PINE A64 Software Releases
Revision as of 00:47, 21 March 2016 by Pineadmin (talk | contribs)
Detecting USB Counterfeit Drives
Linux Image Release
Arch Linux Image with XFCE4 Base on Longsleep Image 20160304-1
Image Info
  1. Base on Longsleep's Arch Linux Image arch-pine64-bspkernel-20160304-1.img.xz
  2. For further info on the Longsleep Arch Linux Image, please refer to the Forum
  3. Added SLiM Display Manager
  4. Added XFCE4 Desktop Environment
  5. Added Midori Web browser
  6. Will direct boot into GUI
  7. MD5: b3289017d352c45579fe111e90b41664
  8. File size : 676MB
Setup Info
  1. Use Winrar to extract the img file form the archive
  2. Use Win32 Disk Imager to write the img to a SD card
  3. Insert the SD card into Pine A64 board and boot it up
  4. Tested with 1GB Ram version of Pine A64 board
  5. Login using username:password, root/root, alarm/alarm, guest/guest
Remix OS Image Relese
Remix OS Image Release 20160227 Beta
Setup Info
  2. Use Allwinner PhoenixCard Bootable SD-Card Creator to create the bootable SD Card
Android Image Release
Android Image Release 20160216
Improvements
  1. Solved Gigabit Ethernet Hang issues
  2. Please take note that this release is for Pine A64 1GB and 2GB Ram version only.
Android Image Release 20160112
Pine A64 Android Lollipop Image Rev 2016012
DD Image Base On Lollipop Image Rev 20160112
Improvements
  1. Improve HDMI output performance,
    • Solve power up delay HDMI output.
    • Solve HDMI recovery no output bug.
  2. Increase CMA reserve space
    • Improve system performance
    • Now able to play 1080P 4K video and solve playback jerky issue
  3. Increase and improve the AV decoding format lib
    • Solve some of the video playback without audio output issue.
  4. Solve IR Control controlling issue
  5. Android Power time are as below,
    • First time power up
      Require 10 second to show the initial Logo page.
      On 278th second, will go into the Android main screen display.
    • For Sub-sequence power up
      On 70th second, will go into the Android main screen display.
      Android will take longer to start-up if the display showing 'Updating' windows.
Known problems
  1. GbE still unable to connect and currently fixing it. 100Mbps Ethernet link should be no problem.
Android Image Release 20151210
Linux BSP Related
Android and Linux BSP 1.2 20160113
Linux BSP 1.0 20151120
Other Tools
