PINE H64 Model A
Revision as of 15:21, 4 September 2021 by Fxc (talk | contribs) (Fxc moved page PINE H64 Model-A Main Page to PINE H64 Model A: Streamlined article naming )
Armbian
Armbian Debian Stretch Nightly Build [microSD / eMMC Boot]
  • Login with
    • username: root
    • password: 1234
Android 7.x
Stock Android 7.0 microSD Card Boot 20180227 v1.0]
  • Support PINE64 RTL8723BS Wifi/BT Combo SDIO Module
  • Support 4K HDR playeback
  • Highly recommend using Etcher
  • DD images:
Stock Android 7.0 microSD Card to eMMC 20180227 v1.0]
  • DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
    • After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
  • DD images:
Stock Android 7.0 Phoenix Card image 20180227 v1.0]
  • Only use Phoenixcard method as last resort option
  • Select "Start up" as option for SD Card boot
  • Select "Product" as option for "SD Card to eMMC" method
  • This process may not everytime build up successfully
SoC and Memory Specification
  • Based on Allwinner H6
  • Quad-core ARM Cortex-A53 Processor@1488Mhz
  • Trustzone technology supported
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • ARM Mali T-720MP2 Dual-core GPU
  • Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
  • Supports ATSC (Adaptive Scalable Texture Compression)
  • Supports FAST(4x)FSAA, IO Coherency
  • Floating point operation greater than 70 GFLOPS
  • RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
  • Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
  • Digital Video 4KP60 (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1 (optional)
Storage
  • USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • mini PCIe connector
Pine H64 Board Information, Schematics and Certifications
Linux BSP SDK
Linux BSP Kernel ver 4.9
Linux BSP Kernel ver 3.10 Lichee ver 1.1
Linux BSP Kernel ver 3.10 Lichee ver 1.0
Mali-T720 driver
Here is the good DRM powerpoint presentation by Free Electron: https://free-electrons.com/pub/conferences/2017/kr/ripard-drm/ripard-drm.pdf
Here is the DRM video presentation by Free Electron: https://www.youtube.com/watch?v=LbDOCJcDRoo
32-bit Wayland MALI Driver:
Android SDK
Android Nougat 7.1 SDK version 1.0
Other Resources
