PineModems
Revision as of 04:32, 30 August 2021 by Biktorgj (talk | contribs) (Small updates to the partition table description)
Modems used in Pine64 boards and devices
Quectel EG25-G Modem
Quectel EG25-G is an LTE Cat 4 module optimized specially for M2M and IoT applications. It is used in the PinePhone.
Specifications
Processor Family Qualcomm MDM9607
CPU Qualcomm MDM9207
Cores 1 ACPU Core, Qualcomm Hexagon DSP
Total RAM 256Mb
Total flash space 256Mb
Available RAM for the ACPU 160Mb
NAND Partition table layout
Index Name Description
MTD0 SBL Secondary Bootloader, called from the BootROM. Used to start the TrustZone kernel and the Application Bootloader (LK). Also used to enter Quectel's recovery mode
MTD1 mibib NAND Partition table
MTD2 EFS2 IMEI and settings used by the ADSP are stored here
MTD3 sys_rev Unexplored
MTD4 rawdata This is where FOTA update data exists before being commited to system or recoveryfs partitions
MTD5 tz TrustZone kernel
MTD6 rpm Resource / Power Manager
MTD7 cust_info Unexplored
MTD8 aboot Application Bootloader. Uses LK (LittleKernel, LK embedded kernel) as the bootloader. By default it allows flashing unsigned images but won't allow booting them, soft-bricking the modem until you enter EDL mode
MTD9 boot OpenEmbedded boot kernel + DTB
MTD10 recovery Recovery kernel (used for FOTA updates)
MTD11 modem ADSP firmware blobs
MTD12 misc Some settings are stored here, along with commands that need to be picked by LK on next boot (to reboot to fastboot or recovery mode)
MTD13 recoveryfs Recovery filesystem image (FOTA updates)
MTD14 usr_data User data partition (/data when mounted by OpenEmbedded)
MTD15 sec Used to blow fuses in the mdm9207 from images generated by Qualcomm Sectools
MTD16 system Linux OpenEmbedded root image, formatted in UBIFS (Unsorted Block Image File System, Wikipedia)
Firmware Recovery
Warning: The following instructions are directed towards expert-level users and developers!
The System partition is mounted as read-only mode, but the data partition is writable. It might be possible, if there's an unexpected reset or power is lost while running, that the data partition gets corrupt and thus unable to boot.
PinePhone USB_BOOT test points
The modem has 4 different boot modes:
  • Normal boot
  • Recovery mode (used by the modem usually to install a FOTA update)
  • Fastboot mode
  • Qualcomm EDL Mode
If the modem is unable to boot, depending on the type of crash, it might:
  • not show anywhere (USB device missing)
  • or malfunction (no radio but USB working)
  • or enter EDL mode, if the entire flash is corrupt.
Boot the device in EDL mode
To check if the device is booted in EDL mode, run lsusb (a part of the usbutils package) in a terminal and inspect the output. You should see the following device listed:
Bus 003 Device 003: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode)
In any scenario, the modem can be triggered to enter EDL mode by shorting two test pins on the PinePhone motherboard.
  1. Power off the phone
  2. short the two test points
  3. boot the phone while keeping the test points shorted until fully booted up, at least until you hear the camera clicking twice (which is normally when the modem is powered).
Get the Firmware Recovery Package
The Firmware Recovery Package is at: https://github.com/Biktorgj/quectel_eg25_recovery
Either clone its repo with git, or download its archive & unzip it.
As you should have no access to the Internet on PinePhone when its modem need a Recovery, you can fetch it on other devices and copy it to the Pinephone.
Execute the Quectel QFirehose utility
Once in EDL mode, open a terminal, navigate to the root directory of the recovery package, and run:
  • If you use an ARM64 distribution (most likely): sudo ./qfirehose -f ./ or sudo ./qfirehose_arm64 -f ./
  • If you use an ARMHF (32 bit) distribution: sudo ./qfirehose_armhf -f ./
It will reboot the modem after finished. After about 30 seconds, it will get back up and running. To check the firmware version after that, use an AT command AT+QGMR like at PinePhone#Firmware_update.
Bootloader unlocking
The Modem has a locked bootloader. It won't allow to boot unsigned Kernel images, but will allow to flash them, making it easy to brick the modem. To fix this, you can flash an unlocked bootloader, which will then allow you to do as you please with the hardware.
Unlocked bootloader:
Custom Kernels and system images
Custom kernel builds and system images can be created for the modem, though they require a couple of things to be correctly built and be bootable.
  • The source code release for the kernel provided by the manufacturer is incomplete and won't build
  • Common Android tools like mkbootimg and dtbtool won't build a bootable image, even if the kernel is correctly compiled and all the DTBs attached.
  • Further, there's no source for the OpenEmbedded parts, so building a new system image must be done from scratch, and retrieving the mandatory binary blobs to use the ADSP part of the modem.
There's a work in progress SDK to allow creating custom kernels and system images, which can be downloaded from the following repository: https://github.com/Biktorgj/pinephone_modem_sdk
See its readme for infomations and instructions. Once downloaded, you should run the init.sh script, which will create all the base directories and download all the different repositories required to build. After the initial setup is complete, runmake without arguments to list the available options.
