PINE H64
Jump to navigation
Jump to search
PINE H64 Model
There are two type of PINE H64 models, Click on the model A photo access to the model A main page. For model B, just stays on current page.
PINE H64 Model B Software and OS Image Downloads
Armbian
Armbian Debian Stretch Nightly Build(!) [microSD Boot]
- DD image to microSD card or eMMC module and boot. Highly recommend using Etcher
- Direct download from Armbian
- File Size: 302MB
- Login with
- username: root
- password: 1234
- To find out more about Armbian and available options please visit their site
LibreELEC(KODI)
Early Community Image [microSD Boot] [20190324]
- Direct download from LibreELEC
- File Size: 114MB
- MD5 (GZip file):24969ecc2ddc3adc62de9d58266b0f6ad0aafdb2c534b69617d83b9f9ee1ec2b
- FEATURES:
- mainline kernel & U-Boot
- completely open source except GPU (Mali) driver
- latest Kodi
- HDMI CEC
- multi channel HDMI audio (correct audio output must be selected)
- IR receiver
- Knows issue:
- Audio drop
- Get corrupted screen on TV when back BDISO video content
- Not support embedded subtitle
AOSC
AOSC Community Build Image with Mate Desktop [microSD Boot] [20190218]
- To learn more about AOSC, please visit the official AOSC website
- Known issue: no audio sound output.
- DD image (for 8GB micoSD card and above)
- Direct download from pine64.org
- MD5 (GZip file): 0274E1011BA58A45CB2B2104CEBD23AA
- File Size: 2.63GB
- Login with
- username: aosc
- password: anthon
AOSC Community Build Image with Mate Desktop [eMMC Boot] [20180216]
- MD5 (GZip file): 34F3F6813EF00FAF49B1C2A1562EE39D
- File Size: 2.63GB
- Login with
- username: aosc
- password: anthon
Android 9.0
Stock Android 9.0 microSD Card to eMMC 20190523]
- DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
- After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
- Highly recommend using Etcher
- Support 4K HDR playeback
- non rooted version
- PINE64 IR mapping not yet implemented
- Please allow 10-15 minutes boot up time on first time for initialization
- DD images:
- Using 8GB or above microSD Card
- MD5 (GZip file): 3B18BA6C82BF3E0020D0B54E9520755E
- File Size: 1.21GB
Stock Android 9.0 microSD and eMMC Boot 20190523]
- DD images:
- For 8GB microSD Card or eMMC module
- MD5 (GZip file): D2244B9FDD5100A4687C16C4A8034884
- File Size: 1.05GB
- Using 16GB microSD Card or eMMC module
- MD5 (GZip file): 9AC957ED7B71BA37A363098F6F15C32C
- File Size: 1.30GB
- Using 32GB microSD Card oe eMMC module
- MD5 (GZip file): 18BE1EDA248EDDAF35B80195954097A8
- File Size: 1.28GB
- Using 64GB or above microSD Card
- MD5 (GZip file): 49EEEBFDEC0337A47879EBE9439F4937
- File Size: 1.02GB
Stock Android 9.0 Phoenix Card image 20190523]
- Only use Phoenixcard method as last resort option
- Select "Start up" as option for SD Card boot
- Select "Product" as option for "SD Card to eMMC" method
- This process may not everytime build up successfully
- Using 4GB or above microSD Card
- MD5 (Gzip file): B0202A03C189897DEAFCC178B5829BEF
- File Size: 389MB
Android 7.x
Stock Android 7.0 microSD Card Boot 20190115]
- DD images:
- MD5 (GZip file): 12110D73CA7ADE749C948D63499B2AE3
- File Size: 417MB
- Using 16GB or above microSD Card
- MD5 (GZip file): FE6DB577CE6D54D3DDF25FD6CB9A8839
- File Size: 426MB
- Using 32GB or above microSD Card
- MD5 (GZip file): 8E37374D87FFDB5BC6D08635A168A152
- File Size: 444MB
- MD5 (GZip file): BA29EBCE85A71C408F6AB9FD3EA23885
- File Size: 482MB
Stock Android 7.0 microSD Card to eMMC 20190115]
- DD images:
- MD5 (GZip file): 61133A2967BDD2806F6AD2E144DD06AB
- File Size: 414MB
Stock Android 7.0 Phoenix Card image 20190115]
- MD5 (IMG file): 679E5F1A0F772B9F750E4139C8B025F0
- File Size: 822MB
SoC and Memory Specification
- Based on Allwinner H6
- Quad-core ARM Cortex-A53 Processor@1488Mhz
- A power-efficient ARM v8 architecture
- 64 and 32bit execution states for scalable high performance
- Trustzone technology supported
- Support NEON Advanced SIMD (Single Instruction Multiple Data) instruction for acceleration of media and signal processing function
- Support Large Physical Address Extensions(LPAE)
- VFPv4 Floating Point Unit
- 32KB L1 Instruction cache and 32KB L1 Data cache
- 512KB L2 cache
GPU Architecture
- ARM Mali T-720MP2 Dual-core GPU
- Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
- Supports ATSC (Adaptive Scalable Texture Compression)
- Supports FAST(4x)FSAA, IO Coherency
- Floating point operation greater than 70 GFLOPS
- RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
- Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
- Digital Video 4KP60 (Type A - full)
Audio
- 3.5mm stereo earphone/microphone plug
Network
- 10/100/1000Mbps Ethernet
- WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
- RTC - Real Time Clock Battery Connector
- Wifi/BT Module Header - SDIO 3.0 and UART
- 2x20 pins "Pi2" GPIO Header
Pine H64 Model B Board Information, Schematics and Certifications
- Board Dimensions: 85mm x 56mm x 18.8mm
- Input Power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector
- PINE H64 Board Schematic:
- PINE H64 Model B Certification:
- [Not yet available]
- Allwinner H6 SoC information:
- X-Powers AXP805 PMU (Power Management Unit) information:
- LPDDR3 (178 Balls) SDRAM:
- eMMC information:
- SPI NOR Flash information:
- Ethernet PHY information:
- Wifi/BT module information:
- Remote control button mapping
Linux BSP SDK
Linux BSP Kernel ver 4.9
Linux BSP Kernel ver 3.10 Lichee ver 1.1
- Direct Download from pine64.org
- MD5 (TAR-GZip file): AE6CA68A230923031680BCFABDD7FC89
- File Size: 2.76GB
Linux BSP Kernel ver 3.10 Lichee ver 1.0
- MD5 (TAR-GZip file): 2D90557E63946A7DA64CD133EE57F206
- File Size: 2.40GB
Mali-T720 driver
Here is the good DRM powerpoint presentation by Free Electron: https://free-electrons.com/pub/conferences/2017/kr/ripard-drm/ripard-drm.pdf
Here is the DRM video presentation by Free Electron: https://www.youtube.com/watch?v=LbDOCJcDRoo
32-bit Wayland MALI Driver:
- MALI EULA document
- MALI-T720 32-bit server binary driver and binary download
- MD5: F2186A4CAE505A76E0758735886FE682
- File Size: 3.4MB
- MALI-T720 32-bit client binary driver and binary download
- MD5: F316A78AFABE87E69C8F816D18F15D68
- File Size: 3.4MB
64-bit Wayland MALI Driver:
- MALI-T720 64-bit server binary driver and binary download
- MD5: 13CC8DCB7CF068D80DFC16281E95E9D7
- File Size: 5.0MB
- MALI-T720 64-bit client binary driver and binary download
- MD5: 951BAD6ED66D4CB904CFE0D65F2855E8
- File Size: 5.0MB
Android SDK
Android Nougat 7.1 SDK version 1.0
- MD5 (TAR-GZip file): C5997ECB5730CC673396808FDA6A410D
- File Size: 10.56GB
