PineNote
Revision as of 17:05, 15 August 2021 by Tllim (talk | contribs)
The PineNote is the first hybrid NotePad computer device combination of Notebook, Tablet and eReader using e-ink panel. It is derived from Quartz64 model A SBC and powered by a Rockchip RK3566 Quad-Core ARM Cortex A55 64-Bit Processor with a MALI G-52 GPU.
  • Not yer available
SoC and Memory Specifications
  • 22nm process, believed to be FD-SOI
  • Supports Vulkan 1.0 and 1.1
NPU (Neural Processing Unit) Capabilities
  • RAM Memory : 4GB LPDDR4.
  • Flash Memory: 128GB eMMC
Network
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
Display
Input Power
  • DC 5V @ 3A USB-C connector
Dimensions and Weight
  • Dimensions: 191.1x232.5x7.4mm
  • Weight: 438g
PineNote Information, Schematics, and Certifications
  • Certifications:
    • Not yet available
Development efforts
BSP Linux SDK
BSP Linux SDK ver 4.19 for PineNote and Quart64 model A SBC
Android SDK
Android 11 eink SDK for PineNote Quart64 model A SBC
