PINE H64
PINE H64 Model
There are two type of PINE H64 models:
Click on the model A photo to access the model A main page.
For model B, stay on the current page.
PINE H64 Model B Software and OS Image Downloads
Armbian
PLEASE NOTE: Armbian doesn't seem to support the Pine H64-B boards, and the A boards are listed as a WIP, checkout the forum for more details
Armbian Debian Buster Nightly Build(!) [microSD Boot]
  • Login with
    • username: root
    • password: 1234
LibreELEC(KODI)
Early Community Image [microSD Boot] [20190324]
    • Direct download from LibreELEC
      • File Size: 114MB
      • MD5 (GZip file):24969ecc2ddc3adc62de9d58266b0f6ad0aafdb2c534b69617d83b9f9ee1ec2b
    • FEATURES:
      • mainline kernel & U-Boot
      • completely open source except GPU (Mali) driver
      • latest Kodi
      • HDMI CEC
      • multi channel HDMI audio (correct audio output must be selected)
      • IR receiver
    • Knows issue:
      • Audio drop
      • Get corrupted screen on TV when back BDISO video content
      • Not support embedded subtitle
AOSC
AOSC Community Build Image with Mate Desktop [microSD Boot] [20190218]
  • To learn more about AOSC, please visit the official AOSC website
  • Known issue: no audio sound output.
  • Login with
    • username: aosc
    • password: anthon
AOSC Community Build Image with Mate Desktop [eMMC Boot] [20180216]
  • Login with
    • username: aosc
    • password: anthon
Android 9.0
Stock Android 9.0 microSD Card to eMMC 20190523]
  • DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
    • After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
  • Highly recommend using Etcher
  • Support 4K HDR playeback
  • non rooted version
  • PINE64 IR mapping not yet implemented
  • DD images:
Stock Android 9.0 microSD and eMMC Boot 20190523]
  • Please allow 20-25 minutes boot up time on first time for initialization
  • DD images:
Stock Android 9.0 Phoenix Card image 20190523]
  • Only use Phoenixcard method as last resort option
  • Select "Start up" as option for SD Card boot
  • Select "Product" as option for "SD Card to eMMC" method
  • This process may not everytime build up successfully
Android 7.x
Stock Android 7.0 microSD Card Boot 20190115]
  • DD images:
Stock Android 7.0 microSD Card to eMMC 20190115]
  • DD images:
Stock Android 7.0 Phoenix Card image 20190115]
SoC and Memory Specification
  • Based on Allwinner H6
  • Quad-core ARM Cortex-A53 Processor@1488Mhz
  • Trustzone technology supported
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • ARM Mali T-720MP2 Dual-core GPU
  • Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
  • Supports ATSC (Adaptive Scalable Texture Compression)
  • Supports FAST(4x)FSAA, IO Coherency
  • Floating point operation greater than 70 GFLOPS
  • RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
  • Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
  • Digital Video 4KP60 (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1
Storage
  • USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
Pine H64 Model B Board Information, Schematics and Certifications
  • Board Dimensions: 85mm x 56mm x 18.8mm
  • Input Power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector
  • PINE H64 Model B Certification:
    • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submits the SBC for FCC, CE, and ROHS certifications and obtain the certificates to prove that the SBC board can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
    • PINE-H64 Model-B FCC Certificate
    • PINE-H64 Model-B CE Certificate]
Mali-T720 driver
Here is a good DRM powerpoint presentation by Free Electron: https://free-electrons.com/pub/conferences/2017/kr/ripard-drm/ripard-drm.pdf
Here is the DRM video presentation by Free Electron: https://www.youtube.com/watch?v=LbDOCJcDRoo
32-bit Wayland MALI Driver:
64-bit Wayland MALI Driver:
Linux BSP SDK
Linux BSP Kernel 4.9
Android SDK
Android Pie 9.0 SDK version 1.0
Other Resources
