PINE A64 Software Releases
Checking microSD Card performance and check whether is counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not.
Linux Image Release
Special thanks to Sunxi community and longsleep contribution
Debian Linux with Mate GUI 20160422 by lenny.raposo with Longsleep kernel
  • DD image (for 8GB and above SD Card):
  • Direct download 2nd site
  • Torrent download
    • MD5 (Zip file): a3d7b36af0a1278332eb29d36a168e48
    • File Size: 1.1GB
  • Included with Wifi
  • Suitable for 512MB/1GB/2GB PineA64 Board
  • Login with
    • username: pine64user
    • password: password
  • Execute resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
Ubuntu Linux Image base on Longsleep 20160421 image, Pine64
  • Torrent Download
  • Base on longsleep xubuntu-xenial 20160415
  • Suitable for 1GB/2GB Pine A64+ Board, not advise to run on 512MB Pine A64 Board
  • Added xubuntu-desktop GUI
  • MD5 (Zip file) : 1cd06bdcbc1ceaf80b81c46638045ff7
  • File Size: 1.8GB
  • Login with
    • username: ubuntu
    • password: ubuntu
Ubuntu Linux Image base on Longsleep 20160403-1 image, Pine64
Ubuntu Linux Image base on Longsleep 20160403-1 image, courtesy of Michael Larson
Image Info
  1. Software installed:
    • Ubuntu Software portal
    • LibreOffice Suite
    • Gimp
    • Midori web browser
    • Geary email
    • VLC and several others.
  2. You can flash this in linux using all the regular methods or you can use Win32 Disk Image software or something simular.
  3. Gparted is installed and allows you to re-size the rootfs partition to the rest of your drive if it is bigger than an 8GB drive.See the video instruction on how to use Gpart and change login information
  4. User Login username and password,
    • User Name: Ubuntu Password: ubuntu
    • User Name: Ubuntu2 Password: ubuntu2
Arch Linux Image with XFCE4 Base on Longsleep Image 20160415
  1. Image for size less then 4GB, require to expend to larger size after install
  2. Added XFCE4 Desktop Environment
  3. Added Midori Web browser
  4. Added LibreOffice
  5. Will direct boot into GUI
  6. File Size: 1GB
  • Login with
    • username: alarm
    • password: alarm
Arch Linux Image with XFCE4 Base on Longsleep Image 20160304-1
Image Info
  1. Base on Longsleep's Arch Linux Image arch-pine64-bspkernel-20160304-1.img.xz
  2. For further info on the Longsleep Arch Linux Image, please refer to the Forum
  3. Added SLiM Display Manager
  4. Added XFCE4 Desktop Environment
  5. Added Midori Web browser
  6. Will direct boot into GUI
  7. MD5: b3289017d352c45579fe111e90b41664
  8. File size : 676MB
Setup Info
  1. Use Winrar to extract the img file form the archive
  2. Use Win32 Disk Imager to write the img to a SD card
  3. Insert the SD card into Pine A64 board and boot it up
  4. Tested with 1GB Ram version of Pine A64 board
  5. Login using username:password, root/root, alarm/alarm, guest/guest
Remix OS Image Release
Remix OS 2.0 Image Release 20160415 Beta
  • This version best suitable for 2GB Pine A64+ Board, can runs on 1GB Pine A64+ Board with performance lagging, not suitable for 512MB Pine A64 Board
  • DD image (for 8GB SD Card):
    • MD5 (Zip file): efeb178d28593d4d928f70c8506953a4
    • File Size: 1.2G
Setup Info
  2. Use Allwinner PhoenixCard Bootable SD-Card Creator to create the bootable SD Card
Android Image Release
Android 5.1.1 Image Release 20160303
  • Please take note that this release is for Pine A64 1GB and 2GB Ram version only.
Android Image Release 20160216
Improvements
  1. Solved Gigabit Ethernet Hang issues
  2. Please take note that this release is for Pine A64 1GB and 2GB Ram version only.
Android Image Release 20160112
  • The Android build suitable for 1GB/2GB Pine A64+ Board, not advise to run on 512MB Pine A64 Board due to system memory constrain
Pine A64 Android Lollipop Image Rev 2016012
DD Image Base On Lollipop Image Rev 20160112
Improvements
  1. Improve HDMI output performance,
    • Solve power up delay HDMI output.
    • Solve HDMI recovery no output bug.
  2. Increase CMA reserve space
    • Improve system performance
    • Now able to play 1080P 4K video and solve playback jerky issue
  3. Increase and improve the AV decoding format lib
    • Solve some of the video playback without audio output issue.
  4. Solve IR Control controlling issue
  5. Android Power time are as below,
    • First time power up
      Require 10 second to show the initial Logo page.
      On 278th second, will go into the Android main screen display.
    • For Sub-sequence power up
      On 70th second, will go into the Android main screen display.
      Android will take longer to start-up if the display showing 'Updating' windows.
Known problems
  1. GbE still unable to connect and currently fixing it. 100Mbps Ethernet link should be no problem.
Android Image Release 20151210
Linux BSP Related
Android and Linux BSP 1.2 20160113
  • Total Archive file size : 22.4GB
  • Tar file MD5: 5c50e7e54a7c9b9c919bb54a1e631647
  • Tar file SHA256: 5d5e27d2844ac16d76083a8e15cfca2acee525d7ddcf72e974e394bd8fe173b1
Linux BSP 1.0 20151120
Other Tools
