PINE H64
Pine_H64_Software_Release
Android 7.x
Stock Android 7.0 microSD Card Boot 20180227 v1.0]
  • Support PINE64 RTL8723BS Wifi/BT Combo SDIO Module
  • Support 4K HDR playeback
  • Highly recommend using Etcher
  • DD images:
    • For 8GB microSD Card
    • For 16GB, 32GB and 64GB SD Card OS build will be provide soon
Stock Android 7.0 microSD Card to eMMC 20180227 v1.0]
  • DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
    • After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
  • DD images:
Stock Android 7.0 Phoenix Card image 20180227 v1.0]
  • Only use Phoenixcard method as last resort option
  • Select "Start up" as option for SD Card boot
  • Select "Product" as option for "SD Card to eMMC" method
  • This process may not everytime build up successfully
SoC and Memory Specification
  • Based on Allwinner H6
  • Quad-core ARM Cortex-A53 Processor@1488Mhz
  • Trustzone technology supported
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • ARM Mali T-720MP2 Dual-core GPU
  • Supports OpenGL ES 3.1/3.0/2.0/1.1, OpenCL 1.2/1.1
  • Supports ATSC (Adaptive Scalable Texture Compression)
  • Supports FAST(4x)FSAA, IO Coherency
  • Floating point operation greater than 70 GFLOPS
  • RAM Memory Variants: 1GB, 2GB, and 3GB LPDDR3.
  • Storage Memory: PINE H64 boards have built-in 128Mb SPI Flash memory, use bootable eMMC module, bootable microSD Cards or USB attached storage.
Board Features
Video
  • HDMI 2.0a (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 4.0/4.1 (optional)
Storage
  • USB - 1 USB3.0 Host port and 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • mini PCIe connector
Pine H64 Board Information, Schematics and Certifications
  • Board Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 5V @ 3A, 3.5mm OD/ 1.35mm ID DC jack connector, Euler connector
  • PINE H64 Certification:
    • [Not yet available]
Linux BSP SDK
Linux BSP Kernel ver 4.9
Linux BSP Kernel ver 3.10
Android SDK
Android Nougat [v7.1]
Other Resources
