magnet over U9009 and plugging in a USB-C cable causes the device to boot into "rockusb" flash mode. With proper flashing software and drivers, it should be possible to load a new operating system using rockusb if the system is soft-bricked. Of course, software vendors will need to be more careful with flashing firmware and providing useful "recovery" options on this device due to this process's relative difficulty to other PINE64 devices.
Unresolved
The following concerns have been brought up as open, unanswered topics:
  • Does Audio Adapter Accessory Mode work? It appears that the Headphone output of the audio codec was routed to the USB-C audio+USB switch, but it's unclear whether CC lines are hooked up correctly for detection of such a device. The PineNote hardware team will be testing this functionality soon (as of August 19, 2021). Note that Audio Accessory mode is detectable by reading the I2C registers of the WUSB3801Q. So connecting ASEL to a GPIO would be enough to get this working if it is not working already.
  • Why is the Headphone output of the audio codec routed to the speakers? HPL_OUT is routed from the RK817 PMIC and audio codec to U9010 (the USB-C switch) and U6 (the audio amplifier). SPK_OUT is unused. It seems like SPK_OUT should be routed to U6 and HPL_OUT to U9010.
  • Nitpick: The cold white charging LED bleeds through the gap between the rear case and the device's face. It does not bleed onto the screen, but it is jarring in low-light conditions or when the screen is amber. Could be resolved in software by turning off the charge LED when the screen is on.
  • Is there any way to indicate when the device is in rockusb mode, such as connecting a certain magic pin to the power LED?
  • The modem/4G connector (J6010) has its I2C and UART pins unconnected. Could those be connected to the SoC?
USB-C Debug Accesory Mode (DAM)/UART Dongle
The USB UART dongle delivered with the PineNote allows you to have access to a serial port without having to open up the device. The factory firmware runs at a baud rate of 1500000bps, 8 data bits 1 stop bit, no parity and no flow control. The USB-C male end should go into the PineNote and the female end can be connected with a standard USB-C cable to your computer.
BSP Linux SDK
BSP Linux SDK ver 4.19 for PineNote and Quart64 model A SBC
Android SDK
Android 11 eink SDK for PineNote and Quart64 model A SBC
Torrent
There is a torrent with the files (100GB)
Hardware troubleshooting guide
At present, nothing is available.
