User:Pfeerick/Pfeerick-scratch-page
DO NOT USE THIS PAGE FOR REFERENCE MATERIAL FOR THE PINECUBE
Pinecube
CPUAllwinner(Sochip) ARM Cortex-A7 MPCore, 800MHz
RAM128MB DDR3
CPUQuad-Core ARM Cortex-A53
CameraOV5640, 5Mpx
StorageMicroSD slot, bootable
128Mb SPI Nor Flash, bootable
Dimensions55mm x 51mm x 51.5mm
NetworkWiFi
Screenoptional 4.5" RGB LCD screen
MiscVolume and home buttons
Speakers and microphone
Power
MicroUSB/GPIO5V 1A
PoE4V-18V
Batteryoptional 950-1600mAh
Overview
General waffle about the Pinecube. some pretty pictures. enough junk to push the gpio section down a bit. General waffle about the Pinecube. some pretty pictures. enough junk to push the gpio section down a bit. General waffle about the Pinecube. some pretty pictures. enough junk to push the gpio section down a bit.
Board Layout
BELOW INFO IS COMPLETELY INVALID FOR PINECUBE
Diagram Schematic
designator
Silkscreen
label
Number
of pins
Description
2 U39 PI-2-bus 40 Pi-2 bus
4 J8 +FAN- 2 PWM controlled fan header
5 J10 SPDIF 3 SPDIF header
I/O
  • 10/100Mbps Ethernet with passive PoE
  • USB 2.0 A host
  • Internal microphone
  • Speaker
  • Camera
  • Volume and home buttons
GPIO port
Consists of a 26 header pin connector with:
  • 2x 3.3V Output
  • 2x 5V Output
  • 1x I2C
  • 2x UART
  • 2x PWM
  • 1x SPI
  • 1x eMMC/SDIO/SD (8-bit)
  • 6x Interrupts
Note: Since some interfaces are multiplexed, they can't be all used at same time
GPIO Header Pinout: (PDF, HTML)
Power
    • 5V 1A from MicroUSB Port or GPIO port
    • 4V-18V from Ethernet passive PoE
  • Battery: optional 950-1600mAh model: 903048 Lithium Polymer Ion Battery Pack, can be purchase at Amazon.com
PineCube board information, schematics and certifications
  • LCD touch screen panel information:
  • Lithium battery information:
Operating Systems
Mainlining Efforts
Linux kernel
Type Link Available in version
Devicetree Entry Pinecube https://lkml.org/lkml/2020/9/22/1241 expected in 5.10
Correction for AXP209 driver https://lkml.org/lkml/2020/9/22/1243 5.9
U-boot
Buildroot
Stock Linux
SDK
Stock Linux
How to compile
Recommended system requirements:
  • OS: (L)Ubuntu 16.04
  • CPU: 64-bit based
  • Memory: 8 GB or higher
  • Disk: 15 GB free hard disk space
Install required packages
sudo apt-get install p7zip-full git make u-boot-tools libxml2-utils bison build-essential gcc-arm-linux-gnueabi g++-arm-linux-gnueabi zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32z1-dev
Install older Make 3.82 and Java JDK 6
pushd /tmp
wget https://ftp.gnu.org/gnu/make/make-3.82.tar.gz
tar xfv make-3.82.tar.gz
cd make-3.82
./configure
make
sudo apt purge -y make
sudo ./make install
cd ..
# Please, download jdk-6u45-linux-x64.bin from https://www.oracle.com/java/technologies/javase-java-archive-javase6-downloads.html (requires free login)
chmod +x jdk-6u45-linux-x64.bin
./jdk-6u45-linux-x64.bin
sudo mkdir /opt/java/
sudo mv jdk1.6.0_45/ /opt/java/
sudo update-alternatives --install /usr/bin/javac javac /opt/java/jdk1.6.0_45/bin/javac 1
sudo update-alternatives --install /usr/bin/java java /opt/java/jdk1.6.0_45/bin/java 1
sudo update-alternatives --install /usr/bin/javaws javaws /opt/java/jdk1.6.0_45/bin/javaws 1
sudo update-alternatives --config javac
sudo update-alternatives --config javaws
popd
Unpack SDK and then compile and pack the image
7z x 'PineCube Stock BSP-SDK ver1.0.7z'
mv 'PineCube Stock BSP-SDK ver1.0' pinecube-sdk
cd pinecube-sdk/camdroid
source build/envsetup.sh
lunch
mklichee
make -j3
pack
