PINE H64 Model A
Revision as of 20:09, 6 February 2023 by Fxc (talk | contribs) (Reworked page, commented out super outdated releases)
The PINE H64 Model A
The PINE H64 Model A is a discontinued Single Board Computer by PINE64. It is powered by an Allwinner “H6” Quad-Core ARM Cortex A53 64-Bit Processor with a MALI T-722 GPU. For the Model B version see PINE H64 article.
Armbian
Armbian is a Linux distribution designed for ARM boards. They are usually Debian or Ubuntu flavored.
Download:
Default credentials
Default user root/1234
SoC and Memory Specification
The PINE H64 Model A is based on the Allwinner H6.
  • Quad-core ARM Cortex-A53 Processor@1488Mhz
  • Trustzone technology supported
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • ARM Mali T-720MP2 Dual-core GPU
  • Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
  • Supports ATSC (Adaptive Scalable Texture Compression)
  • Supports FAST(4x)FSAA, IO Coherency
  • Floating point operation greater than 70 GFLOPS
  • RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
  • Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
  • Digital Video 4KP60 (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1 (optional)
Storage
  • USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • mini PCIe connector
Pine H64 Board Information, Schematics and Certifications
PINE H64 Board Schematic:
PINE H64 Certification:
  • [Not yet available]
Allwinner H6 SoC information:
X-Powers AXP805 PMU (Power Management Unit) information:
LPDDR3 (178 Balls) SDRAM:
eMMC information:
SPI NOR Flash information:
Ethernet PHY information:
Wifi/BT module information:
miniPCIe SATA module information:
Enclosure information:
Remote control button mapping
Linux BSP SDK
The Linux BSP Kernel version 4.9
Download:
Mali-T720 driver
Here is the good DRM powerpoint presentation by Free Electron: https://free-electrons.com/pub/conferences/2017/kr/ripard-drm/ripard-drm.pdf
Here is the DRM video presentation by Free Electron: https://www.youtube.com/watch?v=LbDOCJcDRoo
32-bit Wayland MALI Driver:
