PINE H64
Revision as of 04:32, 13 April 2019 by Tllim (talk | contribs)
PINE H64 Model
There are two type of PINE H64 models, Click on the model A photo access to the model A main page. For model B, just stays on current page.
PINE H64 Model B Software and OS Image Downloads
Armbian
Armbian Debian Stretch Nightly Build(!) [microSD / eMMC Boot]
  • Login with
    • username: root
    • password: 1234
LibreELEC(KODI)
Early Community Image [microSD / eMMC Boot] [20190324]
    • Direct download from LibreELEC
      • File Size: 114MB
      • MD5 (GZip file):24969ecc2ddc3adc62de9d58266b0f6ad0aafdb2c534b69617d83b9f9ee1ec2b
    • FEATURES:
      • mainline kernel & U-Boot
      • completely open source except GPU (Mali) driver
      • latest Kodi
      • HDMI CEC
      • multi channel HDMI audio (correct audio output must be selected)
      • IR receiver
AOSC
AOSC Community Build Image with Mate Desktop [microSD Boot] [20190218]
  • To learn more about AOSC, please visit the official AOSC website
  • Known issue: no audio sound output.
  • Login with
    • username: aosc
    • password: anthon
AOSC Community Build Image with Mate Desktop [eMMC Boot] [20180216]
  • Login with
    • username: aosc
    • password: anthon
Android 7.x
Stock Android 7.0 microSD Card Boot 20190115]
  • Support 4K HDR playeback
  • Highly recommend using Etcher
  • DD images:
Stock Android 7.0 microSD Card to eMMC 20190115]
  • DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
    • After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
  • DD images:
Stock Android 7.0 Phoenix Card image 20190115]
  • Only use Phoenixcard method as last resort option
  • Select "Start up" as option for SD Card boot
  • Select "Product" as option for "SD Card to eMMC" method
  • This process may not everytime build up successfully
SoC and Memory Specification
  • Based on Allwinner H6
  • Quad-core ARM Cortex-A53 Processor@1488Mhz
  • Trustzone technology supported
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • ARM Mali T-720MP2 Dual-core GPU
  • Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
  • Supports ATSC (Adaptive Scalable Texture Compression)
  • Supports FAST(4x)FSAA, IO Coherency
  • Floating point operation greater than 70 GFLOPS
  • RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
  • Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
  • Digital Video 4KP60 (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1
Storage
  • USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
Pine H64 Model B Board Information, Schematics and Certifications
  • Board Dimensions: 85mm x 56mm x 18.8mm
  • Input Power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector
  • PINE H64 Model B Certification:
    • [Not yet available]
Linux BSP SDK
Linux BSP Kernel ver 4.9
Linux BSP Kernel ver 3.10 Lichee ver 1.1
Linux BSP Kernel ver 3.10 Lichee ver 1.0
Mali-T720 driver
Here is the good DRM powerpoint presentation by Free Electron: https://free-electrons.com/pub/conferences/2017/kr/ripard-drm/ripard-drm.pdf
Here is the DRM video presentation by Free Electron: https://www.youtube.com/watch?v=LbDOCJcDRoo
32-bit Wayland MALI Driver:
Android SDK
Android Nougat 7.1 SDK version 1.0
Other Resources
