PineCube
Revision as of 22:11, 28 October 2020 by Fxc (talk | contribs) (https)
PAGE UNDER CONSTRUCTION, INFO SUBJECT TO CHANGE
Specifications
  • Dimensions: 55mm x 51mm x 51.5mm
  • Weight: 55g
  • Storage:
    • MicroSD slot, bootable
    • 128Mb SPI Nor Flash, bootable
  • Cameras: OV5640, 5Mpx
  • CPU: Allwinner(Sochip) ARM Cortex-A7 MPCore, 800MHz
  • RAM: 128MB DDR3
  • I/O:
    • 10/100Mbps Ethernet with passive PoE
    • USB 2.0 A host
    • 26 pins GPIO port
      • 2x 3.3V Ouptut
      • 2x 5V Output
      • 1x I2C
      • 2x UART
      • 2x PWM
      • 1x SPI
      • 1x eMMC/SDIO/SD (8-bit)
      • 6x Interrupts
      • Note: Interfaces are multiplexed, so they can't be all used at same time
    • Internal microphone
  • Network:
    • WiFi
  • Screen: optional 4.5" RGB LCD screen
  • Misc. features:
    • Volume and home buttons
    • Speakers and Microphone
  • Power DC in:
    • 5V 1A from MicroUSB Port or GPIO port
    • 4V-18V from Ethernet passive PoE
  • Battery: optional 950-1600mAh model: 903048 Lithium Polymer Ion Battery Pack, can be purchase at Amazon.com
PineCube board information, schematics and certifications
  • LCD touch screen panel information:
  • Lithium battery information:
Operating Systems
Mainlining Efforts
Linux kernel
Type Link Available in version
Devicetree Entry Pinecube https://lkml.org/lkml/2020/9/22/1241 expected in 5.10
Correction for AXP209 driver https://lkml.org/lkml/2020/9/22/1243 5.9
U-boot
PineCube Board Support https://patchwork.ozlabs.org/project/uboot/list/?series=210044 Waiting for merge
Buildroot
NixOS
Buildroot
Elimo Engineering integrated support for the PineCube into Buildroot.
This has not been merged into upstream Buildroot yet, but you can find the repo on Elimo's GitHub account and build instructions in the board support directory readme. The most important thing that this provides is support for the S3's DDR3 in u-boot. Unfortunately mainline u-boot does not have that yet, but the u-boot patches from Daniel Fullmer's NixOS repo were easy enough to use on buildroot. This should get you a functional system that boots to a console on UART0. It's pretty fast too, getting there in 1.5 seconds from u-boot to login prompt.
Stock Linux
SDK
Stock Linux
How to compile
You can either setup a machine for the build environment, or use a Vagrant virtual machine provided by Elimo Engineering
On a dedicated machine
Recommended system requirements:
  • OS: (L)Ubuntu 16.04
  • CPU: 64-bit based
  • Memory: 8 GB or higher
  • Disk: 15 GB free hard disk space
Install required packages
sudo apt-get install p7zip-full git make u-boot-tools libxml2-utils bison build-essential gcc-arm-linux-gnueabi g++-arm-linux-gnueabi zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32z1-dev
Install older Make 3.82 and Java JDK 6
pushd /tmp
wget https://ftp.gnu.org/gnu/make/make-3.82.tar.gz
tar xfv make-3.82.tar.gz
cd make-3.82
./configure
make
sudo apt purge -y make
sudo ./make install
cd ..
# Please, download jdk-6u45-linux-x64.bin from https://www.oracle.com/java/technologies/javase-java-archive-javase6-downloads.html (requires free login)
chmod +x jdk-6u45-linux-x64.bin
./jdk-6u45-linux-x64.bin
sudo mkdir /opt/java/
sudo mv jdk1.6.0_45/ /opt/java/
sudo update-alternatives --install /usr/bin/javac javac /opt/java/jdk1.6.0_45/bin/javac 1
sudo update-alternatives --install /usr/bin/java java /opt/java/jdk1.6.0_45/bin/java 1
sudo update-alternatives --install /usr/bin/javaws javaws /opt/java/jdk1.6.0_45/bin/javaws 1
sudo update-alternatives --config javac
sudo update-alternatives --config javaws
popd
Unpack SDK and then compile and pack the image
7z x 'PineCube Stock BSP-SDK ver1.0.7z'
mv 'PineCube Stock BSP-SDK ver1.0' pinecube-sdk
cd pinecube-sdk/camdroid
source build/envsetup.sh
lunch
mklichee
make -j3
pack
Using Vagrant
You can avoid setting up your machine and just use Vagrant to spin up a development environment in a VM.
Just clone the Elimo Engineering repo and follow the instructions in the readme file
After spinning up the VM, you just need to run the build:
lunch
mklichee
make -j3
pack
