PineBuds Pro
Revision as of 06:18, 21 December 2022 by Tllim (talk | contribs)
The PineBuds Pro
The PineBuds Pro are open firmware capable ANC wireless earbuds. Some of the notable features include their light weight, 3 Microphones, ANC (Active Noise Cancellation), ENC (Environment Noise Cancellation) and high fidelity 6mm speaker. It is a fully community-driven side-project which anyone can contribute to, allowing you to keep control of your device even though hardware is proprietary.
Software releases
Firmware Images Build
Flash back factory default firmware using Windows based utility:
SDK Release
SoC and Memory Specification
SoC Architecture
    • CMOS Single-chip Fully-integrated RF, PMU, Audio CODEC and Cortex-M4F CPU
    • 4MB Serial Flash On-chip for Custom Program
    • Internal ROM 448KB for critical constants and code
    • Internal SRAM 992KB for critical data and code
  • BT Features:
    • Bluetooth 5.2 dual-mode compliant
  • Audio Features:
    • Support BES Intelligent Bluetooth Retransmission (IBRT)
    • Support FF/Hybrid ANC
    • Dual MICs noise reduction
    • Echo Cancellation
    • Support low power voice activity detection
    • Multi-band EQ and Bass enhancement
    • Support Active Crossover
    • Support TWS
    • HiFi Stereo Audio DAC: 120dB SNR, 110dB DNR
    • HiFi Stereo Audio ADC: 100dB SNR
²* Sample rates from 8 kHz to 384 kHz
    • Support dual/single Mic noise suppression
    • Support ambient awareness
    • Support talk through
    • 24-bit audio processing
  • PMU Features
    • 3.1V-5.5V Input for VBAT
    • Internal LPO for low power mode.
    • DCXO with internal oscillator circuit
    • Internal temperature sensor
Information, Schematics and Certifications
