PineNote
Revision as of 16:30, 19 August 2021 by Arwen (talk | contribs) (→‎Android SDK: Add section for hardware troubleshooting)
The PineNote is the first hybrid notepad computer device combination of notebook, tablet and e-reader using an e-ink panel. It is derived from the Quartz64 model A SBC and powered by a Rockchip RK3566 quad-core ARM Cortex A55 64-bit processor with a MALI G-52 GPU.
Specification
General Information
  • Dimensions: 191.1x232.5x7.4mm
  • Weight: 438g
Core
  • CPU: RK3566 1.8GHz 64-bit quad-core A55
  • GPU: MALI G52 2EE
  • System memory: 4GB LPDDR4
  • Flash: 128GB eMMC
E-ink Display
  • Size: 10.3"
  • Resolution: 1404x1872
  • DPI: 227
  • Grayscale: 16
  • Front Light: 36 level cold and warm
  • Capacitive multi-touch panel
  • EMR pen digitizer
Network
  • WiFi: 2.4/5GHz 802.11a/b/g/n/ac
  • Bluetooth: 5.0
Audio
  • Built in stereo speakers
  • 4 x DMIC microphone
Sensor
  • G-Sensor for portrait and landscape sensing
Power
  • 4000mAH LiPo battery
  • DC 5V @ 3A USB-C connector
Accessories
  • Optional EMR pen with magnetic attachment (included in the first production batch)
  • Optional Cover (included in the first production batch)
  • Not yet available
SoC and Memory Specifications
  • 22nm process, believed to be FD-SOI
  • Supports Vulkan 1.0 and 1.1
NPU (Neural Processing Unit) Capabilities
  • RAM Memory : 4GB LPDDR4.
  • Flash Memory: 128GB eMMC
PineNote Information, Schematics, and Certifications
  • Certifications:
    • Not yet available
Development Efforts
Software
Hardware
This section includes discussions and their results regarding hardware changes to the PineNote.
Closed-Case UART
Developers usually don't like taking their devices apart to debug bootloaders. Therefore, it is important to provide resources to debug the PineNote's boot process such as a hardware UART. Recent PINE64 devices have included a hardware UART connected to their 3.5mm TRRS jacks through a hardware switch. However, the PineNote doesn't have an audio jack. It also doesn't have a convenient place to put a hardware switch which is accessible without taking the device apart. The case only has the affordance for a single USB-C port.
We decided to ask the PineNote product team to explore USB-C Debug Accessory Mode, where the product changes the USB-C port's personality when both CC1 and CC2 are pulled high. In normal usage, either CC1 or CC2 will be floating since these are the connector rotation pins. When both are detected, there is a very good chance that a debug harness is connected.
This decision requires the PineNote motherboard to be able to detect an AND condition between CC1 and CC2 and connect one of the SOC's UARTs to pins on the USB-C connector. In all other cases, the UART should be disconnected. It also requires the PINE64 Store ship a simple one-sided (no magical flipping here, sorry) connector board which breaks out USB 2.0 and UART.
There were concerns that cheap USB-C cables have both CC1 and CC2 shorted together to save a wire. This may cause the PineNote to output 3.3v UART to a device that isn't expecting it, assuming the two are plugged together with a nonstandard cable. This seems unfounded (or not enough of a problem to worry about on a large scale), since the USB-C specification states in section B.2.3.1, "The general concept for setting up a valid connection between a DTS and TS is based on being able to detect the typical USB Type-C termination resistances. However, detecting a Debug Accessory Mode connection requires that both CC pins must detect a pull-up (Rp) or pull-down (Rd) termination. A USB Type-C Cable does not pass both CC wires so a receptacle to receptacle Debug Accessory Mode connection cannot be detected."
There were concerns that checking CC1 and CC2 being pulled high was not strictly to USB-C standard, as detecting them being pulled low is mentioned in the standard. However, detecting a pull-up condition is all that is required. According to the USB-C spec, 'B.2.4.1.5.1 ("UnattachedDeb.SRC Requirements"), a Debug and Test System (DTS) that is a power source must pull CC1/CC2 up, while the Target System (TS) in Unattached.SNK is supposed to pull them low.' In English, this means that we'd only need to detect a pull-up condition on CC1 and CC2, meaning a logical AND between them is a sane solution. IRC logs of this discussion can be found at PineNote/Debug_Accessory_Mode_Discussion.
It should be possible to make the UART connection and breakout cable magically flippable by connecting the UART multiple times to the USB-C port.
BSP Linux SDK
BSP Linux SDK ver 4.19 for PineNote and Quart64 model A SBC
Android SDK
Android 11 eink SDK for PineNote and Quart64 model A SBC
Hardware troubleshooting guide
At present, nothing is available.
