PINE H64
Pine_H64_Software_Release
Android 7.x
Stock Android 7.0 microSD Card Boot 20180227 v1.0]
- Support PINE64 RTL8723BS Wifi/BT Combo SDIO Module
- Support 4K HDR playeback
- Highly recommend using Etcher
- Please allow 10-15 minutes boot up time on first time for initialization
- DD images:
- For 8GB microSD Card
- Direct download from pine64.org
- MD5 (GZip file): 065E66E581D671AB3FDB5C8D36BCD23C
- File Size: 1.09GB
- For 16GB, 32GB and 64GB SD Card OS build will be provide soon
Stock Android 7.0 SD Card to eMMC 20180227 v1.0]
- DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
- After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
- DD images:
- Using 4GB or above microSD Card
- MD5 (GZip file): ECB9934B0D86B3B5EA9037D6EBD878F2
- File Size: 404MB
Stock Android 7.0 Phoenix Card image 20180227 v1.0]
- Only use Phoenixcard method as last resort option
- Select "Start up" as option for SD Card boot
- Select "Product" as option for "SD Card to eMMC" method
- This process may not everytime build up successfully
- MD5 (Zip file): 450372400D115980B5E9F5A7F4232174
- File Size: 802MB
SoC and Memory Specification
- Based on Allwinner H6
- Quad-core ARM Cortex-A53 Processor@1488Mhz
- A power-efficient ARM v8 architecture
- 64 and 32bit execution states for scalable high performance
- Trustzone technology supported
- Support NEON Advanced SIMD (Single Instruction Multiple Data) instruction for acceleration of media and signal processing function
- Support Large Physical Address Extensions(LPAE)
- VFPv4 Floating Point Unit
- 32KB L1 Instruction cache and 32KB L1 Data cache
- 512KB L2 cache
GPU Architecture
- ARM Mali T-720MP2 Dual-core GPU
- Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
- Supports ATSC (Adaptive Scalable Texture Compression)
- Supports FAST(4x)FSAA, IO Coherency
- Floating point operation greater than 70 GFLOPS
- RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
- Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
- HDMI 2.0a (Type A - full)
Audio
- 3.5mm stereo earphone/microphone plug
Network
- 10/100/1000Mbps Ethernet
- WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1 (optional)
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
- RTC - Real Time Clock Battery Connector
- Wifi/BT Module Header - SDIO 3.0 and UART
- 2x20 pins "Pi2" GPIO Header
- mini PCIe connector
Pine H64 Board Information, Schematics and Certifications
- Board Dimensions: 133mm x 80mm x 19mm
- Input Power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector, Euler connector
- PINE H64 Board Schematic:
- PINE H64 Certification:
- [Not yet available]
- Allwinner H6 SoC information:
- X-Powers AXP805 PMU (Power Management Unit) information:
- LPDDR3 (178 Balls) SDRAM:
- eMMC information:
- SPI NOR Flash information:
- Ethernet PHY information:
- Wifi/BT module information:
- miniPCIe SATA module information:
- Enclosure information:
- Remote control button mapping
Linux BSP SDK
Linux BSP Kernel ver 4.9
Linux BSP Kernel ver 3.10
- Direct Download from pine64.org
- MD5 (TAR-GZip file): 2D90557E63946A7DA64CD133EE57F206
- File Size: 2.40GB
Android SDK
Android Nougat [v7.1]
- MD5 (TAR-GZip file): C5997ECB5730CC673396808FDA6A410D
- File Size: 10.56GB
