PINE A64 Software Releases
Revision as of 11:20, 21 April 2016 by Pineadmin (talk | contribs) (→Arch Linux Image with XFCE4 Base on Longsleep Image 20160415)
Detecting USB Counterfeit Drives
This will help you to determine if the SD-Card is Counterfeit Drive or not.
Linux Image Release
Ubuntu Linux Image base on Longsleep 20160421 image, Pine64
- Direct download from pine64.org
- Base on longsleep xubuntu-xenial 20160415
- Added xubuntu-desktop GUI
- MD5 : 1cd06bdcbc1ceaf80b81c46638045ff7
Ubuntu Linux Image base on Longsleep 20160403-1 image, Pine64
- Torrent download
- Base on longsleep xubuntu-xenial 20160403
Ubuntu Linux Image base on Longsleep 20160403-1 image, courtesy of Michael Larson
Image Info
- Software installed:
- Ubuntu Software portal
- LibreOffice Suite
- Gimp
- Midori web browser
- Geary email
- VLC and several others.
- You can flash this in linux using all the regular methods or you can use Win32 Disk Image software or something simular.
- Gparted is installed and allows you to re-size the rootfs partition to the rest of your drive if it is bigger than an 8GB drive.See the video instruction on how to use Gpart and change login information
- User Login username and password,
- User Name: Ubuntu Password: ubuntu
- User Name: Ubuntu2 Password: ubuntu2
- Image for size less then 4GB, require to expend to larger size after install
- Added XFCE4 Desktop Environment
- Added Midori Web browser
- Added LibreOffice
- Will direct boot into GUI
- File Size: 1GB
Arch Linux Image with XFCE4 Base on Longsleep Image 20160304-1
- This version of image is not suitable for PineA64 with 2GB Memory due to a bug involving DMA data transfer with the gigabit ethernet
- Mega.ne Direct Download
- Torrent Download
Image Info
- Base on Longsleep's Arch Linux Image arch-pine64-bspkernel-20160304-1.img.xz
- For further info on the Longsleep Arch Linux Image, please refer to the Forum
- Added SLiM Display Manager
- MD5: b3289017d352c45579fe111e90b41664
- File size : 676MB
Setup Info
- Use Winrar to extract the img file form the archive
- Use Win32 Disk Imager to write the img to a SD card
- Insert the SD card into Pine A64 board and boot it up
- Tested with 1GB Ram version of Pine A64 board
- Login using username:password, root/root, alarm/alarm, guest/guest
Remix OS Image Relese
Remix OS 2.0 Image Release 20160415 Beta
Fixed the 2GB Memory problem.
- Torrent download
- Mega Download
- Direct Download from pine64.org
- Total filesize : 473MB
Remix OS Image Release 20160227 Beta
- Torrent download
- Direct download
- Direct download from Mega.nz
- Total filesize : 348MB
- MD5 : f34a39bbf21ad7d4516f3cd345d086f5
- Only suitable for PineA64 1GB and 2GB Ram version only
Setup Info
- Use Allwinner PhoenixCard Bootable SD-Card Creator to create the bootable SD Card
Android Image Release
Android Image Release 20160303
- DD image:
- MD5: 1cd06bdcbc1ceaf80b81c46638045ff7
- File Size: 1.1G
- Phoenix Card image:
- MD5: 929ba8659028cf42895804864d66991e
- File Size: 337MB
- Please take note that this release is for Pine A64 1GB and 2GB Ram version only.
Android Image Release 20160216
- Google Drive Direct Download
- Mega.nz Drive Direct Download
- Torrent Download
- MD5: 0aca1b9cc94babdb9313ce8c33a154f2
- File Size: 345MB
Improvements
- Solved Gigabit Ethernet Hang issues
Android Image Release 20160112
Pine A64 Android Lollipop Image Rev 2016012
- Torrent Download
- MD5:edd5d7089d19dee5b350ae22108ffe97
DD Image Base On Lollipop Image Rev 20160112
- Torrent Download
- MD5: 2c4ea2529f48c0348b6757acda17e6b6.
- This DD image require minimum 8G Micro SD Card.
Improvements
- Improve HDMI output performance,
- Solve power up delay HDMI output.
- Solve HDMI recovery no output bug.
- Increase CMA reserve space
- Improve system performance
- Now able to play 1080P 4K video and solve playback jerky issue
- Increase and improve the AV decoding format lib
- Solve some of the video playback without audio output issue.
- Solve IR Control controlling issue
- Android Power time are as below,
- First time power up
Require 10 second to show the initial Logo page.
On 278th second, will go into the Android main screen display. - For Sub-sequence power up
On 70th second, will go into the Android main screen display.
Android will take longer to start-up if the display showing 'Updating' windows.
Known problems
- GbE still unable to connect and currently fixing it. 100Mbps Ethernet link should be no problem.
Android Image Release 20151210
- Google Drive : Pine A64 Android Lollipop Image Rev 20151210
- Torrent : Pine A64 Android Lollipop Image Rev 20151210
Linux BSP Related
Android and Linux BSP 1.2 20160113
- Torrent Download
- Torrent Part1
- Torrent Part2
- Each Torrent contain 3 parts, total 6 parts, then join them after download.
- Refer reademe.txt for details.
- Direct Download from Mega.nz
- a64-1.2-20160113.tar.001 (3.91GB)
- a64-1.2-20160113.tar.002 (3.91GB)
- a64-1.2-20160113.tar.003 (3.91GB)
- a64-1.2-20160113.tar.004 (3.91GB)
- a64-1.2-20160113.tar.005 (3.91GB)
- a64-1.2-20160113.tar.006 (3.09GB)
- Readme.txt
- Requires to use Megasync to download (due to files being larger than 1GB).
- Total Archive file size : 22.4GB
- Tar file MD5: 5c50e7e54a7c9b9c919bb54a1e631647
- Tar file SHA256: 5d5e27d2844ac16d76083a8e15cfca2acee525d7ddcf72e974e394bd8fe173b1
Linux BSP 1.0 20151120
- Google Drive : Allwinner A64 Linux 3.10 BSP
- Torrent : Allwinner A64 Linux 3.10 BSP
- Direct download from pine64.org : Allwinner A64 Linux 3.10 BSP
- Linux Boot Image Release 2016/Feb/16 (8.3MB)
- This Linux boot.img support Gigabit Ethernet
