PineNote
Revision as of 18:38, 15 August 2021 by Tllim (talk | contribs)
The PineNote is the first hybrid NotePad computer device combination of Notebook, Tablet and eReader using an e-ink panel. It is derived from the Quartz64 model A SBC and powered by a Rockchip RK3566 Quad-Core ARM Cortex A55 64-Bit Processor with a MALI G-52 GPU.
Specification
  • Dimensions: 191.1x232.5x7.4mm
  • Weight: 438g
Core
  • CPU: RK3566 1.8GHz 64-bit Quad-core A55
  • GPU: MALI G52
  • System RAM: 4GB LPDDR4
  • Flash: 128GB eMMC
e-ink Display
  • Size: 10.3"
  • Resolution: 1404x1872
  • DPI: 227
  • Grayscale: 16
  • Touch Panel
  • EMR Pen
  • Front Light: 36 level cold and warm
Network
  • Wifi: 2.4/5GHz 802.11a/b/g/n/ac
  • Bluetooth: 5.0
Audio
  • Build in stereo speaker
  • 4x high sensity DMIC microphone
Sensor
  • G-Sensor for Portrait and Landscape sensing
Power
  • 4000mAH LiPo Battery
  • DC 5V @ 3A USB-C connector
Accessories
  • Optional EMR Pen with magnetic attached (Free to first production batch)
  • Cover (Free to first production batch)
  • Not yet available
SoC and Memory Specifications
  • 22nm process, believed to be FD-SOI
  • Supports Vulkan 1.0 and 1.1
NPU (Neural Processing Unit) Capabilities
  • RAM Memory : 4GB LPDDR4.
  • Flash Memory: 128GB eMMC
PineNote Information, Schematics, and Certifications
  • Certifications:
    • Not yet available
Development Efforts
BSP Linux SDK
BSP Linux SDK ver 4.19 for PineNote and Quart64 model A SBC
Android SDK
Android 11 eink SDK for PineNote Quart64 model A SBC
