PINE H64 Model-A Main Page
Jump to navigation
Jump to search
Contents
Pine_H64_Model-A_Software_Release
Armbian
Armbian Debian Stretch Nightly Build(!) [microSD / eMMC Boot]
- DD image to microSD card or eMMC module and boot. Highly recommend using Etcher
- Direct download from Armbian
- File Size: 302MB
- Login with
- username: root
- password: 1234
- To find out more about Armbian and available options please visit their site
Android 7.x
Stock Android 7.0 microSD Card Boot 20180227 v1.0]
- Support PINE64 RTL8723BS Wifi/BT Combo SDIO Module
- Support 4K HDR playeback
- Highly recommend using Etcher
- Please allow 10-15 minutes boot up time on first time for initialization
- DD images:
- For 8GB microSD Card
- Direct download from pine64.org
- MD5 (GZip file): C74DDE53FFC943E870EE13F505BA48FB
- File Size: 407MB
- For 16GB microSD Card
- MD5 (GZip file): 7D5543ACD46B55BE17F306CE508A7758
- File Size: 416MB
- For 32GB microSD Card
- MD5 (GZip file): 5A58938E069D5EE1BCE345918994FD1E
- File Size: 434MB
- For 64GB microSD Card
- MD5 (GZip file): 25E54F1826B9F139A736BF31AD9F3965
- File Size: 470MB
Stock Android 7.0 microSD Card to eMMC 20180227 v1.0]
- DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
- After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
- DD images:
- Using 4GB or above microSD Card
- MD5 (GZip file): EA174FB353F3A7C649EA98C50E2A34A9
- File Size: 404MB
Stock Android 7.0 Phoenix Card image 20180227 v1.0]
- Only use Phoenixcard method as last resort option
- Select "Start up" as option for SD Card boot
- Select "Product" as option for "SD Card to eMMC" method
- This process may not everytime build up successfully
- MD5 (IMG file): 450372400D115980B5E9F5A7F4232174
- File Size: 802MB
SoC and Memory Specification
- Based on Allwinner H6
- Quad-core ARM Cortex-A53 Processor@1488Mhz
- A power-efficient ARM v8 architecture
- 64 and 32bit execution states for scalable high performance
- Trustzone technology supported
- Support NEON Advanced SIMD (Single Instruction Multiple Data) instruction for acceleration of media and signal processing function
- Support Large Physical Address Extensions(LPAE)
- VFPv4 Floating Point Unit
- 32KB L1 Instruction cache and 32KB L1 Data cache
- 512KB L2 cache
GPU Architecture
- ARM Mali T-720MP2 Dual-core GPU
- Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
- Supports ATSC (Adaptive Scalable Texture Compression)
- Supports FAST(4x)FSAA, IO Coherency
- Floating point operation greater than 70 GFLOPS
- RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
- Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
- Digital Video 4KP60 (Type A - full)
Audio
- 3.5mm stereo earphone/microphone plug
Network
- 10/100/1000Mbps Ethernet
- WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1 (optional)
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
- RTC - Real Time Clock Battery Connector
- Wifi/BT Module Header - SDIO 3.0 and UART
- 2x20 pins "Pi2" GPIO Header
- mini PCIe connector
Pine H64 Board Information, Schematics and Certifications
- Board Dimensions: 133mm x 80mm x 19mm
- Input Power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector, Euler connector
- PINE H64 Pi-2/Euler/Ext Bus Connector Pin Assignment
- PINE H64 Board Schematic:
- PINE H64 Certification:
- [Not yet available]
- Allwinner H6 SoC information:
- X-Powers AXP805 PMU (Power Management Unit) information:
- LPDDR3 (178 Balls) SDRAM:
- eMMC information:
- SPI NOR Flash information:
- Ethernet PHY information:
- Wifi/BT module information:
- miniPCIe SATA module information:
- Enclosure information:
- Remote control button mapping
Linux BSP SDK
Linux BSP Kernel ver 4.9
Linux BSP Kernel ver 3.10 Lichee ver 1.1
- Direct Download from pine64.org
- MD5 (TAR-GZip file): AE6CA68A230923031680BCFABDD7FC89
- File Size: 2.76GB
Linux BSP Kernel ver 3.10 Lichee ver 1.0
- MD5 (TAR-GZip file): 2D90557E63946A7DA64CD133EE57F206
- File Size: 2.40GB
Mali-T720 driver
Here is the good DRM powerpoint presentation by Free Electron: https://free-electrons.com/pub/conferences/2017/kr/ripard-drm/ripard-drm.pdf
Here is the DRM video presentation by Free Electron: https://www.youtube.com/watch?v=LbDOCJcDRoo
32-bit Wayland MALI Driver:
- MALI EULA document
- MALI-T720 32-bit server binary driver and binary download
- MD5: F2186A4CAE505A76E0758735886FE682
- File Size: 3.4MB
- MALI-T720 32-bit client binary driver and binary download
- MD5: F316A78AFABE87E69C8F816D18F15D68
- File Size: 3.4MB
Android SDK
Android Nougat 7.1 SDK version 1.0
- MD5 (TAR-GZip file): C5997ECB5730CC673396808FDA6A410D
- File Size: 10.56GB
