POT
Revision as of 16:22, 20 February 2023 by Fxc (talk | contribs)
Peripheral On Top (POT)
POT Board Recommended PCB Dimension
USB/UART Programming/Console Adapter (PMPROG01)
Feature
Base on Silicon Libs CP2102
Support Virtual COM Port Device Drivers
Support USBXpress™ Direct Driver Support
With XH 5 pin 2.54mm pitch connector for UART connection
Voltage Output on the connection is selectable to either 5V,3.3V or off
On board USB-B Connector Receptor
Connector J3 can direct insert into Pine A64 Exp-Bus to provide console access to Pine A64 board
I/O pin are protected with ESD protector IC.
On board 5x2pin connector can direct insert into Pine A64 Exp Bus for UART0 Console access
Can use for programming and debugging for Wifi Remote I/O board
Related Specification and Document
CP2102 Datasheet
Virtual COM Port Driver
USBXpress Driver
POT: Veroboard (PMVRB01)
Feature
Sit on top of Pine A64 board
All the header receptor will have extended length pin to allow other POT board to insert on top of it
Allow easy access to all the I/O pin on the Pine A64 header
On board 4pcs of LED with current limiting resistor all direct connect to I/O pin for status indicator
On board 4pcs of Tact switch
On board XH5 2.54mm pitch connector for UART0 allow easy connection to USB/UART adapter for console access
PMVRB01 POT Veroboard Rev1-2B.png POT Veroboard on Pine A64
PMVRB01 POT Veroboard Rev1-1B.png POT Veroboard 2 board stack on top of Pine A64
POT: Multi I2C Bus (PMI2C01)
Feature
2 channel of I2C bus is wire out for easy access
I2C bus repeater IC (PCA9517A) are included in each I2C bus to allow connection of more devices on each bus
Support 3.3V and 5V I2C bus for each channel separately
On Board separated 3.3V supply regulator for 3.3V I2C Bus
Each I2C bus pin are protected with ESD protector devices
Each channel consist of 4 pcs of XH 4 pin 2.54mm pitch connector and 2 pcs of XH 5 pin 2.54mm pitch connector
For the XH 4 pin connector, will consist of GND,SCL,SDA,5V pin
For the XH 5 pin connector, will consist of GND,nINT,SCL,SDA,5V pin
5V supplier is direct connect from Pine A64 adapter's supply thus prevent over loading Pine A64 board
The nINT pin will allow peripheral with interrupt pin link back to the Pine A64 I/O pin
NXP PCA9517A Datasheet
NXP AN10658 Sending I2C-bus signal via long communication cables
NXP AN11075 Driving I2C-bus signals over twisted pair cables with PCA9605
Program to Enable I2c Port internal pull with full source code
Multi I2c Bus Schematic
POT: Shield Adapter (PMARD01)
Adapter for Arduino Shield
Separate on board LM1117 3.3V LDO for the Shield
Base on Maxim MAX11609 on ADC input. Allow up to 5V analog signal
Extra 5V input DC jack socket (suitable for 4.0mm X 1.7mm DC Jack) for extra input power
MAX11609 10bit I2C ADC
I2C Device: Humidity and Temperature Sensor (PMSDP01)
Feature
Base on Silicon Labs Si7021 I2C Humidity and Temperature Sensor
High Accuracy Temperature Sensor ±0.4 °C (max), –10 to 85 °C
0 to 100% RH operating range
Up to –40 to +125 °C operating range
On board 3.3V regulator
2pcs of XH 4pin 2.54 mm pitch connector to allow daisy chain of multiple I2C sensor
Si7021-A20 Datasheet
I2C Device: Ambient Light Sensor (PMSAL01)
Feature
Base on TAOS/AMS TSL2561T I2C Light Sensor
Approximates Human Eye Response
Programmable Interrupt Function allow user defined upper/lower limit trigger threshold
Automatically rejects 50/60Hz lighting ripple
Build with 2 channel of photodiode/ADC to allow more accurate calculation of light intensity (in Lux)
Can support up to 3pcs of sensor in the same I2C channel
2pcs of XH 5pin 2.54 mm pitch connector to allow daisy chain of multiple I2C sensor
TSL2561T Datasheet
WiFi Remote I2C (PMWF01A)
Feature
Base on ESP8266 Wifi Chipset
Connect to Wifi AP
On board chip antenna or U-FL connector for external antenna
On board relay contact (TE PCJ-105D3M with 3A 275Vac Contact) with screw type terminal contact to support AC Line On/Off
On board 1pc Tact-switch
XH 5 2.54mm pitch connector connecting I2C device
XH 6 2.54mm pitch connector for GPIO/SPI/PWM output
XH 2 2.54mm pitch connector for system power 5V input or output
DC Jack socket (suitable for 4.0mm X 1.7mm DC Jack) for system power input
UART Port connector ready for on chip programming using USB/UART Programming/Console Adapter (PMPROG01)
Further Detail info on the module can be found at WiFi Remote I2c Quick Start Guide wiki page
TE PCJ-105D3M Relay Datasheet
ESP8266 Datasheet
ESP8266 forum
Inter Connection Wire
